TJ radiator fan upgrade info.......2000-2006 TJ - JeepForum.com
 7Likes
post #1 of 659 Old 07-09-2011, 04:19 PM Thread Starter
chris142
BTW:For those that have the spin on fan clutch only. 2000 through 2006 with the 4.0L.
There are Many threads when summer comes about 4.0L TJ's that run hot at slow speeds and idling. They run hot at slow speeds because the stock 5 blade fan does not move enough air to remove heat from the radiator.
Jeep used to offer a 7 blade fan and clutch upgrade but it's gone.
I work at a Radiator and AC shop and see it often. I began to look for another fan that would cool the radiator better w/o going to an electric fan. Usually electric fans cause more trouble.
I even went to the extent of drilling a hole in my fan clutch and bolting it solid. This helped alot but the gas milage and noise was unbearable. It would still heat up if idling even with the bolted fan clutch and AC on.
I reciently had an 86 Mustang in the shop and it had an 8 blade 18inch fan on the front of it's 5.0. So I went to PicAPart to find one.
Didn't find any Mustangs.
I did find a 1993 Ford Explorer with an 18 inch 10 blade fan. I unscrewed the fan and clutch from the Explorer, paid $8 and took the fan and clutch home.
The fan and clutch screwed right onto my 02 Jeep waterpump. Took all of 7 minutes and 5 of those minutes were spent removing the coolant over flow bottle. Once it's out of the way the stock fan and clutch slides right out and the Ford parts slide back in.
So there you have it. A 10 blade fan upgrade.
You must use the ford fan and it's clutch.
A new fan is $85 from Ford. They will ask you if you want a 10 or 9 blade fan.
ORiley gets $65 for a new Hayden fan clutch.
The auto parts stores do sell a new 9 blade fan for the Explorer for about $35. It is supposed to replace the 10 blade fan. I'm betting that the 9 blade fan is still an ugrade over the Jeep 5 blade fan.
Anyway on to the pics.
Stock jeep fan vs 93 Explorer fan.
The new fan is a perfect fit!
Idling it pulls enough air to keep a towel on my grill. It's amazingly quiet too. Much quieter than the stock Jeep fan. It also removes more heat from the AC condensor so the AC blows colder at slow speeds to.
There you have it.
My contribution of the day
rscottkeen likes this.
chris142 is offline
post #2 of 659 Old 07-09-2011, 04:23 PM
JBTJ
Very nice and thank you, not that I need to, But I know what I'm doing tomorrow.
JBTJ is offline
post #3 of 659 Old 07-09-2011, 04:29 PM
cyber1satan
Very nice find, Thanks for the info!
cyber1satan is offline
post #4 of 659 Old 07-09-2011, 04:30 PM
all3forus
Great job..Thanks for the info..
all3forus is offline
post #5 of 659 Old 07-09-2011, 04:35 PM
sduncan
sduncan's Avatar
HMMMMMMMM!!!!!! Nice find!!! I'll be pasing that along to my dad....he's still having a hard time keeping his motor cool in 100+ heat.
'98 TJ, 5.7 HEMI,
sduncan is offline
post #6 of 659 Old 07-09-2011, 04:37 PM
JBTJ
After checking the major auto parts stores here in Dallas, Auto Zone, NAPA and O'Reilly all they offer is the electric fan for a 93 explorer.
JBTJ is offline
post #7 of 659 Old 07-09-2011, 04:40 PM Thread Starter
chris142
Doorman part # 620-112.
Go to Azones site. Put in 93 explorer then fan blade.
chris142 is offline
post #8 of 659 Old 07-09-2011, 04:43 PM
JBTJ
Originally Posted by chris142 View Post
Okay my bad, found the fan but which clutch? They show for both transmissions, heavy duty and non.
JBTJ is offline
post #9 of 659 Old 07-09-2011, 04:43 PM Thread Starter
chris142
Dorman/Fan Blade
For your 1993 Ford Truck Explorer 2WD 4.0L MFI 6cyl
Price:$25.99
Part Number: 620-112
AVAILABILITY:STORE PICK UP AVAILABLENormally stocked at your local store.SHIP TO HOMEAVAILABLEShips within 2 business days.
chris142 is offline
post #10 of 659 Old 07-09-2011, 04:44 PM Thread Starter
chris142
Only show one clutch here.
Torqflo/Fan ClutchPrice:$59.99
Part Number: 922793
chris142 is offline
post #11 of 659 Old 07-09-2011, 04:47 PM
JBTJ
Part Number: 922793
Thanks a bunch, really. Was looking at O'reilly parts.
JBTJ is offline
post #12 of 659 Old 07-09-2011, 04:50 PM Thread Starter
chris142
The Hayden # that ORiley sold me was# 2793
chris142 is offline
post #13 of 659 Old 07-09-2011, 04:51 PM
JBTJ
Standing in front does that big nut to remove the clutch turn right or left?
JBTJ is offline
post #14 of 659 Old 07-09-2011, 04:52 PM Thread Starter
chris142
Regular right hand thread. Counter clockwise to remove if your standing at the front of the jeep.
chris142 is offline
post #15 of 659 Old 07-09-2011, 04:54 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
well crap, i just ordered a new fan clutch.
i'll get one of these next time i'm at the junkyard and see what happens.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
10 blade , 5 blade , 9 blade , cooling , explorer , fan blade , Fan clutch , ford , upgrade
NP231 from a 2000 TJ fit a 2006 LJ? NavinRJohnson TJ Wrangler Technical Forum 1 10-29-2009 11:40 AM
OEM fog lights for TJ 2000 in TJ 2006 maimo TJ Wrangler Technical Forum 7 03-28-2007 03:14 PM
Lug diameter 2000 vs 2006 bruker TJ Wrangler Technical Forum 2 11-28-2006 02:02 PM
Any info about 2006 Willys Edition?? Caesars0331 TJ Wrangler Technical Forum 4 09-10-2005 08:40 AM
2006 Wrangler Info SpitNine TJ Wrangler Technical Forum 3 08-04-2004 08:50 PM
