Quantcast flatlander757's 03 TJ build/update thread - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > flatlander757's 03 TJ build/update thread
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGR8TOPS Introduces the Exogate HD Tire Carrier1984-2001 Jeep XJ Cherokee Lift Kits 3-4.5" with Full
Old 09-01-2007, 09:07 AM   #1
flatlander757
Now in the 937
flatlander757's Avatar
flatlander757's 03 TJ build/update thread(now D60/D70 swap/stretch on 40s)
My build thread has gotten out of hand and being as ridiculous as it is, it's very hard to sort through it, or sit down and read it all at once. This table of contents is going to be a work in progress and I hope to get it up to date within a month or two. Thanks for checking it out
Page 1 - Table of Contents that you're reading now... then the build starts! Scroll down you big dummy!
Page 2 - 3" Full Traction lift fully installed, 33x10.50 TSL Radials, spaced out tire carrier for bigger spare
Page 3 - More pics of tire carrier bracket, MV1050 compressor installed, rock lights, Uwharrie wheeling trip
Page 4 - SYE, CV shaft, JKS rear UCAs, cut front bumper, RE rear trackbar and angled bracket
Page 5 - Redid rock lights, Pioneer DEHP4000UB radio, JKS Quicker Disconnects, Cobra 75WX-ST CB, Nth Degree engine skid, RE steering stabilizer, Poison Spyder steering box skid
Page 6 - Uwharrie wheeling trip, pics from the Outter Banks, Raptor liner install
Page 7 - More Raptor liner pics, AtoZ rocker guards installed, pics of carnage from Starr Motors Offroad Day 2008
Page 8 - BESRK tire carrier install, bought a welder, custom 3rd brake light, rock lights redone AGAIN
Page 9 - Pics of girlfriend(now wife) posing with Jeep, lots of chatting
Page 10 - Uwharrie wheeling trip, Christmas Jeep pics, picked up a HP30, started spacing the EVAP canister and installing CJ style tail lights
Page 11 - Finished CJ tail lights, license plate light, THE WORST IMPULSE BUY EVER: I bring home a D60 and D70HD :evilgrin:
Page 12 - Cut EVERYTHING out from under the Jeep... there is no turning back now! Started cleaning the old brackets off the axles and frame, etc.
Page 13 - Still cutting brackets off the axles, comp cut on the tub, cut the front fenders up, some parts starting to arrive
Page 14 - Tires arrive, fuel tank mounted in the tub, start fabbing rear bumper, mounted the first of my tires
Page 15 - Rear bumper fab continues, rear leaf spring mockup, mounted another tire("how to" mount on a beadlock wheel)
Page 16 - Final-welding in the rear suspension, bunch of chatting and answering questions about the build
Page 17 - Start checking clearances at the front axle for driveshaft and steering, cut the front crossmember out of the frame
Page 18 - Steering box relocated for more clearance, start playing with the 3-link calculator, built new front crossmember
Page 19 - Finalized crossmember, D30 vs D60 axle shafts, D300 installed and clocked to check DS clearances, front axle brackets starting to get mocked into place
Page 20 - Rear axle brake calipers replaced, brake lines run, fabbed frame-end brackets for front suspension
Page 21 – 1.25” BL, front suspension tacked into place and mocked up with dummy control arms
Page 22 – Welded in some of the control arm brackets on the axle, and mocked up with real suspension links
Page 23 – Cycled front suspension, Branik high steer D60 arm installed, coil mounts tacked in place, drag link mocked in place, trackbar mounts tacked in place, welded a BUNCH of stuff in for good
Page 24 – Pics of all the stuff welded up, final teardown, started painting EVERYTHING
Page 25 – Painted suspension components, mounted the last 2 tires, final touches on rear bumper, Spyder giving me crap(lol)
Page 26 – Reassembled, IT SEES DAYLIGHT for the first time in 9 months!
Page 27 – Problems with not turning tight enough
Page 28 – Tie rod built, replaced a wheel bearing, had some problems with siezing a heim in my new tie rod
Page 29 – Built front shock mounts, pics of front end and steering
Page 30 – Pic of my Jeep next to a stock Jeep(Zach's), JK turn signal install, side clearance lights, started building rear axle shock mounts
As I said, this is a work in progress... you'll get the rest of the 140+ page build up sorted when I have time to kill.
The Build starts HERE!!!
So I figured I oughta start one of these threads before I get too far into building up my Jeep. The short-term goal(less than 5 months) is to have it sitting on 33in tires. Then the long-term goal(by this time next year) is to get it regeared for 35s, put some armor on it, flat-fender, and 35in tires of course. I probably won't be updating this every single day but whatever I do I'll take pictures
So anyways, here is my 03 Sport(4.0, dana 44, and NV3500) the day I got it a couple months ago:
And then 2 days later:
I made my own mirror for when the doors are off, seen here:
The lumbering steel-laden pig - 2003 TJ - 40" LTBs - D60/D70HD - 5.86s - Detroit lockers - 110" wheelbase
Build thread here.
Originally Posted by 2006 Sport
Being able to make vroom vroom noises in Tonys Jeep was the highlight of my life.
