Unlimited04's LJ Build - Page 34 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Unlimited04's LJ Build
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineWIN a Rough Country Forged Track Bar - ExtremeTerrain!1987-2016 Wrangler Jammock Black 2.0 Jeep Hammock (YJ, TJ
Unread 10-20-2012, 11:03 AM   #496
-sean-
1944 CJ2
....behind a supercharged 4.7L stroker
how's your jeep coming along? do you need help flinging parts?
Just waiting on parts from Gerald (Savvy).
When I start wrenching I will give you a call, it's always nice to have an extra set of hands on standby.
L-TJ
-sean- is offline   Reply With Quote Quick reply to this message
Unread 10-20-2012, 11:10 AM   #497
RubiconRazorbac
RubiconRazorbac's Avatar
Originally Posted by Unlimited04
We saw four cow moose, one bull moose, one nice bull elk and one small buck mule deer. For as large an area as we covered, that's absolutely horrible. It was almost like a spaceship landed and sucked all the wildlife up.
Aaaaaand which one is now in the freezer?
Your shaft isn't long enough to handle that kind of droop...
My build thread: http://www.jeepforum.com/forum/f9/ru...thread-792423/
RubiconRazorbac is offline   Reply With Quote Quick reply to this message
Unread 10-20-2012, 11:33 AM   #498
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
I've got two sets of springs compressors, so we can make quick work of the suspension
none of them, unfortunately
there's always next year....
Unlimited04 is offline   Reply With Quote Quick reply to this message
Unread 11-04-2012, 05:13 PM   #499
Unlimited04
making some shock relocation mount for the front, to run N66L for 4" lift, on 2" of lift, with only 1.375" bumpstop extension (2" normally required).
Cut two pieces of 1"x2"x3/16" C-channel. Set the shocks on top of them, and marked an outline with a sharpie.
Used a bench top drill press to drill four holes, then cut the center out with a jig saw.
Repeatedly test fit the shocks, and nibbled the rest of the material out using a dremel, die-grinder with cutting wheel, and a file.
Once the shock fit well, I marked the locations of the bolt holes and drilled a pilot hole, then a 5/16" hole for the shock bolts.
The plan is to cut the stock shock mount off, and reinforce the remaining hole in the spring bucket with some plate.
Then mount the new fabricated shock mount about 1" lower than the stock mounting plane, against the lower control arm mount.
Also fabricated rear relocation mounts out of a scrap piece of 2x5x3/16". Will be running N67L shocks for 4" lift, on 2" of lift, with ~1.5" bumpstop extension (2.5" normally required).
Here's the reasoning behind the change:
Current front shock length:
N66: 9" travel, 13.2" compressed length (14.2" with 1" extension), ~5" uptravel / ~4" downtravel
New front shock length, with relocated mount:
N66L: 11" travel, 15.5" compressed length, ~5" uptravel / ~6" downtravel
downtravel gain: ~2"
Current rear shock length:
N67: 8.8" travel, 13.3" compressed length, ~5" uptravel / ~4" downtravel
New rear shock length, with relocated mount:
N66L: 10" travel, 14.5" compressed length, ~5" uptravel / ~5" downtravel
downtravel gain: ~1"
Going for something like this:
from CB3's build done by mudb8: Yellow, Red, Long and Soft....
More to come later....
Unread 11-05-2012, 12:29 PM   #500
bobthetj03
Bob's boring build:
http://www.jeepforum.com/forum/f22/b...build-1304260/
White Jeep club member #2003
www.norcal-jeeps.com
bobthetj03 is offline   Reply With Quote Quick reply to this message
Unread 11-24-2012, 01:54 PM   #501
AngryTJ
just came across your build..subbed for a future read
[SIZE="5"][COLOR="Blue"]Follow me on Instagram @ Tarantula_TJ[/COLOR][/SIZE]
[URL="http://www.jeepforum.com/forum/f22/angrytjs-97tj-05-rubicon-build-1271051//"][SIZE="4"][B]
Tarantula_TJ Build[/B][/SIZE][/URL]
AngryTJ is offline   Reply With Quote Quick reply to this message
Unread 11-24-2012, 04:15 PM   #502
MattJeep
2003 WJ
Finished an week long expedition/hunting trip with the trailer. It carried a wall tent, wood burning stove and plenty of camping gear roughly 600 miles With a full load, going up a pass kills the power bad...damn 42RLE...since I don't want to bounce the motor off the rev limiter, the top speed is about 40mph or less at times.
Sounds like my trip to Colorado in my Jeep. We were fully loaded plus a cargo carrier with some stuff. Once we hit that initial climb right outside Denver I basically had to fly over to the right lane. I knew it would struggle somewhat in the mountains but man. TJ definitely struggled from that point on in all mountain grades/passes. Getting my new axles in will help for sure since they have 4.10's compared to my stock 3.55 with 285's. But its had me seriously thinking about a V8 swap over the winter before we return next summer. Its just too hard on the 4.0, sometimes i was holding 3500 rpm for several minutes.
