Know that the Voltage you want to use on an adjustable MAP tends to rise with your modifications. Also know that monitoring the AF ratio via an O2 based AF monitor would go along ways towards helping an individual adjustable-MAP-user know what voltage is optimum for his setup.
However, I don't have any kind of 02-sensor based AF monitor on hand at the moment. But I'd still like to get an idea of what Voltage settings have worked well for people here given their respective engine modifications (especially if similar to my own) -- 4 or 6 cylinder, either way
Mine is a 4Banger 2.5 with a Borla Cat-Back, PDI ignition, 62mm TB, custom cold air intake, 19lb Ford Injectors, and an Adjustable FPR.
Over the weekend I installed an Adjustable MAP sensor from Turbo City (yeah, I know you can make your own for $20-$30, but time is money and all that and I personally came out way ahead just buying a completed unit).
My stock MAP Sensor measured at 4.63V. Turbo City directions suggested increasing the Voltage by .2V. So I did that and now I am measuring 4.82V (precise .01V increments are hard to do with the thing).
And it is running better. But I would like to find out from you guys what Voltages you are using given your respective mods. Thanks.
