jenkins27 said:
Just bought my first Jeep. 2008 JK Sahara and its due for an oil change in the next month. I ran Castrol Syntec in my pickup but have recently read its overpriced hype so I'm switching to a different synthetic. Got it narrowed down to Mobil 1 and Quaker State Ultimate Durability...has anybody used both of these and can give a comparison? Dont want to break the bank either. Cheers.:cheers2:
5w-20?
Both are excellent oils and should easily go 5000 miles. Depending on how easy your actual use is on the oil (lots of highway, few short trips) you could possibly go 7500 or even 10,000 miles.
Pick which ever one is on sale. Get a good filter (fram ultra (XG3614) are getting rave reviews theses days).
Reset your oil minder and see when it tell you to change then go another 1,000 miles.
Just be sure to check you dipstick every week or every fuel fill up until you know how the engine is on oil.
Some 3.8s consume oil.
The oil minder tracks the engine duty cycle and give a good conservative oil change interval based on how you actually use the engine. It could trigger at 3,000 miles, or it could go 10,000 or even more depending on how you drive. It's set up expecting conventional oil so a quality name brand synthetic can go even longer intervals. Although if you are in an extremely dusty environment you have to use your judgement.
I don't know how much you know about the previous maintenance on your '08 but I'd consider changing out the coolant if it's original (OEM is 5-year HOAT coolant) and also get fresh brake fluid. Those are often overlooked.
