what is the best place to hook a strap to on the front of a 93 zj without tow hooks
This. The axle is really about as good a choice as you have with no tow hooks, but you're asking for trouble and I'd be surprised if you could recover something that's buried without bending, tweaking or breaking something.Simply hook onto anything you don't like. It will get pulled loose very quickly.
The ONLY safe and secure location to attach a recovery strap on a unibody vehicle is the factory installed or factory style aftermarket tow points that incorporate a frame reinforcement bracket.
Stop by the junkyard and look for some factory tow hooks. They are easy to remove and will fit on your Jeep.
I have those same fogsWill the radiator support work if you have the warn brush guard?
Because the mounts for the guard also use those holes. I can take a pic with the cover off if anyone needs to see the mounts themselves
EDIT: maybe they don't use the same holes but I think they do. Does anyone have a pic on the kor rad sup mounted and where it's mounted to?
Sent from my iPhone using JeepForum and has probably been edited.
It would rip out. It's secured well but the mounts are to thin to be used as a pull point. It's not distributed event enough over enough points of the unibody for me to consider it safe to tow from.kg6mov said:If you have the brush guard could you use the front cross bar as a pul point, or is it not that secure?
