TJ radiator fan upgrade info.......2000-2006 TJ - Page 31 - JeepForum.com
 7Likes
post #451 of 659 Old 08-17-2011, 12:40 AM
47MTP
MML = Motor Mount Lift? Sorry, I see the term thrown around a lot on this thread....I did an advanced search on MML and got no hits![/QUOTE]
That's correct. Jeepers have almost as many acronyms as the military.
Bert
47MTP is offline
post #452 of 659 Old 08-17-2011, 11:32 PM
Best4x4
Yep MML = Motor Mount Lift.
05 Electric Lime Green LJ with a 4spd Auto, 2.5inch Suspension Lift, OME Shocks, OME Steering Stabilizer, 32inch BFG M/T's on 17inch Moab's using Spidertrax Spacers, UCF Aluminum TC Skid, Novak Cable Shifter, Brown Dog MML, Rokmen 1/2 BL, Banks CAI, Diehard Platinum Marine Battery, JW Speaker 8700 LED Head Lights, Safari Nets, G.E.A.R Overhead Console/G.E.A.R Tailgate Storage, Rugged Ridge XHD Front Bumper, Warn Gas Tank Skid, Mopar Rock Crawler Rear Bumper, Warn XD9000i Winch with Warn Wireless Remote, and a Uniden 880 CB Radio
Best4x4 is offline
post #453 of 659 Old 08-20-2011, 09:32 PM
HappyPancake!
FYI. OK So I bought a 9 blade and a motor craft clutch when this thread first started. Don't know why as I never had any overheating problems. Today I " locked" my fan with painters tape and let the temp of the thermostat housing (used an IR gun) go up to 235F then released then fan. The fan did not rip the tape at 235F. I cut the tape and the clutch engaged with the IR gun reading 207F within a few minutes. Again, just an FYI. My radiator is new. I'lI hold on to my purchase for the future.
HappyPancake! is offline
post #454 of 659 Old 08-22-2011, 08:24 PM
Bills03tj
1992 XJ Cherokee
I did this mod and had to put the stock fan back on. I was wheelin' yesterday and my Jeep's temp's got into the red twice. It never did that with the stock fan.
Bills03tj is offline
post #455 of 659 Old 08-22-2011, 08:27 PM Thread Starter
chris142
Did you hear the new fan roar when it got hot? Maybe you got a bad but new fan clutch?
Mines been doing great in the SoCal desert with the AC on.
chris142 is offline
post #456 of 659 Old 08-22-2011, 08:40 PM
Bills03tj
1992 XJ Cherokee
Yes, so long as the rev's were up it would keep it cool. But a crawling speeds it ran hot. Put the stocker back on today and running around town and stopped at red lights it stayed below 210. With the Ford fan it would get a little above 210 and that's with the heavy duty clutch.
post #457 of 659 Old 08-22-2011, 08:49 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
Update on my findings:
I picked up an aftermarket Explorer 9-blade fan (VDO brand, price matched to $20 after Checker's couldn't get the Dorman for weeks). It does fit way better in the shroud than the Ford 10-blade - pretty much perfect. The 9-blade seems to work better than the 10-blade, but haven't had it on long enough to make a firm determination between the two. The Ford 10-blade didn't seem to cool as good as the stocker at idle, but it did better above 1500rpms, and it certainly sucks far more power out of the engine. Still looking into the 9-blade to see if it has a different response.
Now this Hayden 2973 is starting to cause squeeling on the belt when fully locked up. Starting about 3000rpms, but is very faint and I can't hear it unless driving next to a K-rail on the highway...but at 3800-4000rpms or so, the squeel gets really loud like it did before with the Torquflo clutch & stock 5-blade. Maybe its the tensioner, but I still think its this damn Gates belt. With the new belt, it was great for about 1500 miles, but now its turning out just like the old one as it breaks in....
One interesting thing I noticed was the VDO 9-blade appeared to have two bolt patterns on it...one for the Explorer clutch and one for the Jeep/Chrysler clutch.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #458 of 659 Old 08-23-2011, 07:14 AM
TheSlowDown
I've noticed at least a few people on here stating that the temps are too hot with this setup (or similar setup with different blade count fan).
Do you think it's possible that these fans are designed to work more efficiently at higher RPMs due to the normal projected use of the original vehicle the fan was designed for?
Perhaps similar to boat propellers where you have to decide what your intended use is: high-speed short distance has a much different design than low-speed crossing/transit for example.
