Intake Plenum Repair Kit, Poor Gaskets
The plenum gasket has been leaking for a couple of months in my Niner (5.9). It's been using a quart of oil every thousand miles, small drop in power and the engines block is sucking a vacuum.
I ordered the Hughes V8 magnum plenum repair kit with the 1/4" thick aluminum plate.
Here's a photo of it.
I had read about the Chinese gaskets that come with the Hughes plenum repair kit, so I also ordered a complete set of Mopar ones with the bolts and everything needed for $41.00 (they took down this ad, was priced wrong)
Below are some photos comparing the ones from Hughes and the ones from Mopar.
I will let you guess which are the ones from Hughes and which are the ones from Mopar.
Those bent pieces of rubber will not bend back up.
Yes, those are scratches on the metal, I'm thinking that happens when they clean the rubber off the sides.