MattJeep is offline   Reply With Quote Quick reply to this message
Unread 11-24-2012, 08:54 PM   #503
Yucca-man
The transmission and gearing make a huge difference as well as the transmission choice - both with stock 3.55 gears and 30s, as well as with 4.56 and 33x10.50, my '96 XJ could fly up I-70 west of Denver. The transmission was an AW-4 in that. With 31s and 3.73s in the LJ, I might be able to stay out of the right lane if the downshift gods are kind...but it's rare.
Yucca-man is offline   Reply With Quote Quick reply to this message
Unread 11-24-2012, 10:58 PM   #504
MattJeep
2003 WJ
Well I plan on getting the 8.8 and 30 with the 4.10's in over the winter. Hopefully that alone makes a nice difference. With your experience with the trailer, do you think its easier on the Jeep pulling the same weight with the trailer or loading everything inside the jeep and on a cargo carrier? Trying to figure out if the trailer will be beneficial.
Unread 11-25-2012, 09:26 AM   #505
Unlimited04
the trailer doesn't help aerodynamics or maneuverability at all. no matter what, a trailer always makes driving more of a pain in the butt than no trailer...another thing you have to watch, look over/around, backing up, tight turns, parking, etc.
just for that reason alone, I'm not towing my trailer unless I need the extra space.
As for a cargo carrier, I'd rather have a trailer. I'm not into loading heavy crap on top of my Jeep. i do have a hitch mounted carrier for a little bit of overflow, like firewood or a fish cooler...I built it raised for off-road use. it is described in this thread. I have only used it once or twice.
btw, with 33s, 4.10s will be better than 3.55s....but ideally, you want 4.56s with your particular transmission, not 4.10s.
Unread 11-25-2012, 08:09 PM   #506
MattJeep
2003 WJ
Ok thanks for the advice. I agree about the pita with backing up, turning around, etc. Maybe i'll stick with the cargo carrier for now.
As for the gear ratios, your probably right but I'm not spending $1500-2000 on regearing. This was the cheap way to gear down and gain strength in the rear.
Unread 02-12-2013, 01:15 AM   #507
Zetto
Zetto's Avatar
Kinda what I was thinking.
Exhaust updates.
Front pre-cat - still good
Rear pre-cat - notice the honeycomb has broken loose - this is why I got the CEL & P0432, and the engine compartment got so hot - half the passageway was blocked with that honeycomb turned sideways & just floating around in there.
From my research this is a common problem with the late model TJ/LJ and some owners our on their 2nd or 3rd replacement. I just dealt with the same issue except I was receiving P0431. Fortunately I was still covered under the 8 year/80K Federal Emissions Warranty and the local dealership took care of it. They completely overlooked the Savvy Modular Under Armour and other mods which was nice.
Now that I am in Colorado you need to show me where to wheel .
Savvy inspired LJ
06 Silver LJ
Savvy 4" lift with aluminum CA -- Currie AntiRock (Front) -- Currie F/R Trackbars -- Savvy Modular Under Armor
BF Goodrich T/A KO 285/75/16 on 16" Moab powdercoated black -- Vanco 16" big brake kit
JeeperMan swing-away tire carrier with tub extensions (JSPUex)
Four X Doctor Rocker Guards
Hella E-Code Housings -- ARB H4 Headlight Harness (M002) -- KC 130 watt SlimLite mounted on windshield
Zetto is offline   Reply With Quote Quick reply to this message
Unread 02-19-2013, 11:31 AM   #508
Unlimited04
wow, i haven't checked this in a long time...
yea, the difference between the drive-ability of the AW4 vs the 42RLE is pretty crazy. my friend's old XJ used to kick my arse on I-70...even though I'm geared better.
sure. watch the Colorado section too. I'll try to shoot you a PM when a few of us are going to do hit the trails this summer. Most stuff won't be open till June/July timeframe, depending how much snow we end up with in the mountains. The wildfires may be bad this year too...
anyway...been too busy with work, snowboarding & other stuff to do more work on the shock mounts.
My alternator decided to give out. Installed a reman Duralast 160A Durango alternator. I still need to upgrade the wiring to the battery.
Making some slow progress on the trailer lid:
Unread 02-19-2013, 01:37 PM   #509
Zetto
Zetto's Avatar
Are the trails actually off limits in the winter or do you just avoid snow wheeling (I am not sure I can wait that long )?
I would love to check out your rig sometime and see how the transmission cooler is setup. I have a Derale direct fit transmission kit I picked up on clearance but do not like how it mounts behind the transfer case on the frame rail. I am debating selling it and just mounting a generic cooler in front of the radiator.
Savvy inspired LJ
06 Silver LJ
Unread 02-19-2013, 02:18 PM   #510
freeskier93
Some trails have gates, some don't. Personally snow wheeling doesn't appeal to me, that's assuming I even have time to go wheeling during the school year...
I'll leave the snow for skiing and summer sun for top and doors off wheeling.
CU Boulder Aerospace Engineering
freeskier93 is offline   Reply With Quote Quick reply to this message
