This thread was floating around in the TJ forum when I was down there......so I'm stealing it.....
What did you do to your CJ today?
For the rear yes, still have to make decision for the front.True trac ?
Agear, not pickin on ya, but do you have any coolant problems with that rad inlet hose? Looks much taller than the rad cap. Last time I had a setup like that, there was air that I couldn’t never get out of the inlet hose.I tried to readjust my alternator so the bracket would stand straight. Its a little better but still off. Some but still a little but at a time. Also looked for signs of a gas smell but not sure where its coming from. View attachment 4336456
yikes, Ive done a lot of manual trans installs over the years in other makes and never noticed this before. whats the modern alternative to whatever AMC originally sold?Make sure you get an oil wick in there.
This is what I was able to find doing google search.yikes, Ive done a lot of manual trans installs over the years in other makes and never noticed this before. whats the modern alternative to whatever AMC originally sold?
You’re ok mate No its not that bad. I believe its the optional upper radiator hose for the jeep with A.C. And thanks you 🙌Agear, not pickin on ya, but do you have any coolant problems with that rad inlet hose? Looks much taller than the rad cap. Last time I had a setup like that, there was air that I couldn’t never get out of the inlet hose.
When I pulled my original transmission out and readying the engine for some work, found a simple piece of oil soaked dense foam inside the crank that was put it by AMC/Jeep. I use the same type of foam today, soaked with engine oil and stuffed in the end of the crankshaft. The foam piece is a bit longer than the opening so once stuffed in, it kind of folds in half.yikes, Ive done a lot of manual trans installs over the years in other makes and never noticed this before. whats the modern alternative to whatever AMC originally sold?
This!! ^ With a bronze/brass bushing I’m not sure you need the wick. Additionally, don’t forget that the only time there is any friction between the pilot shaft and bushing/bearing there, is when the clutch is depressed.This is what I was able to find doing google search.
Just need to make sure you allow room for the input shaft nose to engage fully in the pilot bushing, without too much wick material inside the hole.
For an AMC pilot bushing oil wick, use a material like ordinary felt and soak it in engine oil, such as 10W-30, to impregnate the bushing. Once installed, the porous bronze bushing will release the oil onto the transmission input shaft to provide lubrication.
Do you have a top support bolt on your alternator? I don't see one...I tried to readjust my alternator so the bracket would stand straight. Its a little better but still off. Some but still a little but at a time. Also looked for signs of a gas smell but not sure where its coming from. View attachment 4336456 View attachment 4336457
Thanks for the reply . I do not. So far no issue but i like the replies.Do you have a top support bolt on your alternator? I don't see one...
I happened to add a piece of tube over the bolt, but it's that gray tube at the top of the alternator.
It helps square up and support the top of the alternator.
Rich
I made my own bushing out of this material...This!! ^ With a bronze/brass bushing I’m not sure you need the wick. Additionally, don’t forget that the only time there is any friction between the pilot shaft and bushing/bearing there, is when the clutch is depressed.
The heater hose is resting on top of the piece that I was talking about. I was referring to the straight gray tube (with a bolt going through it). The bolt goes through the top of the alternator, and into a threaded hole in the block.Thanks for the reply . I do not. So far no issue but i like the replies.
wait. For the heater hose yea. AMC jeep hose bracket . Pretty sweet . Its the small things
I believe that bracket is so the alternator can pivot, to tighten the belt. Not the same thing, I don't believe...This is hoe AMC put it i believe. View attachment 4336595 View attachment 4336596 View attachment 4336597
