Common Causes for Misfire DTCs - JeepForum.com
post #1 of 1 Old 02-06-2011, 07:58 PM Thread Starter
ZeeJay1997
Worn spark plugs
Cracked distributor caps
Out of Phase distributor/rotor
Shorted rotors
Leaking plug wires
Low fuel pressure
Low compression
Sticking valves
Broken valve springs
Worn cam lobes
Incorrect valve or ignition timing
Leaking EGR
Vacuum leaks
Leaking Injectors
Clogged Injectors
Contaminated fuel
Low fuel tank level
Excessive EVAP purge
Low ignition system primary voltage
Cracked coils
Plugged exhaust
Excessive PCV flow
Wiring Harness
Faulty PCM
Since the Misfire DTCs cause us Jeepers so much grief. Many of these are cheap and easy.
P0300 P0301 P0302 P0303 P0304 P0305 P0306 P0307 0308
ZeeJay1997 is offline
cel , ignition circuit , mil
Not your common offroad tire... ChargerX3 Tires & Wheels 18 12-16-2009 11:15 PM
Noob with a common question.... MTBeaconJunkie General Jeep & Off-Road Equipment 10 10-15-2009 06:01 PM
Headgasket on a 4.0? Hard? Common? Seven Engines & Drivetrain 2 07-25-2006 10:04 AM
common cb freq jason.luckwell Audio, CB & Ham Radios, GPS, & Electrical 1 11-23-2004 11:37 AM
why not?, common... , please Rockwall General Jeep & Off-Road Equipment 43 07-12-2002 05:22 PM
