Quantcast Unlimited04's LJ Build - Page 16 - JeepForum.com
jeeppartsdept.com
Get your jeep parts here. Full line Jeep dealer. HUGE DISCOUNTS!
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Unlimited04's LJ Build
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineDISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-GR8TOPS Introduces the Exogate HD Tire Carrier
Old 02-01-2010, 11:48 PM   #226
Unlimited04
Unlimited04's Avatar
Originally Posted by ankyle62 View Post
posting to find this later for post #69, good info.
or you can just click the link in my sig
Originally Posted by imped4now View Post
I hope you replaced them with a certain Currie product.
$12 for 2 Clevite bushings or $160 for the Currie conversion kit....yea so considering i'm a student again...the $12 Clevites won. i'm trying to build this thing for as cheap as possible including regear labor, gears, TrueTrac, master install kit, new ball joints, new unit bearings & truss.
Unlimited04 is offline   Reply With Quote
Old 02-02-2010, 11:29 AM   #227
Imped
TITS
Imped's Avatar
I followed the same thought process....no worries.
OlllllllO
Float Test Build
IndyORV
Best served cold
Imped is offline   Reply With Quote
Old 02-02-2010, 07:16 PM   #228
Unlimited04
for those of you with a B&M trans gauge - I did some diagnostics on the temp gauge to find out wtf's going on and come to the conclusion my gauge is defective. sensor spits out a nice, consistent resistance, but the damn gauge sensor output spits out crazy voltages...and the ground wires are dead nuts solid...checked everything with the multi-meter & tested every wire individually.
called up Summit Racing, and all I can say is WOW...these guys have great freakin' customer service. They're sending a whole new kit, and covering the shipping of the defective parts. I didn't even have to give them the order number, knew the account based on caller ID.
Old 02-04-2010, 10:00 PM   #229
Unlimited04
finally a video illustrating the 42RLE suckage-
http://www.jeepforum.com/forum/f96/why-3-8l-v6-sucks-video-964113/
same problems with the JK's. this trans sucks something fierce...should have never been put in a Jeep. 4.88s with 31s maybe? very stupid gearing.
Old 02-04-2010, 10:15 PM   #230
2006_Sport
I just saw that, I thought it would be better in the JKs...apparently not.
SUPPORT THE TROOPS
2006 Jeep Wrangler|BDS|BFGoodrich|Uniden|Upol|HiLift|Cragar| Hella|Alpine|JKS|PoisonSpyder|Delta|Aussie Locker|Bluetorch Fab|Novak|Trail Gear
-Zach
2006_Sport is online now   Reply With Quote
Old 02-04-2010, 11:25 PM   #231
glockster
glockster's Avatar
The 42rle lasted 3 months with me and I traded it in for a 6 speed rubi. Probably the best decision I made last year.
Marco
Glockster's Rubihara Build
glockster is offline   Reply With Quote
Old 03-04-2010, 11:27 PM   #232
EugeneTheTJ
Homeless guy, savvy?
EugeneTheTJ's Avatar
All these people talk about the beauty of autos, yet I have never had a single issue with my NV3550
EugeneTheTJ is offline   Reply With Quote
Old 03-16-2010, 02:37 PM   #233
Unlimited04
2" OME lift update!
Now that I've put almost 12,000 miles on the 2" OME lift, I decided to check the pinion angle and see if I could get away without the t-case drop.
Before lift - 11.25" to the skid.
If you remember back to page 1, I had 15" of clearance from the ground to the bottom of the skid before the lift settled, with minor vibes. After the 1" t-case drop, it was 14" to eliminate the vibes.
After 12,000 miles on the lift, w/ the t-case drop, 13" to the bottom of the skid, with 7.5 deg pinion angle and output shaft angle...a difference of 0 degrees...perfect!
So, I decided to remove the t-case drop, getting 14" to the bottom of the skid and see if I still get vibes. 5.3 deg output shaft angle and 6.5 deg pinion angle. About a 1 deg difference...not perfect...and I do notice a slight difference smoothness. Will need more miles at different speeds to determine if the drop needs to go back in. I fear if I put the soft top on the rear is going to jump enough to make it an issue.
and 12" to the bottom of the control arm mount.
If you remember back to measurements on page 1, then the actual lift after 12,000 miles is 3" at the t-case skid, and 2.75" at the front lower control arm mount. Had alignment checked again...toe is still good and caster is still at ~5.6 degrees and thrust angle is still the same, which means it hasn't sagged at all in the last 8,000 miles.
Old 03-16-2010, 03:46 PM   #234
klimb2xs
Where did you get your digital angle finder? I am tired of fighting with the elcheapo weighted dial ones.
