I almost NEVER change out the 'Grit Guards'...
The only time I replace them is if they are bent up, dinged up, rusted apart, ect...
Just use some emery cloth and clean up the inside part where the 'K' seal rests and put on a new 'K' seal and you should be fine.
DO NOT forget to lube the back side of the spindle where the thin lip of the 'K' seal rests or you will wipe that seal lip out in short order!
Would you like to know how to get the proper amount of grease into the spindle and spindle bearing?
As you will find out, if you heap the spindle or stub axle with grease, it will be scraped off as you put things back together...
This is a 'Sneaky' way to fill the void between the stub axle and spindle housing...
Remember, where grease is, water and moisture can't be, so it's a REALLY good idea to fill that void!
While the spindle is off, drill a small hole outside of the hub bearing pad,
Then you can use a 'Grease Needle' (This one is used for lubricating the bar of a chain saw) to fill the void between spindle and axle once the spindle is back on the vehicle...
THIS
DOES NOT LET YOU OFF THE HOOK FOR PROPERLY LUBRICATING THE SPINDLE AND WHEEL BEARINGS BEFORE ASSEMBLY!
Here is a way to fill the void in the hub once assembled.
Remember, where grease is, water and air can't be.
The reason for this is simple,
Anyplace grease is, AIR CAN'T BE...
If you have a hot hub and you splash off in a cold water hole, the air in the hub will contract and 'SUCK IN' the water past the seals.
If that air 'Void' isn't there, you won't have the 'SUCK' when the hub hits water...
DISCLAIMER!
This IS NOT for street driven 'Mall Pounder' jeeps,
Or desert racers & rock crawlers that never see mud holes or deep water.
This is for TRAIL JEEPS that are going to ford deep water, splash through all kids of mud holes, mud boggers, jeeps that are driven in water of any kind...
Locate the slots in the hub intended for knocking out the bearing races,
Drill into those slots from the outside using a fairly small drill, you don't need much of a hole for a squirt of grease.
Then you use a little bigger drill bit on the outside of the hub so you can thread the hole for a grease nipple (Called a 'Zerk')...
This little gadget is a Grease nipple or Grease Zerk wrench, and it's made to remove broken off grease nipples, thread holes for new grease Zerks, install and remove grease Zerks...
They cost about $8 around here.
Now, you have used the larger drill on the outside of the hub, and tapped with the Grease Zerk tool, install a grease Zerk, and it will look like this,
Besides a hand drill, this is everything you need to do this modification...
The yellow line on the hub is to remind me to turn that Zerk 'DOWN' before removing/installing a wheel so I don't snag on the Zerk...
