I just bought a 97 ZJ on Saturday from a private party. Drove and looked great, had a write-up from a garage giving it a full workover and thumbs up. It's a primarily stock vehicle, former owner put on a push bar and aftermarket fog lamps which are wired to a custom switch mounted inside. There is also an aftermarket stereo.
Ever since I have been trying to pinpoint an issue. Sorry so long, summary at the bottom.
Sunday - Driving at 70mph with cruise control on, I feel a barely noticeable "miss" or "slip". I'm thinking I'll change the plugs and wires, no big deal.
Monday - I drive 25 miles to work, the last 10 of which is highway. After getting off the highway I've slowed to about 35mph, I feel the vehicle lurch and lose a lot of power, I hit the gas and after about a second of hesitation it's back to normal. Drive home without incident.
Tuesday - In the morning, less than a mile from home it cuts off while driving (was under 10mph). Restart it, it cranks a few seconds longer than it should, but starts, and I go to work and then back home with no incident. Tool around with it that evening, change a light bulb that was out, then start the vehicle, after a few seconds it shuts off like I had turned the key (no sputtering or anything). Start again, again it shuts off. Start again and rev the engine up to 2000 rpms for about 10 seconds, then let off, it idles just fine.
Wednesday - Get to work no problem. Take a mid-day break and drive it no problem. Leave work and go to a parts store across the street to have them test the battery (wanted to rule that out first). Battery tests "Good - Recharge" which showed the 660 CCA battery at 598 CCA. Starter Test and Charging System Test both report normal with no problems. Drive about 15 miles on the highway and get off, go to another parts store to test the battery again. This time it just comes back as "Charge Required" with a measurement of 493 CCA. At this point I'm thinking I need an alternator, as it's apparently not charging my battery (after 15 miles on the highway it measured lower).
Today - Cuts off again on the way to work, after I'd been driving for about 15 minutes and was pulling up to a light. Again it started right back up. Got to work ok after that, and when I went to leave at the end of the day, it won't start. Cranks ok, and once could get it to fire up but it immediately shut off. Have a code scanner and it showed code P0320. Got a jump start and once I -barely- got it started, I revved the engine for about 30 seconds, was able to then get it home. I spent the evening removing and thoroughly cleaning the throttle body and IAC with carb cleaner. Started it when I was done, after about 5 seconds, once again it shuts straight off.
TLDR: Vehicle stalls while driving, battery not staying charged, idles fine but prone to stalling, now having trouble starting it at all. Code P0320.
Do I have more than one root issue here? Where do I start with replacing or testing parts? I have a *very* limited budget. I do have a junk 96 ZJ I can use for many parts, but it was not well maintained so I don't know which parts are reusable and which are not. As far as I know battery and alternator should be good on the parts car. Should I be looking at the TPS and/or the IAC for the stalling issue? Should I swap the alternator, or should I just try a new battery (I worry if the alternator IS bad I would kill a good battery and waste money).
