#61 | |
So, no shock relocators or exhaust mods in the "comprehensive" plan then?
#62 | |
want it rite or rite now?
what was that comment about the 231 being worth putting money in again..... ![]() ![]() I believe it got a new sye put in, then they never put in enough oil, I'm certain it didn't leak due to how much silicone it had stuck in it... that thing was toast. I ended up using the sye, in another t-case... hope the temper is still good... shock relocation is awesome for a few reasons, just not exactly needed with the proper length shocks for the lift height..
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable HighLine Hood Jeepers TJ Adjustable Track bars DIY highline fenders.... 34-37's under 0"-2.5" lifts shock length, bumpstop extension, tire size chart click here DIY shock shifters, more uptravel/better ride 2011 E-350 4x4 Van conversion 2006 Rubicon Unlimited ASE Certified Master Tech/Fabricator In need of work... 11/2/11 |
#63 | |
don't know how exhaust mods fit with a 2.5" suspension, but if I get rubbing on the shock, I'll probably just leave it for now. May cut the tailpipe off and weld a turndown on if I have to. But so far, no issues.... Eventually I'd like to go to a 2.5" diameter exhaust, but thats waaaaaaay down the road.
Useful Write-Ups: SEARCH TUTORIAL TJ Tech BOOT CAMP-A Must Read! FAQ: Cold Air Intakes & K&N's Off-Road Tips and Techniques What is a CV shaft and why do I want one? So you want a Tummy Tuck? Tire size, lift height, bumpstops & shock guide DIY Shock Shifters for Long Travel Shocks Lug nuts and bolt patterns Catalytic Converters Busted TJ Track Bar Bolt Fix Brake Knuckle Divot/Groove Repair Coconut Oil for Drilling and Machining Fabrication & Build: My Build Thread Funny: Will it fit in my Jeep? |
#64 | |
Why a 2.5" exhaust, you will loose almost all the back pressure that you have right now? |
#65 | |
AND...found a NV241J in my price range thanks to "provelogear" (Savvy Offroad). Thanks !
#66 | |
#67 |
I installed the Banks catback and lost low end torque. Installed an exhaust pipe reducer in the end of the 2.5" pipe and got the low end torque back...
#68 | |
#69 |
had some death wooble symptoms the other day, so decided to check the track bar. broke the axle side front track bar bolt this morning checking the torque....today wasnt my day. Spent 5 hours screwing with the t-case linkage too....
The stock track bar bolt is 10.9 and has 9mm shaft, but M10 (10mm x 1.5) threads....which is why its so loose inside the JKS track bar. Stock Bolt Shaft (9mm): ![]() Stock Threads (10mm): ![]() Normal Class 8.8, Class 10.9 and Class 12.9 Bolt Shaft (10mm): ![]() Normal Class 8.8, Class 10.9 and Class 12.9 Bolt Threads (10mm): ![]() This makes no sense to me, because the OD of the non-thread shaft should be the same as the major diameter as the threads, not the minor diameter. Every bolt you buy at the hardware store is like this, but Jeep's bolt isn't. And the hole is drilled to 7/16" - so its a custom metric bolt in a standard drilled hole. Whatever, typical Chrysler engineering...crap like this is why they went bankrupt. So the local hardware store doesn't have any hex head 10.9 bolts because they are morons. they only have 8.8 hex heads, and 12.9 socket head cap screws. Then the hardware store guy tried to tell me Class 8.8 = Grade 8. ![]() I bought two hex Class 8.8 and one socket head cap Class 12.9, all M10 x 1.5. [Engineering Speak] All 10.9 bolts have a tensile strength of 145 ksi (kilo-psi), all 8.8 bolts have a tensile strength of 116 ksi. For reference Grade 5 = 120 ksi and Grade 8 = 150 ksi. Class 12.9 has a tensile strength of 174 ksi. Source: www.mcmaster.com The factory torque spec is 55 ft-lbs. BUT - a Class 8.8 M10 bolt can only take 40-45 ft-lbs of torque before the threads distort and the bolt is useless. A Class 10.9 M10 bolt can take ~55-60 ft-lbs. A Class 12.9 M10 bolt can take ~73 ft-lbs. Source: http://dodgeram.org/tech/specs/bolts/M_bolts.html and http://www.dansmc.com/torque_chart.htm and and http://books.google.com/books?id=_Pk8raJvVaEC&printsec=frontcover&dq=Elect