Hi all!
First off, I have already found a wealth of info here that I can apply to my first Jeep. (87 YJ 4.2 auto). Good to be here.
The guy that sold me the Jeep had recently replaced the carb with a Weber (not sure which model - has a rectangular chrome filter) and didn't do anything with the return line to the tank. It's just hanging out near the intake manifold with a vacuum cap over the end.
The problem I'm having is the Jeep won't start when it's warm (after being shut off for a while after being driven a few miles or more). The fuel filter (clear plastic) will be empty and the mechanical pump won't add any fuel to the filter during cranking.
My weak engineer mind tells me the tank is a sealed system as there is a warning on the fuel tank cap that states a pressure differential could occur, so I removed the cap on the return line to relieve any vacuum in the system. The problem still occurs.
I'm leaning toward vapor lock in the pump, even though once the engine shut down at a light and refused to start until everything had cooled down. (Again the fuel filter was empty, it filled slowly as things cooled and started right up after 10 minute nap.)
Regardless of cause, I can't have an open return line to the tank just hanging out under the hood.
What should I do with it? There doesn't seem to be a place for it to go.
By the way, the guy replaced the fuel pump at the same time he did ne new carb, so it's all new.
Thanks in advance, all!
Carl.
Carl.