Check out my Youtube channel
Pictures of it wheeling at Bill's 491
And more pics from that trip here!
flatlander757 is offline   Reply With Quote
Old 09-01-2007, 09:14 AM   #2
flatlander757
Now in the 937
Then within the first week or so it was sans-front-milkjugs:
Then just a couple days ago I got around to painting the fender-flares and headlight bezels w/ satin black krylon fusion... it looks great IMO!
And then not directly Jeep-related, I got out of the dealership I worked at and went to a very large used car dealer. They provide tools there, so I got to take home the ton of stuff I'd bought while at Hall Dodge
It's also a nice $$ increase so more goodies for the Jeep!
Build thread here.
Old 09-01-2007, 08:57 PM   #3
ronprice
Now black out those wheels and lift it !!!
Family of 5<Myself and 4 girls. Out numbered and dont care that I leave the seat UP.
-OIIIIIO-
ronprice is offline   Reply With Quote
Old 09-02-2007, 01:55 AM   #4
Dr. Marneaus
Hairy Armgina
Dr. Marneaus's Avatar
1973 FSJ Wagoneer
yeah, time to black everything out, some day you can be as cool as me
haha, just kidding, good job with the paint son.
Andrew - Landscape architect in training. Not landscaper
If guns kill people, then pencils misspell words, cars make people drive drunk, and spoons made Rosie O' Donnell fat!
"One of the best ways to get yourself a reputation as a dangerous citizen these days is to go about repeating the very phrases which our founding fathers used in the great struggle for independence" - Charles Austin Beard
OOoooh, it's a killin' machine! It's got everything! Like a drivin' power, big fat tires, and everything!
- Deep Purple
The Beast Build Thread:Marns '73 Wagoneer Thread ----- Gone but not Forgotten:97 TJs Build Up.
Dr. Marneaus is offline   Reply With Quote
Old 09-02-2007, 02:29 PM   #5
flatlander757
Now in the 937
Haha, it's funny you responded, I've read through your entire build-up... it pretty much gave me the inspiration to get off my *** and do something haha
Build thread here.
Old 09-03-2007, 04:01 PM   #6
jayhawkclint
1970 CJ5
I've got tool box envy.
My '70 CJ5 Build Thread:
http://www.jeepforum.com/forum/f22/my-jeep-build-thread-359375/
jayhawkclint is offline   Reply With Quote
Old 10-03-2007, 07:41 PM   #7
flatlander757
Now in the 937
No pictures, but soon to come is a FT 3" lift w/ 33x10.50 Swamper TSL radials
And so you know the flares and headlight bezels have held up great
Build thread here.
Old 10-03-2007, 07:53 PM   #8
.Jch.
You didn't do any prep to the bezels? Just spray painted them? I might do that rather than pay 30 dollars for the black set from quadratec.
[SIZE="4"][CENTER]
[B]_____
[U]l JEEP l[/U]
[U]OllllllllO[/U][/B]
[SIZE="1"]2006 Unlimited[/SIZE][/CENTER][/SIZE]
[center][B]Black Jeep Club V2.0 Member #2006
[URL="http://groups.jeepforum.com/LJ_Owners"]LJ Owners, join the group and click here.[/URL][/B][/center]
.Jch. is offline   Reply With Quote
Old 10-03-2007, 08:01 PM   #9
flatlander757
Now in the 937
I just roughed them up with some 320 or something grit sandpaper, wiped them down with parts cleaner and a rag. Then sprayed them.
Build thread here.
Old 10-11-2007, 09:56 PM   #10
flatlander757
Now in the 937
My 3" FT lift is in the garage awaiting install. Hopefully this weekend
Build thread here.
Old 10-13-2007, 10:39 PM   #11
flatlander757
Now in the 937
So I have everything up front installed save for the sway bar stuff...
The only problem I ran into was the driver side front shock was being stubborn on the top mount. I couldn't get a good hold on the top of the shaft and it kept getting mangled so I cut up the cover and used vise grips and a 1/2in impact
Also there is no need for a tie-rod end puller for the track bar or the swaybar endlinks... here were my solutions:
Build thread here.
Old 10-13-2007, 10:44 PM   #12
flatlander757
Now in the 937
...and for the track bar tie-rod end, I did the same thing that I do for tie-rod ends in the dealership, loosen the nut enough to get loose but still hold when the tie-rod end is free, and hit whatever it mounts into with a hammer. It will take a few good blows but it works well. It may help to be wiggling/forcing the track bar w/ one hand back and forth or have someone rock the steering wheel back and forth while hammering.
And the pics in the last post aren't up to date, I've got the track bar and shocks all installed too and wheels back on. I've got one spring on in the rear, I'll have to finish tomorrow.
Build thread here.
Old 10-13-2007, 11:18 PM   #13
AlTheKillerr
looks good so far! cant wait to see it with the lift completed
AlTheKillerr is offline   Reply With Quote
Old 10-14-2007, 03:06 PM   #14
flatlander757
Now in the 937
So I've got all the physical parts installed, it looks freaking great I'm about to set the toe and straighten the steering wheel then test drive it. I'll take pics before it gets dark and probably post them between 10:00 and 11:00
Build thread here.
Old 10-14-2007, 09:12 PM   #15
flatlander757
Now in the 937
Well here it is... I have it aligned and all seems well, I'm not sure if I've got vibes or not, if there are any they're real subtle, but since I'm so paranoid about having them it's hard to tell if I'm imagining them or not.
Build thread here.
Glock Forum
