Jeep Enthusiast Forums banner
61 - 80 of 2,573 Posts
Discussion starter · #61 ·
I am not too sure when I added these so now seems like a good time :D
I needed new plug wires so instead of buying the same old rats nest I went with a blue set of Taylor Shorties. They cleaned up the look of the engine a bit and made it easier to diagnose an issue in the future.
To keep the internals and especially the throttle body cleaner I got a Billet Technologies Catch Can! I bent a spare piece of steel into an "L" bracket, painted it Khaki, and mounted it to one of the passenger side strut bolts.
Discussion starter · #62 ·
Now for a little suspension modification! I wanted to eek a little more height out of this thing. I thought about doing something similar to AcidCold's Frankenstein (Hybrid) Lift, but after the disastrous outcome he had I decided against it. Instead I decided to only add an extra inch. The problem was no one made a 1" lift, so I had to make my own.
First the rear.
I acquired a set of rear poly spacers from a RRO lift locally to play with. They started out looking like this:
Then I chopped .75" off the bottom and the center 1" off the top:
As you can see the bottom piece that I cut off was beveled so I had to do the same so it would seat properly.
I was planning on reusing the rubber isolator so I had to trim up the top a little too.
After all that they were down to a 1.5" spacer.
I also installed the custom longer sway bar links from Rusty's.
Discussion starter · #63 ·
Now for the front.
I was already using one set of Rusty's strut spacers. With one set on I could see that the bolts were not long enough for another set. So I had to get longer bolts. Instead of tracking down just the right size stud that would be a proper replacement only longer, I bought grade 8 bolts to use. The problem with using bolts and not studs is now the bolts could freely spin, where as the studs were pressed in place.
The new hardware:
Compared to the old:
To remove the stock studs from the strut plate, I used a 7/8 socket. After letting them soak for a few minutes in PB blaster I placed the socket under the stud, and after a couple good whacks they popped out.
Now I placed the new bolts in and welded the heads to the plate. After hitting them up with a wire brush, primer, and paint they your good to go.
I reassembled the strut assembly and they were ready to go back in!
Discussion starter · #64 ·
December came and with it my trip out to CO! This was my trip report once I got back:
So I am now back home. The trip was great! I love spending time with family. The trip out there was not so great. I left at 0400 and got there at 2200 PST. It literally rained the entire way out there except for the last 3 hours. So traveling through a storm meant my gas mileage sucked. I averaged 17mpg on the way out which isn't too bad considering the terrain and the weather. On the way back I averaged about 19mpg and even saw 21 for a while! I am very glad I grooved my tires though. With all that rain and snow I know my traction would have been pretty bad. They performed flawlessly the whole trip. And the HEMI!!!... Man I love that thing!!! Even with the 285s and the terrain, I had no problem maintaining unmentionable speeds. :shhh::shhh::shhh: The landscape out there through Utah and Colorado was just Gorgeous! I really want to move out there, unfortunately I don't think that will happen any time soon. It killed me to go all that way and just drive past Moab without stopping for a quick offroad adventure. If I was not on a time crunch I would have. Anyway, here are some pix I snapped during my drive. Enjoy! :thumbsup:
Discussion starter · #65 ·
Time for the 60K mile service! I went to the stealership to grab some goodies.
There was a 2011 Grand Cherokee sitting there so I decided I should park next to it. When a couple of the salesmen saw me snapping pics they came over and asked me if I was ready for an upgrade. They were talking GC I was thinking SL! :D When they started telling me how superior the '11 was offroad I had to laugh and tell them that a vehicle with only one locking diff would never be more capable that a vehicle with 2 locking diffs. They had no idea what I was talking about :facepalm: Ha, figured!
Discussion starter · #66 ·
After finally coming to the realization that my currents CB antenna was a piece of crap, I ordered up a real one. I got a 3' Firestik 2 antenna along with a new Fire-Ring cable and the Saguaro mount.
Discussion starter · #70 ·
Well after procrastinating long enough waiting for a company to come out with some aluminum sliders that didn't way 100lbs, i finally bought the 4xGuard Side Guards (3rd Gen). Along with them I purchased the Belly Guard to finish off my collection of armor. The instal was easy, but having a second set of hands would have been nice.
I did the belly first.
I found a second set of hands sitting on the patio! :D
I was thrilled to finally have this skid. I have come to realize that the main piece that covers the tranny is very stout, however the piece that covers the cat needs a little work.
Next came the sides.
With the plastics removed.
The second set of hands wasn't really needed here, but it made me feel better laying underneath it. :D
They don't quite match just yet!
I love the shape of these things! If you didn't know any better you would think these were stock plastic skirts. The fit and finish is superb and the mounting is very solid for bolt on rails. Although it could be better by tying them into the frame, most will never need anything stronger. I like that I got the 3rd Gen because the 4xGuard logo that used to be cut into the sides always seemed to be the first thing to rust on other Jeeps.
Discussion starter · #71 ·
After a lot of research and talking to way too many people I finally decided on and purchased my new tires! I went with the Nitto Trail Grapplers in the hefty 295/70/17. I figured they were only slightly bigger than what I was currently running and I got those to fit so why not give theses a try :D The next day I went out for a quick test run.
These suckers are huge! They fit pretty good, but rubbed a bit here and there. Nothing I couldn't handle :D The only thing that needed to be handled for now was to take a sledge and flatten the pinch weld just a little bit more.
Discussion starter · #72 ·
I just realized I forgot to mention my wheel spacers! I knew with how close the 285s were, the .25" spacers were not going to cut it anymore. So I bolted the 1.25" spacers back onto the front and got 1" spacers for the rear. This combination worked good and it is what I am still using now!
What spacers are you using omelet?
Discussion starter · #74 ·
If you are asking brand? They are from a shop on eBay! No fancy name, but they are quality spacers made exactly like the fancy expensive blue ones :D
How much did you spend on them? And any comments on them? I'm in the market for some. Any cons?
Discussion starter · #76 ·
After adding all of the additional weight in the past year, especially the rails, I decided the MD coils just weren't going to cut it anymore. Before the Jeep felt very controlled on and off road, but lately it was feeling a bit floaty. Also in preparation for a near future project, it was time to upgrade to the Heavy Duty coils! So I place another order from Kolak.
While I had the struts apart I also installed some rubber bumpstops to the existing foam ones. These effectively keep the tires from smashing into the fenders on hard hits. :thumbsup:
I used these and cut them in half so they were 0.5" thick.
And how it looked after!
Discussion starter · #77 ·
They are $60 a pair. I haven't had any issues with them. The only thing that could be a con is that with the 1" set they are only hub and lug centric, not wheel centric. I didn't see it as that big of a deal.
Discussion starter · #78 ·
A few days later I got the heart of a project I had been planning for over a year. . .
I got it off Amazon for just over $500 with free shipping! :bacon: :bacon: :bacon: :bacon: :bacon: :bacon:
Discussion starter · #79 ·
I was kind of in between mods and I needed to do something one weekend. So I knocked out some painting. I had been looking for that perfect graphite paint for some time and finally found what I was looking for at Pep Boys. First I painted up the Matrix then moved onto the 4xGuard front skid. I painted the center crossmember on the Matrix Khaki to match the Jeep and the rest graphite.
It took some convincing to paint the skid because I liked how it looked silver, but in the end I think I like it better this way.
