Quantcast Unlimited04's LJ Build - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Unlimited04's LJ Build
TJ 5.25" Speaker Adapters - NalinMFGSpartan Lockers FREE SHIPPING Excellent PricesRough Country Deals at JeepHut.com
Old 05-16-2009, 06:35 PM   #1
Unlimited04
Unlimited04's Avatar
My ultimate goal is a capable general purpose Jeep. Whether thats daily driving to work in the crowded big city parking in garages, long 5 hour drives for fun activites, climbing mountain trails in Colorado, trail riding on forest roads to a fishing hole, carrying a mountain bike to the next singletrack, camping with friends, accessing various national parks/forests, or carefully driving to a Colorado ski resort in the middle of blizzard for world class powder runs. It's not a rock crawler, its not a mud hole machine, its more of a general purpose expedition Jeep and its going to go be a jack of all trades, master of none.
My comprehensive 33" tire build:
Mods for 33" tires
More Completed Mods:
Still waiting for install:
  • AEV/Nth Degree Shock Shifters (outboarding lower shock mounts) & OME N67L shocks
  • Rugged Ridge stainless steel header, wrapped with DEI Titanium wrap & coated with silicone sealant
  • Monstaliner DIY kit
  • 2nd stage tranny cooler
Wish List:
  • extra lights
  • air horn
  • alloy shafts
  • 2004 Durango 4.7L 160amp alternator
  • Supercharger, stroker or turbo
  • Something to fix the shift points on the 42RLE.
  • Goodyear 4060882 Gatorback Serp. belt
You don't NEED all this to run 33s, but above is what I would consider a comprehensive 2.5" lift kit to bring all steering, suspension and driveline geometry to where they should be, while still providing an exceptional daily driver and capable off road rig.
Removed mods:
JKS front track bar
Reason: didn't work.
JKS rear track bar
Riddler Diff covers
Reason: major clearance problems, front track bar & gas tank skid interference.
Homemade 23mm bumpstops
Reason: Removed from front. Welded on 3/8" plate & tapped spring pad for bumpstops. Used in the rear to make 1.3" bumpstop extension.
Homemade t-case drop (6061-T611 aluminum)
Reason: installed SYE/CV shaft.
Zone Off-Road front cam bolts
Reason: installed Rokmen control arms. Caster now at 6.5 with HP D30 swap.
Daystar 0.75" spacers for front & OME 933 front springs
Reason: went with 934 front springs after installing winch.
Unlimited04 is offline   Reply With Quote
Old 05-16-2009, 06:35 PM   #2
Unlimited04
Pictures!
Before:
After:
Front suspension:
JKS track bar, Skycrapper SS, drag-link and tie-rod adjusted & alignment done.
*edit - ^^that track bar and diff cover didn't work...they hit each other at 1.5" less uptravel than stock.
Read here:
http://www.jeepforum.com/forum/f9/tj-front-adjustable-track-bars-0-3-5-does-yours-hit-fit-738948/
Hopefully the JKS track bar won't hit the Riddler diff cover...time will tell:
Homemade 23mm bumpstop, JKS Quicker Discos:
Ground clearance:
Before:
After:
Rear Driveline Angle:
Old 05-16-2009, 06:46 PM   #3
Unlimited04
The biggest problem right now is the passenger side rear shock mount: http://www.jeepforum.com/forum/f9/lift-install-problems-778320/
I bought a Cobalt tipped drill bit that is supposed to be suitable for drilling hardened steel, that's tomorrows project. Tried to chip the weld-nut off today with a A3 tool steel chisel, it sure busted up the nut, but isn't doing much to the weld. The weld must be 7018 or higher tensile strength stuff.
Old 05-16-2009, 06:58 PM   #4
Unlimited04
I can't comment on the ride yet because there is no right rear shock and i'm bouncing all over the freakin' place. I can't go over about 40-45mph because it bounces like crazy. Can't comment on vibes yet either because I can't drive highway yet, and when I am driving, I'm bouncing....
But here's somes measurements of the gains:
Before-
Drivers Rear: 33.25"
Pass Rear: 33.25"
Drivers Front: 33.5"
Pass Front: 32.75"
To the Tummy Tuck: 11.125"
Lowest point on the front control arm frame side bracket: 9.25"
Front Bumper: 17.875"
Rear Bumper: 15"
After-
Drivers Rear: 37.25"
Pass Rear: 36.875"
Drivers Front: 36.625"
Pass Front: 36.5"
To the Tummy Tuck: 14.875"
Lowest point on the front control arm frame side bracket: 12.75"
Front Bumper: 21.25"
Rear Bumper: 18.75"
Hopefully it settles a little bit, because its actually about 1" taller than I'd like. It also sits slightly nose high, or level, because of the 0.75" spacer up front, and the fact that I don't have my engine skid on. I'd hoped this nose-high would point the output shaft down a bit more and prevent me from having to install a SYE/CV or t-case drop.
