I take it when the mechanic says he thinks it's a computer problem, he's referring to the PCM (power train control module). So, what are the symptoms of a shot - needs to be replaced "computer"? My only symptom is no spark.
Disconnect the O2 sensor and see if it runs.I paid a mechanic to replace the Crank Sensor. Turned out, the original one was still good. Cha Ching. Haven't considered the 02 sensor. How can this be tested?
ECM = PCM?
I don't know about in the 95, but in the 96-98 the o2 sensor can short out on the exhaust causing a no spark condition. It is essentially shorting the PCM.why the hell would the o2 sensor cause no spark???? absolutely no relation..
If it's the pigtail/connector on the CTS (coolant temp sensor) on the T-stat that's shorted, would the Jeep start with the CTS unplugged? Remember, the '95 Jeep has two CTS, one for the gauge and one to the PCM. It's the one to the PCM that was changed out (and never needed to be).Anyone tried disconnecting the coolant sensor that was just replaced? A shorted sensor can bring down the ECM, producing a no-spark scenario. Usually that's the crank or O2, but there's no reason why it can't be another sensor that's shorted out.
Sounds like the fuse is (and usually is) blown. Check the small fuses in the box under the hood, should be a blue 15A.if it did short out would the computer be ok or fried?
