Quantcast Right Hand Drive TJ Build Thread - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Right Hand Drive TJ Build Thread
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineBLOWOUT SALE -- SYE Slip Yoke Eliminator Kits, NP231 TransNEW BOLT-ON Dash CB Mount 97-06 TJ Wranglers
Old 04-21-2009, 08:32 AM   #1
NotURMailman
Straight Up Fool!
NotURMailman's Avatar
Ok, so some of you know that I have been having issues installing my RC 6" X system on my TJ due to it being RHD. Just wanted to post an undate.
1-After the first dissapointing conversation with the guy who is apparently the one and only grum a** unco-operative employee at RC I ended up in contact with Jeff. He has been super helpful trying to come up with alternatives and solutions for me. Maybe sergant 20% was just having a bad day, but customer service and support has been top notch since then.
2-I used 1/2 of the RC rear track bar bracket cut down and welded to the OEm bracket for strength. I am waiting for another to show up (thanks Jeff!) to finish that up. I have come up with a solution for the rear track bar that I will imnplement tonight.
3-The plan is this: the rear bar actually has no bends vertically. The vertical off set is designed in by the notch in the end of the tube where the end (where the bushing goes) is welded on. There is 8" between the end and the begining of the first horizontal bend. I am going to make a nice square cut at the 4" mark - then I will tap threads into both sides of the tube - I will install an 8" paice of threaded rod into the long end of the tube - I will screw the short end onto the thread stopping 1/2 of a turn short - this wil flip the end and reverse the offset.
4-The front will be a different story since the bar actually has bends in it. Atleast I will be able to set the Jeep down on the rear tires and meassure for my driveshaft and get it ordered.
OVERALL build progress:
XRC8 winch
Quick Air 2 OBA
Skid Row rocker skids
Skid Row fuel tank skid
Curt receiver hitch and receiver shackle
Crown SYE
Rear axle housing emptied and awaiting gears and locker (tonights project)
So, my Jeep is still in my garage on stands and my rear axle is now in my wife's garabe on saw horses.
Parts still in the pile:
Skid Row engine/trans skid
Skid Row lower radiator tank guard
Skid Row steering bow skid for RHD
Skid Row lower control arm skids
CB, antenna, etc.
4.88 gears and ECTEDS for front and rear
35x12.50x15 Pro Comp M/Ts on 15X10 Pro Comp Street Loks
I'M SURE I'M FORGETTING SOMETHING SOMEWHERE!
My RHD TJ - Savvy equipped... And loving it! - Durty Rok Carolina Offroad
I drive on the right side, what's wrong with you?
Be very careful with the wife mod. Uninstallation can be extremely expensive. Wife mods have been known to take the Jeep and all other mods during the uninstall process. Also, make sure you service your wife mod properly as often as humanly possible. Wife mods not properly serviced may malfuction or uninstall themselves at any time.
NotURMailman is offline   Reply With Quote
Old 04-21-2009, 08:33 AM   #2
NotURMailman
Straight Up Fool!
Just a note: with the hitch the rear "L" brackets for the fuel tank skid wont work. I just put the hitch on and then put the skid up, and then I welded the skid to the hitch.
Old 04-21-2009, 08:59 AM   #3
NotURMailman
Straight Up Fool!
Sorry I don't have pics. I always take the camera into the shop with me, but then I get busy and don't think too use it.
Old 04-21-2009, 02:16 PM   #4
NotURMailman
Straight Up Fool!
Wow! I'm really suprised nobody attacking me for modifying my track bars... LOL!
Old 04-21-2009, 02:29 PM   #5
miguelitojeep97
OMG YOUR modifying your trac bars!? it will never work...
1997 TJ 4.0 5 spd. rock track 4:1, 3.5 inch Rock Krawler 5 inch stretch long arm, 35 inch MTRs, Warn 9k, D44/30 locked with 4:88s, Vanco BIG BRAKES!!and more...
miguelitojeep97 is offline   Reply With Quote
Old 04-21-2009, 02:34 PM   #6
NotURMailman
Straight Up Fool!
LOL! I didn't say I wanted anybody to, I'm just suprised. People get worked up and attack people over the strangest things on here sometimes...
Old 04-21-2009, 02:35 PM   #7
RUBtjICON
Sounds like you are having a fun build ! If they go too easy, it's just no fun.
2004 TJ Rubicon........My build thread, My URE Vid
www.vanc4x4.net
All Who Drive Jeeps Are Not Jeepers - Willy 3:16
RUBtjICON is offline   Reply With Quote
Old 04-21-2009, 02:39 PM   #8
NotURMailman
Straight Up Fool!
In that case it's way more fun than I anticipated. Seriously though, I am really enjoying it. I just wish I had gotten started earlier, this is wheeling weather, not wrenching weather! But that really wasn't an option since I got it as soon as I got back in the country.
Old 04-21-2009, 03:51 PM   #9
jcssurf
So are you going to be delivering mail in a 6" lifted rig on XX" tires? Sounds like a pain...
2004 TJ-L with 3-4" of lift, 35's, and no money
The Unlimiteds shall inherit the earth.
jcssurf is offline   Reply With Quote
Old 04-22-2009, 06:43 AM   #10
NotURMailman
Straight Up Fool!
I don't deliver mail... LOL! I bought the Jeep from my mail lady, she got a new one.
Old 04-22-2009, 06:50 AM   #11
NotURMailman
Straight Up Fool!
So, maybe it's no fun when everything goes right... but, what do you call it when everything goes wrong?
First, I tell you never, ever buy the $125 pinion depth gauge from Summit. I now have a $125 paper weight. I know better, just thought I'd give it a shot.
So I took a leap of faith. My OE pinion gear was scribed with a zero and my new gear was also scribed with a zero. I never trust those marks and always measure for myself. Well, I went ahead and put the new pinion in with the old shims...
I went to pull out my torque wrench to mearuse the pinion bearing pre-load, and... Apparently the mover that moved me to NC dropped and broke it and just put it back in the case. The glass is broken of of the dial and the needle doesn't move fluidly anymore, it jerks erratically. So, I can't trust it.
Basically... never sell your differential tools evene if you think you will never need them again, you will end up buying them again. And never trust movers with your precision tools, and if you do the open everycase and inspect each one before you sign off on delivery.
So, all I got done last night was to install a pinion and I'm not even sure it's right! ARGHH!!!!
Old 04-22-2009, 08:55 AM   #12
NotURMailman
Straight Up Fool!
Ok, so I figured I could drown my frustration with money. I just dropped $700 to order a T&D pinon depth set and a bearing puller set and another $75 to order a new (used) Snap-On "torquemeter" torque wrench. That should make my life easier! Now I just need to find a soft jaw vise.
Old 04-22-2009, 12:07 PM   #13
RUBtjICON
I know what would make you feel better. Buy me a set of tube fenders Think of the warm fuzzy feeling you'd get helping out the less fortunate...LOL
Where are you in NC ? Want to help me regear my Rubi ? I do work for the beer company
www.vanc4x4.net
Old 04-22-2009, 12:18 PM   #14
NotURMailman
Straight Up Fool!
I'm about 30 minutes north of Durham. I'd be gald to help! (as soon as all these tools come in and I get mine done ofcourse) Where are you at?
Old 04-22-2009, 12:21 PM   #15
NotURMailman
Straight Up Fool!
I just caught that part. I'll be lucky if I don't get beat for the amount of money I've put into mine! Myabe next yaer I'll get some tube fenders, front and rear D60s and some 40s... LOL!
Glock Forum
EGGERS BROS. INC YOUR JEEP SOURCE
CALL 1-800-274-2460
Competitive pricing!
