98 ZJ rear hatch stuck closed
rear hatch zj
21K views 17 replies 11 participants last post by  DrReaper
My aunt's ZJ's rear hatch handle is broken. It is still there but it won't open the hatch. tried locking/unlocking with the key and still doesn't open.
Any ideas on how i can get it open?
does the handle feellike its locked or does it feel "stuck"
with mine, I have to hit unlock on the door a few times in a row and it frees up the hatch, then I have to push on the hatch while I pull the handle, if that makes any sense to you.
mine probably needs to be greased, its a common issue on ZJ's
X2 until I fixed it. Had to adjust the latch, pin and adjust the door bumpstops. It works fine but rattles a bit now so next time I'll also adjust the door hinges.
The rod to the latch is held in place by a plastic clip.that slips and you can't open the hatch without pulling the panel and adjusting that clip., theres about 9000 threads on it here and at least 30 write ups.
So i got it open. Turns out that the rod had slipped off
and i am missing that white piece.
went down to the dealer to see if i could get it, but i guess I'd have to buy the whole latch assembly
Any ideas on how to fix it?
Head over to the junkyard, get the part you need. Bet they won't even charge you if its a little clip
What i did while i was in there was tied some picture hanging wire to the rod and ran it up between the window and the trim . Next time it happens , you'll have an emergency pull .
