How To Check Fault Codes - JeepForum.com
post #1 of 25 Old 08-25-2011, 07:15 AM Thread Starter
Que89YJ
I keep reposting the fault code check so I though I would put a thread in to link to for everyone to refrence. The FAQ one is good but I like the video from YOUtube to show how it's done. Here are the links:
An this is what they mean:
http://www.jeepforum.com/forum/f12/s...eaning-677141/
12, 33, and 55 are normal and should happen every time you check the codes.
Que89YJ is offline
post #2 of 25 Old 08-25-2011, 07:56 AM
oldtime_ironman
Thanks, Que. I've started giving that video also, especially to newbies.
Lately I've been researching and writing how to test various sensors with a multi-meter.
Mind if I add that to this thread when I get done with it?
Not to mention what you said about disconnecting sensors, and re-setting the ECU.
oldtime_ironman is offline
post #3 of 25 Old 08-25-2011, 08:04 AM Thread Starter
Que89YJ
Add away. I hate getting repetitive.
Que89YJ is offline
post #4 of 25 Old 08-25-2011, 08:19 AM
oldtime_ironman
You and me both!
post #5 of 25 Old 01-31-2012, 08:32 AM
monsteryjjeep
no start 95 wrangler 2.5 4cyl. cut off going down the road will not start bad its getting fuel just no spark replaced the coil twice and still no good. Checked everythings getting power but the tps, map sen 5v with key in on position. Codes 22,23,24 show up when I checked it. I know what they are but dunno why they would stop it from starting or getting spark they just control the fuel lean,rich part. Any ideas? Would greatly appreciate any.
monsteryjjeep is offline
post #6 of 25 Old 01-31-2012, 09:18 AM Thread Starter
Que89YJ
Post up to a new thread. Yes they can stop you from running. You need to disconnect the battery for 10 seconds. Reconnect the battery, try to start it and rechec the codes. Post back in a new thread what you find.
Que89YJ is offline
post #7 of 25 Old 01-31-2012, 11:43 AM
brentd711
Thanks Que! Can you also post the procedure for checking the PCM for codes with a trouble light for those of us with pre-CEL rigs? Maybe I'll be able to find it easier with the search function if it's in this thread.
brentd711 is offline
post #8 of 25 Old 01-31-2012, 11:50 AM
monsteryjjeep
im new with this forum how do I do it?
post #9 of 25 Old 05-22-2012, 05:33 PM
zomblake
The video is no longer available.
zomblake is offline
post #10 of 25 Old 05-22-2012, 07:04 PM
pete1991YJ
I have a copy of the video if JF will let me upload it somehow. Que what do you say?
***--- Wrecking Crew member ---***
"I've prolly been around longer than you think"
pete1991YJ is offline
post #11 of 25 Old 05-22-2012, 07:14 PM Thread Starter
Que89YJ
Absolutely. That is a great video.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #12 of 25 Old 05-22-2012, 09:23 PM
pete1991YJ
post #13 of 25 Old 05-22-2012, 10:18 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
That's an awesome quality video. I miss the early 90's.
Luck Favours The Prepared
Anticanman is offline
post #14 of 25 Old 05-22-2012, 10:39 PM
pete1991YJ
The original video was a flash vid, I re-coded it into mp4 so now it should play on iPhones and Androids. Better quality than many other formats. I'll also up a vid about testing the IAC someday soon. BTW notice the youtube acct is owned by Oldtime Ironman. Here's to you, Que!
post #15 of 25 Old 05-22-2012, 10:54 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Yeah, what ever happened to OldtimeIronman?
fault codes BadApple1403 YJ Wrangler Technical Forum 6 06-20-2009 12:21 PM
FAQ - Check Engine Light and Diagnostic Trouble Codes (Error Codes, Problem Codes) Wheelin98TJ TJ Wrangler Technical Forum 6 05-15-2009 05:05 PM
Gas Cap and Fault Codes AferVentus TJ Wrangler Technical Forum 11 05-19-2008 03:35 PM
Fault Codes? SEMO 95 YJ YJ Wrangler Technical Forum 0 02-14-2008 04:41 PM
Check Engine Light - No Fault codes !! jreuscher TJ Wrangler Technical Forum 0 06-21-2005 08:29 PM