Anyone with experience driving a late model Ford Exploder? I would imagine it spends little time at lower RPMs, at least compared to a Jeep Wrangler.
TheSlowDown is offline
post #459 of 659 Old 08-23-2011, 10:17 AM
ftgiles
Fan RPMs vs. Engine RPMs based on Pulley Ratio differences
ftgiles is online now
post #460 of 659 Old 08-23-2011, 10:39 AM
freeskier93
I don't know exact ratios, but the water pump/fan pulley is smaller than the crank, therefore the fan should be spinning faster than the engine.
On the jeep anyways, but I suspect it's that way with every vehicle. Maybe if someone can measure the pulleys of both the jeep and ford.
freeskier93 is offline
post #461 of 659 Old 08-23-2011, 12:25 PM
Brazos609
What's your take on trying to upgrade the mechanical fan vs using the 03-06 TJ 2.4L electric fan assembly?
Brazos609 is offline
post #462 of 659 Old 08-23-2011, 10:50 PM
Best4x4
Yeah Unlimited04 I tried a 10 blade fan I got for 23.00 brand new and that thing fit HORRIBLE vs the 9 blade Dorman unit.
My findings are that the Torq Flo and the 9 blade cool the best, but it does drag the motor down at slow speeds and the belt will squeal at 3500 + RPM's. The Hayden 2793 and 9 blade cool better than my OEM setup, and it doesn't drag the motor down at slower speeds like the Torq Flo or squeal the belt. I was going to slap the 10 blade fan on the Torq Flo clutch to see if it would maybe stop it from squealing, but it fit so bad on the Hayden 2793 that I didn't even bother testing that combo.
Best4x4 is offline
post #463 of 659 Old 08-23-2011, 11:51 PM
c69ss396
Just me...
c69ss396's Avatar
I went with a early 2000 explorer fan 14 blade, It helped alittle at idle but overall it wasn't worth the swap.
c69ss396 is offline
post #464 of 659 Old 08-24-2011, 02:04 AM
Best4x4
I think any fan after 10 blade is overkill and the fan isn't going to spin fast enough to draw enough airflow through the radiator. The 10 blade sat way to far back and wasn't in the shroud far enough. My OEM setup with a MML was better than the 10 blade, but the 9 blade sits perfect and that's why I think I'm getting the better cooling from a 9 blade vs the 10.
Best4x4 is offline
post #465 of 659 Old 08-26-2011, 04:56 PM
chmo
UPDATE:
with 2793 Hayden severe duty clutch and Dorman 9 blade fan in hot (>110*F) and humid UAE climate:
- idling with AC on is leading to > 230*F and rising if left alone
- from 1500 rpm and up the clutch fan combo is delivering better results than the stock setup ... temp stays below 211*F ... fluctuating between 206 and 211
- I have no noticeable additional drag on the engine
- no belt squeal above 3500 rpms ... YET? (stock belt!)
- no roaring noise ... even with higher rpms and hot engine
so Unlimited04's results are repeatable! (I had my fan clutch combo already ordered and on the way when he published his results ... so I had to redo the experiment as well )
and to some extent (noise and drag) Best4x4's results as well!
The next optimization worth looking at:
smaller pulley ? (here I need support ... ... where to get the pulley from? do I need a shorter belt? )
because I actually like the combo ... if only the idle weakness can be eliminated!
btw : I noticed the 9 blade fan is NOT blowing the air backwards to the engine and over the AC lines (I read s.th. about here somewhere??) ... the air is blown radially from the "perimeter of the circle" ... NORMAL?
"The more I know, the more I realize how much I don't know"
chmo is offline
10 blade , 5 blade , 9 blade , cooling , explorer , fan blade , Fan clutch , ford , upgrade
NP231 from a 2000 TJ fit a 2006 LJ? NavinRJohnson TJ Wrangler Technical Forum 1 10-29-2009 12:40 PM
OEM fog lights for TJ 2000 in TJ 2006 maimo TJ Wrangler Technical Forum 7 03-28-2007 04:14 PM
Lug diameter 2000 vs 2006 bruker TJ Wrangler Technical Forum 2 11-28-2006 03:02 PM
Any info about 2006 Willys Edition?? Caesars0331 TJ Wrangler Technical Forum 4 09-10-2005 09:40 AM
2006 Wrangler Info SpitNine TJ Wrangler Technical Forum 3 08-04-2004 09:50 PM
