#106 | |
mudb8, any idea wtf that piece is? I'm taking this POS trans in tomorrow to be fixed/rebuilt/replaced.
Useful Write-Ups: SEARCH TUTORIAL TJ Tech BOOT CAMP-A Must Read! FAQ: Cold Air Intakes & K&N's Off-Road Tips and Techniques What is a CV shaft and why do I want one? So you want a Tummy Tuck? Tire size, lift height, bumpstops & shock guide DIY Shock Shifters for Long Travel Shocks Lug nuts and bolt patterns Catalytic Converters Busted TJ Track Bar Bolt Fix Brake Knuckle Divot/Groove Repair Coconut Oil for Drilling and Machining Fabrication & Build: My Build Thread Funny: Will it fit in my Jeep? |
#107 |
want it rite or rite now?
yep, yer right, it does look like a snap ring, I haven't seen on break tho... I was expecting to see part of a sprag..
it could also be a thrust ring from the convertor... guess I stuck my foot in my mouth on that one!
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable HighLine Hood Jeepers TJ Adjustable Track bars DIY highline fenders.... 34-37's under 0"-2.5" lifts shock length, bumpstop extension, tire size chart click here DIY shock shifters, more uptravel/better ride 2011 E-350 4x4 Van conversion 2006 Rubicon Unlimited ASE Certified Master Tech/Fabricator In need of work... 11/2/11 |
#108 | |
I would like to change shift points to get my overdrive to stop engaging at freakin 45 mph
SUPPORT THE TROOPS 2006 Jeep Wrangler|BDS|BFGoodrich|Uniden|Upol|HiLift|Cragar| Hella|Alpine|JKS|PoisonSpyder|Delta|Aussie Locker|Bluetorch Fab|Novak|Trail Gear -Zach
#109 | |
. They had my Jeep all day today, but theres only one trans guy and they're backed up of course. Why do they want you to bring it in, then don't even look at it for a few days? Yet another reason I'm pissed at Chrysler at the moment. My trans is crap @ 55k, even tho its been well cared for, and the good dealership is closed but the 'we-screw-you-over' dealership is now the only place to take a Jeep for warranty work. Isn't Toyota going to make an FJ Cruiser convertible Wrangler copy soon? Maybe a long wheelbase version, with a TRD supercharger package so I could actually climb I-70 at a reasonable speed?
#110 | |
I've gotten mine to where it won't shift out of 3rd till over 60mph unless I let off the gas... normal driving for me includes long grades and a couple that are over 6% tho.
#111 | |
That's how things work out these days. Good dealerships close but the ****ty ones stay open. It happened around here too. Good luck with the tranny work. I will be followin the thread to see whats goin on.
#112 |
The saga continues.....
So that piece of a snap ring was only a small piece of what was broken. The rest of that snap ring was floating around inside the trans someplace, they couldn't even find all of it. The clutches attached to that snap ring were toast. Needs a new torque converter and a new pump, and obviously new clutches and whatever else lives in a transmission. Looks like they'll be rebuilding my trans as its under the 70% rule. To be fair, the dealership has been good. Looks like I'll be installing the trans cooler I've got sitting in my living room for an extra measure of durability once I get the Jeep back. This puzzles me because I've never neutral dropped, never power surged it in anyway, never overheated, never abused and I have always changed the fluid regularly. Heck, I never felt the clutches slip and it was shifting perfect (for a 42RLE) when I took it in. Thank goodness I bought the 7/70 powertrain warranty...it has at least paid for itself. Maybe its just bad Chrysler engineering/assembly/manufacturing?
#113 | |
#114 | |
Since they'll be basically rebuilding my tranny, I was thinking of having them install the TransGo shift kit while everything is apart. I don't want to void my warranty tho, so I'm not sure how all that will pan out. So I've been bored...and decided to make some stuff for my Jeep for use when its back on the road. Another roll bar clamp, aluminum this time, will hold my 75WXST CB: ![]() Not done yet. ID is done, thickness is done - just need to face the OD, drill and tap it, then cut it in half. The last clamp was mild steel and for a GPS Mount. Both were machined with Coconut Oil as the cutting oil ![]() And a new third brake light with 2 CB antenna mounts - ![]() Need to touch up a bit with a flap disc, then prime/paint and its done ![]() Welds: ![]()
Useful Write-Ups: SEARCH TUTORIAL TJ Tech BOOT CAMP-A Must Read! FAQ: Cold Air Intakes & K&N's Off-Road Tips and Techniques What is a CV shaft and why do I want one? So you want a Tummy Tuck? Tire size, lift height, bumpstops & shock guide DIY Shock Shifters for Long Travel Shocks Lug nuts and bolt patterns Catalytic Converters Busted TJ Track Bar Bolt Fix Brake Knuckle Divot/Groove Repair Coconut Oil for Drilling and Machining Fabrication & Build: My Build Thread Funny: Will it fit in my Jeep? Last edited by Unlimited04; 07-10-2009 at 09:09 PM.. |
#115 |
I'm gonna second it being one of the assembly line workers having a bad day, I'm still surprised it went kaput on you so early. Are they still going to reset it to the virgin state with the StarScan for you?
Nice job on the addition to your tire carrier and CB mount. Must be nice to have access to all of this fun fabrication stuff.
2005 LJ- Mostly stock/ DD 2000 TJ- Slowly Rebuilding 1976 CJ7- 304/TH400 | 3" suspension | Warn 9.5ti | |
#116 |
stealership still doesnt have all the parts to rebuild the trans....
but i finished a roll bar clamp for my CB: ![]() ![]() was going to paint it, but haven't decided - the sandblasted finish does look nice. Finished: ![]()
Useful Write-Ups: SEARCH TUTORIAL TJ Tech BOOT CAMP-A Must Read! FAQ: Cold Air Intakes & K&N's Off-Road Tips and Techniques What is a CV shaft and why do I want one? So you want a Tummy Tuck? Tire size, lift height, bumpstops & shock guide DIY Shock Shifters for Long Travel Shocks Lug nuts and bolt patterns Catalytic Converters Busted TJ Track Bar Bolt Fix Brake Knuckle Divot/Groove Repair Coconut Oil for Drilling and Machining Fabrication & Build: My Build Thread Funny: Will it fit in my Jeep? Last edited by Unlimited04; 11-12-2009 at 10:45 AM.. |
#117 |
holy crap.... all that for a CB mic!
this is what I use, they don't fall out and never hit the floor..... one can be found in every truck stop on the planet.. http://gearkeeper.com/communication/cbmickeeper.html nice job BTW!
#118 | |
I wish I had the machinery needed to fab up parts like that.Great LJ so far. |
#119 | |
![]() ![]() mudb8, thats a neat CB mic thing, but i'd still need a roll bar clamp to hang it from ![]() ![]()
#120 |
tranny is still f'ed. they can't seem to get it together right and it was spewing fluid everywhere with their last attempt. they took it all apart AGAIN to find the blown seal and hopefully will have it back to me tomorrow, assuming the re-assembly goes ok.
After all the latest rocker discussion threads, I finally made a rocker decision - get some Rokmen sliders with internal braces. Shameless plug - Selling my stock Ravine wheels and a set of Garvin frame mounted rockers if anyone is interested. I found a cheap set of slightly used Rokmen rockers with everything - mounting hardware, internal reinforcements with rocker gaskets - got it all for less than half the cost of new. I'll need to sand them down a bit - there is some rust and the previous owners paint job wasn't very good. I'm getting some powder coat estimates - what should a reasonable cost of powder coating be? The one estimate I've got back so far is almost twice what I paid for the rockers!
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
