Hi Folks, I'm new here.
I recently purchased a 1983 CJ-7 from a guy that had owned it since 1991. It is all stock in the sense that it isn't lifted or anything, but it isn't exactly original lol. I don't want to say that I will be restoring it really, but I'll be fixing it up and trying to make everything better (appearance and reliability). Anyway...
The 258 engine has had a Weber 32/36 DGV carb installed at some point in it's life, and the plumbing is driving me crazy lol. The PCV valve is plumbed into the float bowl vent for example.
So...questions:
1. The PCV valve is supposed to be at the front of the valve cover correct?
2. With the Weber carb install, where is the PCV supposed to be plumbed to? Into the top carb adapter plate? (I see there is an 1/8" NPT port there, currently plugged).
3. The float bowl vent should be plumbed to??...The charcoal canister? I see there is an unused 3/8" barb on the charcoal canister down below the washer fluid reservoir.
4. The rear port of the valve cover should just be connected to the air cleaner? I don't have the correct fitting for this, but it looks like Crown Auto makes one p/n J3236685? Can anybody confirm?
5. The vacuum advance for the distributor. It is currently connected to a port at the base of the carb facing the engine/head. Is this correct? Can anybody confirm?
6. The fuel supply is tee'd at the filter and goes to two inlets on the Weber. Is this actually needed? Everything else I can find shows only one inlet being used (the one on the driver's side).
7. Is this dual outlet fuel filter actually required? This is new to me...I've been working on old Fords and have only used fuel filters with one outlet. Is the second outlet for venting somehow? It looks like it just runs back to the tank.
Answers to any of the above questions would be appreciated. I just want to get everything sorted out and cleaned up under the hood. I'll be rewiring the whole thing this winter but right now I just want to remove the unnecessary items and correct the necessary ones
. Thanks for your help!
So...questions:
