Idle Air Control Valve- High Idle
51K views 43 replies 12 participants last post by  Que89YJ
I have read several things here and wanting some input to put me in the right direction.
I have a high-idle issue about 1600-1800 RPM's
I took out the IAC (Idle Air Control Valve) and cleaned it out. When I placed it back in the idle was purring at around 700 RPM's.
I thought it was good so I shut it off. When I went driving the next day, the high idle came back. GRRRR.
I picked up a new IAC, thinking the old one might have issues.
Put in the new IAC, and it was idling at 2800-3000 RPM's holy cow.... I read that if you drive it at 40 MPH it will "re-set" ; nope didn't work when I got back from my drive it was still screaming at 3000 RPM's.
I pulled the new IAC back out; adjusted the pintal out, put it back in; the idle went back down to 700 RPM's. Took it for another drive @ 40 MPH, and the idle creaped back up to 1300 RPM's.
I am stumped, any ideas out there? Anyone seen this before or was able to troubleshoot this? Anyone have the exact pintal measurement for installation?
EDIT: 1993 Jeep YJ 4.0L stock motor stuff.
EDIT: It's all fixed, it was a leak on the intake/exhaust gasket back by #6 cylinder, it was delaminated between the exhaust & Intake ports on #6. That's why I couldn't find it with the usual tactics (carb cleaner, water, sound, etc).
What the exact symptoms (were): Idle at startup was around 700-900 RPM's; Idle after warm up or after driving it over 40 MPH was around 1400-1900 RPM's. Everything else was normal no codes, plenty of power, etc.
For anyone else playing around with the IAC; the more you shorten the pintal (screwing it in or clockwise) the faster the idle will become. If you lengthen the pintal (screwing it counterclockwise) the slower the idle; however there is a happy medium in length that must be achieved, and some models have groves where you have to screw it down to match up with the groves in order for it to work properly. I have found that the groved model you can't really adjust it and that it has more throw. The aftermarket versions (non-groved) seem to have adjustability of about 1/2-3/4 of an inch.
Find your vacuum leak. It sounds like you have a leak and the IAC is trying to compensate for it, then when you drive, it re learns what is normal and then you get the high idle. It doesnt take a large leake to make the idle go up.
Check all of your vacuum lines and connections. If you cant find anything obvious, you can spray carb cleaner around the vacuum lines with the engine running, listening for a change in idle speed. When you hear it, look in that area very closely for a split line, dry rot, etc.
Tried the vac leak/carb cleaner look around, there was no change in idle;
tonight when I get a chance I'm going to remove a vac line one by one and plug it (thinking maybe the 4WD lines?)
Sticky throttle plate? That's a new one, did spray cleaner down the throttle body didn't do anything but make the engine bog down.
Thanks for those that replied.
I am having the same exact problem. I thought I got a bad IAC from Quadratec, so I got one from Auto Zone and another from the stealership, only to have the same result. I use a propane tank to look for vacuum leaks and found none. I have been taking the IAC out and turning the plunger out at a half turn each time. Over the coarse to five days I have been able to get idle down a little but not where it needs to be. Engine at normal operating temp, idle is still around 1300-1400. Re-adjusted throttle cable, no change.
Alfons said:
If the manifolds or the throttle body have been removed/reinstalled, that woiuld be the first place I would look - around the gaskets. With a leak that size, you should be able to hear some level of "hiss" that isn't attributed to the air rushing into the throttle body.
I had loose bolts at the header/exhaust manifold. Check them manually to be sure.
#21 ·
The type of leak that you're describing does have an effect on the oxygen sensor, but that would make the engine run rich, not fast idle. You mentioned that you had some loose manifold bolts and tightened them - the fact that they were loose, could mean that the intake is still leaking to some degree (you don't need much of a leak to raise the rpm). You used a cleaner to spray for your vacuum leak test and didn't find anything - not all cleaners are volatile enough to be useful in this test, I've had better luck using propane, but again this test doesn't always work (the smaller the leak, the less chance you'll have of catching it with this test), so I tend to plug off all vacuum lines at the manifold with the exception of those that are needed to run the engine (MAP, fuel pressure regulator, and that's about it) and add a vacuum gauge to one vacuum port to see what reading I get. I rely on the vacuum gauge readings for a lot of problem diagnosis.
I had a high idle (3000-4000 RPM) and it turned out to be a leak in the intake manifold gasket.
Spraying some carb cleaner around the intake manifold where it meets the head would tell you for sure. You said you tried the carb cleaner. Did you try it around the intake manifold?
#14 · (Edited)
Nibbley, I don't believe the leak in that area will cause the high idle, because I don't have the leak, but do have the idle. I have gotten my idle down to 1100 rpm, but after a couple of days the IAC making the automatic adjustments the gets too low that my Heep wants to stall. Starting to think that I would have better luck if I went to a junk yard and pulled an IAC from there, because the three that I have bought are different from the original.
Nibbley, I don't believe the leak in that area will cause the high idle, because I don't have the leak, but do have the idle. I have gotten my idle down to 1100 rpm, but after a couple of days the IAC making the automatic adjustments the gets too low that my Heep wants to stall. Starting to the that I would have better luck if I went to a junk yard and pulled an IAC from there, because the three that I have bough are different from the original.
Thanks! I'm still chasing this one down,
I feel we are on the right track here, it has to be something that works with the IAC that tells it what to do (from another sensor?)
EDIT: I have the orginal sensor and the new sensor and they both do the same thing, first start idle great, after driving idle goes up.
#17 ·
I have a caliper gauge and have the measurement down to 2 13/16 for the total length of the IAC. If i could keep that measurement then great, because idle is about 1300rpm cold and 900prm warm. The problem is the auto adjustment keeps moving (over time) the plunger out til the rpm's drop to low.
#33 ·
This statement is still bugging me. My issue has stabilized somewhat after setting the total length of the IAC to 2 13/16, complete cleaning of the IAC housing and installing a new MAT. Right now cold idle is 1400-1700rpm and warm is 700-900. My issue is everything gets reset after I turn the key off. If I start back up immediately, the idle is at 1400-1700, dropping after a minute or so. Being that you situation is opposite I can't help but wonder if a couple of wires were switched, telling the ECU that your engine is cold when it is not, but if this were the case then one of the three controllers (MAP,temp,TPS) should throw a code. Have you had a chance to test the MAP yet?
#19 ·
Im going to take a shot in the dark here. Maybe the ECU is thinking cold its in cold idle. Try checking the temp sensor by the thermostat. Did you clean out the throttle body and the IAC air passage when you had it out?
#20 ·
I just thought of that thermostat just this morning, need to get in the books to see if it's reading right. I cleaned out the air passage about a week or so ago.
I adjusted the IAC a bunch last night, taking measurements etc. I now have it adjusted to a cold start @ around 800-900 RPM's; warmed up it floats around 1100-1300; getting closer, but still working opposite so I'm still going to check the thermostat (computer side), since the gage is operating good.
#24 ·
Thanks! Was looking for that chart.
OK, so here might be a silly question, and trust me I know wiring so yes I feel dumb asking this,
I am getting an infinity reading for Ohm's from the coolant temp sensor. I tried 2 different meters (digital), 2 different sets of wires. Checked the ground and had hardly any resistance, so I know the meter was working.
Tried checking the resistance between the two contacts on the sensor, tried one side to ground, then the other side to ground, nothing, nada, zilch. Please advise did I do this wrong? I am testing this plug:
EDIT: Had the meter set to Ohm's not K Ohm's since it was a cool motor had to have in the thousands to pick up a reading, LOL; tested against a known good one and had the same exact readings. Around 6,000 ohm's
#30 ·
Nibbley, advance comes down to 3 sensors: Map (Same as vacuum advance on the old distributors, Temp sensor (Cold and warm idle), and the tps.
#31 ·
I know that is correct, however an out of limit TPS, and MAP will drop a code, and all I get is code 55. My shift light comes on (MAP), and when I push the cluth while arriving to a stop the RPM's are around 1500 ish, when I finally arrive to a stop the RPM's drop down to 1100-1300 ish (depending on it's mood). Also when I pull a vacuum line the RPM's go up, plug it and goes back down. This weekend I'm going to pull the exhaust donut out and replace it (take out known bad things). Don't think this will cure it, however maybe the O2 sensor is thinking rich/lean condition and more or less gas causing the high-idle?
#32 ·
No, a bad sensor doesnt fail out of range always. There in lies the dig with OBD1 over OBD2. Obd1 is a fixed range with OBD2 looks at rate change and range. You need to measure the TPS and Map to make sure they are ranging correctly.
#34 ·
Just got the exhaust leak fixed today, replaced the donut on the header manifold to down pipe, found that I had a cracked header/manifold too. Got that welded, runs smoother. Currently after that change here is my latest: sensors are all working as advertised, from the tests I can perform. No codes from the computer, the O2 sensor was pretty white (not normal goldish color).
Now the idle cold is around 800-900; warm is anywhere from 1100-1300 depending on it's mood. Next I'm going to pull the battery cable, to reset the computer and see what she does. She still has plenty of power, was able to maintain 55 @ 1450 RPM's in 5th on a flat road on 33's.
To answer the question on wires switched, it's stock wiring, nothing looks spliced together, I haven't pulled the dash out, but from what I can see with a flashlight, looks good under there.
#35 ·
After driving around on this for a week after reseting the computer, same stuff. Finally found the other exhaust leak (far right of the exhaust manifold) by #6 cylinder. So I decided to finally pull the exhaust header so I can replace the gasket. After pulling the intake & exhaust out, found out my gasket was delaminated bad and leaking by #6 on the intake & exhaust side; so IMHO this was probably causing my high idle. Now to get some feedback, my intake was coated with crap from the injector holes all the way to the valves, no big deal I guess, looks like someone was pouring something in there (seafoam?). Anyway here is a pic of the exhaust valves, they are white; so please let me know am I close to a valve job here? Or can I get at least a year out of these before I go and do a head job on this? Will this even hurt anything? Please advise, thanks in advance....
