tj front adjustable track bars for 0-3.5", does yours hit or fit?
| Official Chassis Saver Rust Preventive Truck & Auto Un | TJ 5.25" Speaker Adapters - NalinMFG | SALE -- Yukon Gear Free Spin Hub Conversion Kit - Dana 30 |
#1 | |
want it rite or rite now?
post you're front track bar specific pics and comments... what hits and what fits 0-3.5" lifts along with broken and bent ones. I'm interested in track bar and differential contact/failure.
we hear claims of jks, rusty's and other hitting and breaking. I want to attempt to point out why and which ones have little to no issues. I'll put all the info together in a few days that weeds out the BS. like opinions on strength... we"ll show it. mother's day EDIT... broken and bent TRE and hiem shafts seem to be/are from clearance issues with the differential cover... several pics in this thread. still gathering info .. bent bars are from abuse, I run and hide here.. kinda like this pic of the thin re1600 and a solid rock krawler bar, which is also similar to rough country's new adjustable, Clayton, and iron rock off road... ![]() there is a definite shape difference... here's a teraflex adjustable over a stock track bar.. ![]() I can start off with my 2.5" suspension, nth degree/aev hd solid adjustable w/frame brace. with my 16" lower arms and 15 1/2" upper control arms it'll hit the diff cover bolts on the brace and the wj bar just barely touches the cover. it requires 2" bump stops to keep it clear and problem free. nth with stock wj track bar.. ![]() nth with jks wj adjustable has a considerable amount more room from the cover. ![]() this means you to rubidriver.. snap some good side views of the jks what I figure might be a solution and alternative to the adjustable is a weld/bolt on drop bracket like Clayton's having a thick pad drilled with a tapered hole that'll potentially center the axles of 2-3" lifts with the stock track bar and be used for adjustable that are known to have rubbing issues with tre's and jj's. ![]() the currie HD offset IMO is the best (I should say easiest) option at this time for a front adjustable track bar... ![]() ![]() ![]() not yer usual thin bar here.... ![]() ![]()
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable HighLine Hood Jeepers TJ Adjustable Track bars DIY highline fenders.... 34-37's under 0"-2.5" lifts shock length, bumpstop extension, tire size chart click here DIY shock shifters, more uptravel/better ride 2011 E-350 4x4 Van conversion 2006 Rubicon Unlimited ASE Certified Master Tech/Fabricator In need of work... 11/2/11 Last edited by mudb8; 08-09-2009 at 12:07 AM.. |
#2 |
Demonic Jeep Freak!
No pics but, I've had Black Diamond and RC and never had any problems.
#3 |
what lift height?
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable HighLine Hood Jeepers TJ Adjustable Track bars DIY highline fenders.... 34-37's under 0"-2.5" lifts shock length, bumpstop extension, tire size chart click here DIY shock shifters, more uptravel/better ride 2011 E-350 4x4 Van conversion 2006 Rubicon Unlimited ASE Certified Master Tech/Fabricator In need of work... 11/2/11 |
#4 |
I have the Rusty's that just arrived yesterday... sitting in the box...waiting to shipped back.
Unless someone can reassure me that installing this will be better than just relocating my stock track bar.
____ (OlllllO) 65th Anniversary Edition TJ Jeep Green Rough Country 3.25" Suspension Lift JKS 1.25" Body Lift & 1" Budget Motor Mount Lift 33x12.50/15 BFG All-Terrain's on 15x8 ProComp Series 51 w/ 3.75" BS
#5 |
I have a Rusty's with the TRE frame mount. I have a 4" RC lift, no clearance issues, however I don't have discos yet. Once I disconnect it might hit. It has been installed for about 2 years and around 5k miles. I had a D30 which give me a little more room over the D44. After all this talk I debating about getting something better. I will be very interested once you compile the info.
Black Jeep Society Member |
#6 |
My Full Traction didn't hit with ~3" of lift but I snapped it. I will find out next week if the JKS one works.
04 TJ - 2 KC Daylighters, 35x12.5x15 MT/R Kevlar, 3" coils, Rear 4 link, 1.25" JKS BL, 1" JKS BMML, 33 Eng. Hi-Clearance Skid, 8.8 with LS, D30 EZ locker, OBA |
#7 |
My RE 3.5" kit works just fine.
#8 |
i have the clayton setup... i have no issues
#9 |
Demonic Jeep Freak!
#10 |
I just installed Rusty's Adjustable trackbar and it hits the diff cover just enough to scape the oily residue off. I'll try to post some pictures later. I may return it depending on your investigation. Thanks for keeping this topic alive, someones life may depend on it.
#11 |
What's weird is I have NEVER heard of this issue until a few days ago!
I can't believe it isn't a major topic of conversation when discussion lift kits, etc...
#12 |
i have a problem with mine.the 2'' bumpstops are too much imo.as far as front lca go i have the re fixed ones and cam bolts that have taken the lca all the way back to the end of their adjustment.
http://www.jeepforum.com/forum/f9/jks-adj-trackbar-hitting-dana-30-diff-cover-700145/ |
#13 |
I bought a rubicon express because of the known issue between JKS and the D44 cover. Unfortunately the RE has the same issue....
I run an OME HD spring, 3/4" spacer, and have 2 hockey pucks per side for bump stop extensions. To make this discussion more valuable, I think it would help if people skip their lift height, and describe: Bump Stop Extension LengthEdit: I'll add that the contact on my diff cover is VERY suttle, only slightly affecting the paint. Obviously there is some bind and distortion at full compression if there is contact which isn't good, but its not much. I haven't taken any action yet because I was hoping to find a welded style aftermarket diff cover which will actually increase clearance, no idea if one actually exists and haven't had a chance to look into it more. -Brent
- 06 LJ Rubicon 34" LTB's / 33" MTZs, OME Springs/Shocks, RE FTB, JKS RTB & 1.25BL, Brown Dog MML, Fabtech F Bump, Warn M8000 on AtoZ plate, ORF R Bumper & Rack, AR CAI, Banks Catback, Hi-Lift, Midland 75-822, Dual MF1050 Comp, Clayton Skids, Kilby Gas Skid - 94 Firebird Formula, 02 Softail Deuce, 86 GSXR750 - RIP 97 TJ, 83 CJ7, 87 TType Last edited by MEnginerd; 03-26-2009 at 05:35 PM.. |
#14 | |
This is not something you want to experiment with my friends. If it snaps, you LOSE your steering. You can hold on at low speeds, but if it snaps at higher speed on a little road dip like mine, you will need both sides of the road to stop...thats IF you don't roll first. I tried to post the pic but it wont work. I just get the red x. Just look at the other threads on the Rusty's stuff and track bar.
2008 Black Rubicon Unlimited, fully loaded, Auto AEV Premium Lift with High Steer 35x12.5/R17 Goodyear MTR Tires AEV Argent Pintlers AEV front bumper with Superwinch EPI9000 Last edited by SB99TJ; 03-26-2009 at 05:50 PM.. Reason: working on resizing pic |
#15 |
I have a BDS front adjustable, 2" BDS Spring lift, stock control arms, and stock bump stops. I have no rubbing issues at full coil bind.
'99 Jeep TJ Sport 4.0 Kilby Steering Skid, Skid Row Engine Skid JKS Quicker Disconnects, 1" PA Body Lift, 2" BDS Spring Lift 33" BFG KM2's on AR Baja Wheels ><> Ryan |
| Tags |
| tj, track bar |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
