i'll check the volts on the TPS when i get home. When the transmission shop had it they said it was a volt high. I think i'll replace it just to be sure after i check the voltage.
Tune up was done Friday the 14th. Plugs, wires, cap, rotor and coil.
Also having a problem with starting. i think the check valve on the fuel pump is bad as after the truck sits for about 20 minutes it wont start right away and needs to be primed with the key a few times. that, or its a leaky injector or two. which would be my misfire if those injectors are bad.