romechanical+design+handbook [/Engineering Speak] What does this mean? Since the stock torque spec is at the upper limit of a 10.9 and grade 8 bolt, you can very easily overtorque the stock bolt, causing the threads to deform and the next time you go to use the bolt it is useless and will not torque properly. It will just snap. Thats what happened to me. The solution - buy a 12.9 M10x1.5 75mm bolt and torque to 55-65 ft-lbs. Also, every M10 x 1.5 bolt you buy from McMaster or a hardware store will have a 10mm OD shaft instead of the stock 9mm, which makes it fit more snug in the track bar (a good thing!). You'll have to drill out the stock washer, I worked it with a 3/8" drill bit for a while. I couldn't find a thick, larger OD 10mm ID washer to match the stock one. Finished - Class 12.9 Socket Head Cap Screw, Class 10.9 thin washer + drill out stock washer: ![]() I reused the stock nut after chasing the threads with an M10 tap - I chewed them up trying to get the busted bolt out. Torqued to 55-60 ft-lbs and used a bit of blue lock-tite. make sure to tighten the Class 12.9 M10 bolt with an 8mm Allen head - careful not to strip the allen head!
Useful Write-Ups: SEARCH TUTORIAL TJ Tech BOOT CAMP-A Must Read! FAQ: Cold Air Intakes & K&N's Off-Road Tips and Techniques What is a CV shaft and why do I want one? So you want a Tummy Tuck? Tire size, lift height, bumpstops & shock guide DIY Shock Shifters for Long Travel Shocks Lug nuts and bolt patterns Catalytic Converters Busted TJ Track Bar Bolt Fix Brake Knuckle Divot/Groove Repair Coconut Oil for Drilling and Machining Fabrication & Build: My Build Thread Funny: Will it fit in my Jeep? Last edited by Unlimited04; 05-07-2010 at 08:23 AM.. |
#70 |
New toy to grin at:
![]() ![]() It won't be installed for a long time. Need to save money for some adjustable arms, new rear driveshaft, front u-joint 1310-->1330 thingy, the necessary wiring crap, speedo corrector thingy, etc. So for now, its wheeling next to the futon.
#71 |
Did some quick wheeling on a trail today to check flex and for track-bar interference.
I can put my finger between Riddler and the JKS track bar. Its close, but doesn't appear I'll have issues at this point. These are all with sway bars connected: ![]() ^the front is still like an inch or more off the bumpstop, and the rear is probably 1/2-3/4" off the bumpstop, and I got 2-3 fingers between the flare and the tire. Plenty of room for 33s! ![]() Next issue I've noticed is the passenger side spring perch is about 1/2" smaller than the drivers side. My friend's LJ is the same way. It causes my passenger side spring to rub on the perch. On big bumps or quick braking stops, the spring rubs and makes an annoying clunk that resonates through the entire frame. I can find absolutely no reason Jeep engineers would design the perches like this. There is no potential of sway bar interference, no brake lines, A/C lines or anything that would get in the way of a 1/4-1/2" wider perch...guess its a "Jeep thing". Nothing I can really do to fix it either...the spring is in correctly... ![]() I'm amazed how much better the OME rides on the trail and over washboards. The Jeep keeps the wheels stuck to the ground better and the body stays level better in flexing situations.
#72 |
cool coolio
#73 | |
Nice to see your progress and great documentation. |
#74 |
LMAO i know how you feel!
AND holy CRap I thought my spring perch smaller. I just thought i got jiped lol
2004 LJ 1" JKS BL, 1" BMML, Rough country 3.25" lift with 2"puck up front 4.88 GEARS, D30 W/ AUSSIE LOCKER D44 33X1250X15 Currie Anti rock, Trail gear bumpers, Rokmen tummy tuck with Eng skid, Genright Rockers Smitty Bult XRC 10k winch
#75 |
Very nice. Looks like it's ready for regear and 33's.
How is it on the highway? I know this is a ridiculous question, but notice anything with gas mileage? Your gonna love that OME kit even more after a while. Even with 80k miles on mine, it still felt great.
Money can't buy you happiness, but it can get your butt in a Jeep, and that's a good start. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
