I'm reasonably sure about 1999-up TJ w/242ci I6 and 2000-2001XJ w/242ci I6. I think some of the later V6 Dakotas got them (starting around 1999-2000 or so,) but the bellhousing will be for the LA-block and won't fit AMC. However, the NV3550 has the same bellhousing mounting pattern as the 1993-up AX-15e (external slave,) so that opens up swap options. I haven't figured out where else you can find it yet.
Note that the AX-15i and AX-15e are both viable swaps. The AX-15i will allow you to use the exact same clutch kit (including slave cylinder/TO bearing and pilot bushing/bearing) as the BA-10; while the AX-15e will be able to use only the same friction (disc/pressure plate,) the pilot diameter is different and (naturally) the slave cylinder and TO bearing is different. The AX-15i (internal slave) was used in XJ, MJ, and YJ from mid-1988 through 1993, and in the V6-238 Dakota through MY1993 as well (I believe.) The AX-15i became the AX-15e (external slave) for MY1994 - the spline remained the same (1.125"-10,) but the pilot increased in diameter (from roughly .625" to about .750") and requires the use of an "off-list" bushing - generally the bushing from the early 1970's CJ V8-304 and three-speed manual is used.
The AX-15 was also used in the ZJ w/242ci I6 until about midway through MY1994! I don't know if it was the AX-15i or AX-15e, however.
Changing from the BA-10 to the AX-15e also requires changing the clutch master cylinder and hydraulic line - but that should probably be done by now anyhow.
The AX-15i, AX-15e, and NV3550 are all workable swaps for the BA-10/5, but the AX-15s will be easier for you to find (the AX-15 was originally a Toyota box - so you can probably find it in Toyota pickups, and just find an AMC bellhousing to put on the thing!)
