Depending on height, radius arms are stupid the higher you lift them. If you calculate them in a 3/4 link calculator, you'll see that since they function as if the upper control arm "mounts" at the exact same point as the lower control arm mounts(at the frame) and is seen as one solid connection as far as geometry numbers go, they will have ****loads of anti-squat and jack the hell out of the suspension under load. No way to really adjust anything short of lowering the vehicle or lowering the control arm mounts on the frame.
My 3 link has 36" long lowers, a 40" long upper control arm, and I've got it set up for about 60% anti squat. It drives great on the road, unfortunately I have no experience offroad yet as it isn't ready but I'm very confident it will work well.
Going back to radius arms... they work the same as a traction bar on a leaf sprung Jeep. The shorter the radius arms are and the more of an angle they are at in relation to the axle tube and the frame side mount, the worse they will perform. I built my traction bar as flat as possible to stay at or under 100% anti squat in the rear. It accellerates with the rear not changing height hardly at all, and the front raises just slightly like it should. The front doesn't have brake dive or anything as well. Drives like it should.