Track bars still need some work. Rear axle is too far left and the front axle is slightly pushed right. Maybe off 3/8" in rear and 1/8" in front. I also put blue Locktite on the track bar, so it should be fun to loosen. Another project for tomorrow after I get the rear shock on.
As I had hoped, the ground clearance with the JeepMedic tummy tuck + 2.5" OME lift is freaking awesome. I can have a party under there I honestly don't know why you would need more than this for a DD.
Old 05-16-2009, 06:59 PM   #5
rubidriver
rubidriver's Avatar
You finally did it. I see you did go with the JKS track bar. It looks like you wont be having any trouble with it hitting, although you might need more bumpstop in the front. You are running a hair shy of suggested bumpstop for 33's on those springs.
2005 Black Rubicon - OME 933/942 - OME N66/N67 - JKS Adj Track Bars Front/Rear - JKS Quicker Discos - 285/75/16 MTZ
Originally Posted by bigj1974 View Post
your money will go farther in College Station.
rubidriver is offline   Reply With Quote
Old 05-16-2009, 07:25 PM   #6
Unlimited04
what bumpstop should I have in front? The ones in there now are 23mm, which is 0.905".
Old 05-16-2009, 07:29 PM   #7
rubidriver
rubidriver's Avatar
With the 933 in the front normally you do a 2". With your BL you may not need that extra tho. You will be able to find out when you get your new tires ofcourse.
Old 05-16-2009, 07:46 PM   #8
Unlimited04
In case anyone's interested, here is the laser alignment data from the shop. The uncorrected toe-in and drag-link made for some white-knuckle 30mph driving, thats for sure.
Camber (L/R):
Before: -0.8/-0.8
After: -0.8/-0.7
Caster (L/R):
Before: 4.2/4.5
After: 4.2/4.5
Toe (L/R):
Before: 0.68/0.59
After: 0.15/0.14
Old 05-16-2009, 10:43 PM   #9
LGriffith
Did you get the OME HD springs, or the LJ/ZJ springs? My build's going to be very very similar to this one
04 LJ|2.5" OME|RE arms|1" BL|ROKMEN|Savvy|33" MTZ's
LGriffith LJ Build
LGriffith is offline   Reply With Quote
Old 05-17-2009, 05:53 AM   #10
Unlimited04
Front: 933 (TJ HD)
Rear: 949 (LJ Specific)
Decided against the ZJ 934 fronts after talking with OME. My friend that helped me install all this has 934 fronts with 949 rears, and he needs 1" rear spacers to sit level.
And if I'm thinking of the bumpstops correctly, I should be good. Baseline is 2" for 33s w/o BL. 2"-1.25" for BL. Leaves 0.75"-0.9" for the homemade bumpstop...which gives me 0.15" extra clearance. Plus theres a spacer in front which gives an extra 0.75".
EDIT-after adding a winch, I went to 934 springs. I'd recommend the 934/949 combo for LJ's, the 933's will work if you're keeping a stock front end with no extra weight.
Old 05-17-2009, 09:20 AM   #11
klimb2xs
I had the same thing happen when I replaced my shocks. I just took a dremel with a cut off wheel to the welds. I was able to get one side of each nut cut loose. Then I took a chisel to then and knocked them off.
The biggest problem right now is the passenger side rear shock mount: http://www.jeepforum.com/forum/showthread.php?t=778320
Black Jeep Society
Originally Posted by walldk View Post
Step away from from the vehicle and seek professional help.
klimb2xs is offline   Reply With Quote
Old 05-17-2009, 09:29 AM   #12
TheBoogieman
Demonic Jeep Freak!
TheBoogieman's Avatar
Those bolts are a PITA.I snapped 3 off mine.
http://jeephorizons.com/tech/xjshock.html
TheBoogieman is offline   Reply With Quote
Old 05-17-2009, 11:28 AM   #13
LJameson
Am I the only person in the world that hasn't broken those off? Even at 120,000 miles when I did my lift, the bolts came out no problem. And they were the original shocks...
You pretty much have the build sheet of what I wanted to do to my TJ. I'm probably going that same route when I get back into one too. Maybe even get into an LJ if theres one in my price range.
Money can't buy you happiness, but it can get your butt in a Jeep, and that's a good start.
LJameson is online now   Reply With Quote
Old 05-17-2009, 12:19 PM   #14
lumpster
lumpster's Avatar
Ive never had a problem, 4 jeeps and no breaks. Knock on wood!
Originally Posted by SuperWade2 View Post
Blaine asked me before we left camp if I'd ever been wheeling before, I said "sure, of course I have"... about 50 feet onto the trail, he said "Wade, you f'in lied to me, you've never been WHEELING before"... I think he was right! :rofl:
Want to STOP?
JEEP Co-op parts, jk, tj, lj, yj, cj delrin door bushings, TRE inserts, poolball shifters, tierod flip kits
My Goodyear tire experience
lumpster is offline   Reply With Quote
Old 05-17-2009, 01:06 PM   #15
95BadBoy
Unlimited04 -
Looking very nice, hopefully you will get that shock in today.
95BadBoy is offline   Reply With Quote
Glock Forum
