So I have print out that I got off of here that says 1.1 qts for a np231, is that right, it just does not seem like it?
What if the box is low on fluid before you drain it?...See how much comes out when you drain it. That'll tell you if it's right or not.
If the capacity is supposedly 1.1 and you get 1.0 or .9 quarts, then that - to me, at least - is a good indication that the 1.1 number is right. However, I see your point...I wouldn't want to rely on what I drained, exclusively. I was treating it as a number that could corroborate what one already has been told. Thanks for pointing that out! :thumbsup:What if the box is low on fluid before you drain it?
