My cat is rattling really bad and I was just going to cut it off but then i realized that there is an O2 sensor connected to it. Is there any way to replace it with something that I can hook the O2 sensor into?
So the factory service manual is wrong?the rear 02 sensor does not have anything to do with the fuel, the second 02 sesnor only determines whether the cat is good or not...
I have a 1997 TJ with the 2.5L engine and the cat was just replaced by the dealer under emissions recall E-22. Parts and labor were free. You might want to check w/your local dealer to see if your cat has been subject to a similar recall.My cat is rattling really bad and I was just going to cut it off but then i realized that there is an O2 sensor connected to it. Is there any way to replace it with something that I can hook the O2 sensor into?