Black Jeep Society
Originally Posted by walldk View Post
Step away from from the vehicle and seek professional help.
klimb2xs is offline   Reply With Quote
Old 03-16-2010, 04:14 PM   #235
Unlimited04
- Harbor Freight Tools - Quality Tools at the Lowest Prices
the magnets suck. I've got a rare earth magnet i stick to it for better hold. Its still a POS chinese thing..but it does work.
Old 03-28-2010, 04:31 PM   #236
Unlimited04
Originally Posted by rubidriver View Post
You finally did it. I see you did go with the JKS track bar. It looks like you wont be having any trouble with it hitting, although you might need more bumpstop in the front. You are running a hair shy of suggested bumpstop for 33's on those springs.
well rubidriver, you were right. I need more bumpstop to fit 33s. The JKS track bar acts like a 2.5" bumpstop on one side unforunately, but flexing the other side you see I need about 1" more bumpstop for 33s, or highline fenders
JKS track bar vs Riddler diff cover:
This is 245/75R16 (30.5") stuffed in front with the bumpstops completely compressed, and drivers side shocks fully extended (23")
About 1/2" - 3/4" gap all the way around....maybe.
Time to get some hockey pucks!
Old 04-20-2010, 05:08 PM   #237
Unlimited04
4/20 update
Rubidriver will like this one
More here: Jeep TJ Air Lift Suspension Installation Write-Up.
Called up AirLift, found the part number needed for my lift after measuring the springs - #60811. Was about to order them from Summit Racing...but surprisingly enough I found the correct bags on craigslist. They're also used in WK's - guy lifted his WK and the bags didn't fit anymore. $15 A trip to the hardware store for some fittings, and a trip to a bicycle shop for a Shrader valve fitting, and I've got ~$35 into load leveling airbags in the rear. Well...and I rented some spring compressors...but that doesn't count
The manifold, with a drain plug to remove water...its not quite the lowest point in the system, but it will have to do.
Air lines follows the brake lines on the axle housing, and up the control arm.
Made a little bracket to hold the Shrader valve and connected it to the unused locker pump mount on my tummy tuck.
Now technically I have like 1/2" or so too much bumpstop according to AirLift. I decided NOT to remove the OME bumpstop extension because I'm not to sure about using these AirLift bags as bumpstops at this point.
If anything, I was thinking of hacking 1/2" off the jounce bumper.
I went for a short drive and so far I'm very pleased. At 7 psi (5 psi is minimum) it rides exactly the same, and there is no extra lift, the measurement to the t-case skid is exactly the same. At 20 psi it stiffens the springs up nicely and will be awesome when towing or hauling a heavy load. I can't wait to get em off-road now and see how flex is effected.
UPDATE: I had to modify the jounce bumpers, and reset the bumpstop length for the airbags to work properly.
See part 2 and part 3.
Old 04-20-2010, 06:28 PM   #238
rubidriver
rubidriver's Avatar
Your right, Rubidriver does like that. He would like it even more if you had used a Rancho OBA to air them up
2005 Black Rubicon - OME 933/942 - OME N66/N67 - JKS Adj Track Bars Front/Rear - JKS Quicker Discos - 285/75/16 MTZ
Originally Posted by bigj1974 View Post
your money will go farther in College Station.
rubidriver is offline   Reply With Quote
Old 04-20-2010, 10:01 PM   #239
RubiconRazorbac
RubiconRazorbac's Avatar
Nice
Post up how it does on the trail!
Originally Posted by never monday View Post
when life gives you lemons.....make a trail rig out of it.
My build thread: http://www.jeepforum.com/forum/f9/rubiconrazorbac-build-thread-792423/
RubiconRazorbac is online now   Reply With Quote
Old 04-22-2010, 08:36 PM   #240
Unlimited04
actually I think I'm going to go a different route for in-cab controller...eventually. I already have the Viair 460C with 125psi switch, but haven't gotten around to adding an airtank yet. I'll then put a 0-35 psi precision air pressure regulator in the cab, maybe under the seat, hooked directly to the 125psi tank. I'm thinking a ControlAir Type 100 or Type 850.
Type 850 spec- http://www.controlair.com/downloads/850_spec.pdf
Type 100 spec- http://www.controlair.com/downloads/100_spec.pdf
I've used the Type 100 before and it's accurate to 0.01 psi, it actually bleeds off excess pressure or feeds more pressure continuously as necessary to maintain the exact setting specified. You can mount a gauge right to them. Runs about $100. A liquid filled Wika Gauge runs about $20. Add quick disco air fittings & PE air hose and I'm done. Total cost about $125 from Fiero Fluid Power.
Glock Forum
