What power steering fluid for Jeep Wrangler 2001???
ATF4+ ??? or ...???
ATF4+ ??? or ...???
Yup.NotURMailman said:There are a ton of chemical additives other than just dye that are present in ATF +4 and not power steering fluid.
Have I used ATF in my personal PS systems to no ill effect for years? Yep.
But saying they are exactly the same is false.
If you read the thread from the beginnings, a '02 does not use ATF, but actual power steering fluid.Gents, need some help: there's no ATF+4 here in Mongolia, but I have found Mobil's Multipurpose ATF high performance. It says it's compatible with systems using Dexron 3 H or Allison C4. Is this appropriate for use in power steering for an 02 TJ? Thanks for any advice.
Brian
