While researching these shocks I was running into a lot of conflicting measurements. No websites that I could find actually listed the measurements (just said for 3.5" to 5" lift).
I wanted to make this post so it hopefully helps someone later on, that may be looking for this information. This is straight from ARB:
Front shocks (60047L which I believe are replacing the 66L) are 678mm (26.69") extended, 392mm (15.43") collapsed.
Rear shocks (60049L which I believe are replacing the 67L) are 622mm (24.49") extended, 366mm (14.41") collapsed
Most of the information I found was correct for the front shocks, but they also listed the rears as the same length, which isn't the case.
