Unlimited04's LJ Build - Page 37 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Unlimited04's LJ Build
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 07-25-2013, 08:46 AM   #541
mike_dippert
hodophobic
mike_dippert's Avatar
Ever consider connecting the two breathers together with a T fitting, and feed them both to the manifold?
mike_dippert is offline   Reply With Quote Quick reply to this message
Unread 07-25-2013, 08:53 AM   #542
Boundless
Thanks
__________________________________________
Rusty
Satellite Bch, FL
2005 Jeep Wrangler Unlimited (LJ) 6cyl, 4spd auto, dana 30/44 3.73, rear trac-loc, hard top, BFG KM2 35/12.5 x 15 on rattle can black stock Ravine wheels & 1.5" spacers, trimmed flares, budget PA 1" BL & RC 1" MML, Ford Explorer roof rack, Hella e-code headlight housings, 55 watt DDM HID Hi/Lo 6000k, EBC Yellow Stuff front brake pads, Platinum P4 battery, Rusty's 3" 305s front and 303s rear springs, RC rear track bar bracket and Hella 500FFs with DDM's 55watt 6000k H3 HIDs on windshield hinge brackets. Currie's front upper and lower control arms. Hummm whats next? Building a Dana HP30 with 4.88 and ? locker
http://www.canddautocenter.com/
Boundless is offline   Reply With Quote Quick reply to this message
Unread 07-25-2013, 09:27 AM   #543
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
Originally Posted by rdock31 View Post
What's do you have planned for the next stage of the build? Or is this set for a while.
see 1st post.
you could do that, but it won't solve the blow-by oil+air issues, you'd still need to the oil/air separation capability of a catch can.
some people drain the oil out of the bottom and inspect it, but really all you need to do is drain it back to the engine.
Unlimited04 is offline   Reply With Quote Quick reply to this message
Unread 07-25-2013, 02:48 PM   #544
taterhed
I'm gonna second the earlier question; didn't see an answer:
Is the electric horn loud enough to satisfy my need for a train horn? (without the need for compressor and tank).
thanks
taterhed is offline   Reply With Quote Quick reply to this message
Unread 07-25-2013, 09:43 PM   #545
MWV247
Not comparable. An air horn will demolish an electric horn. But they are all a lot of fun
MWV247 is offline   Reply With Quote Quick reply to this message
Unread 08-03-2013, 01:24 PM   #546
Unlimited04
Roof Top Tent is mounted! new cover too, old one was trashed.
Unread 08-03-2013, 01:38 PM   #547
-sean-
1944 CJ2
Looking good
So how went the trip up to Wheeler?
L-TJ
-sean- is offline   Reply With Quote Quick reply to this message
Unread 08-03-2013, 01:47 PM   #548
Unlimited04
Zetto got stuck in "The-V", COLOUXJ tugged him out with a strap. I went around the bypass
It rained most of the time on the trail....was slippery as hell and traction was hard to get.
Unread 08-03-2013, 06:07 PM   #549
-sean-
1944 CJ2
Very cool
L-TJ
Unread 08-12-2013, 07:48 AM   #550
Unlimited04
Red Cone, Radical Hill and Saints John with COLOUXJ and freeskier93
Working on the GoPro video...got like 5 hrs of 1080p to edit
Unread 08-12-2013, 08:35 AM   #551
mike_dippert
hodophobic
Just post it all. We have time.
Unread 08-12-2013, 08:45 AM   #552
G Beasley
You post some great pictures ,thanks for letting the rest of us wheel vicariously through you
How bad is the turn on the left hand side of this picture ? Is it a three pointer , or is the picture deceiving ?
G Beasley is offline   Reply With Quote Quick reply to this message
Unread 08-12-2013, 08:51 AM   #553
Unlimited04
That's Webster Pass. I have not done it yet.
That said, I've looked down on it many times and that particular corner isn't bad. Red Cone has worse in the timber, and Radical Hill has worse on the switchbacks.
maybe, but I don't have the time, nor the space I'll try to get it up this week.
Unread 08-12-2013, 09:22 AM   #554
gspup
It's not bad at all...just a smooth turn. Webster pass is fun, super easy drive up and good camping along the river.
gspup is offline   Reply With Quote Quick reply to this message
Unread 08-12-2013, 09:56 AM   #555
freeskier93
I think there are a couple different ones that I didn't post to Facebook.
CU Boulder Aerospace Engineering
freeskier93 is online now   Reply With Quote Quick reply to this message
