Status
Not open for further replies.
The ultimate Hi lift jack mounting thread.
28K views 128 replies 26 participants last post by  Jerry Bransford
Every year around this time we get a swarm of people asking where to mount their hi lift they got for Christmas. Well I have compiled a nice selection of pictures and explained the pros and cons of each.
First I will say I am not a professional but I have been around them. I have friends who are missing teeth, have broken bones and I personally almost busted my windshield when mine let loose. These things CAN be very dangerous if not respected.
Use caution for language.
First up is the info on the HLJ. They have many uses from clamps, winches, jacks, spreaders and more. There are lots of attachments and options from color to metal choices. That is all up to you.
Next is a common myth that people have. " I must get a HLJ as I have 31" (or larger) tires and the stock jack doesn't work." Well in this picture a stock jack clears 35" tires with room to spare. Yes he is in the garage but a rock or 2x4 will help on the trail. Not to mention your suspension drop, but more on that later.
This is one nice thing about the HLJ but also bad at the same time. Yes you can winch yourself out with it, but notice you are standing in line with the strap, cable or chain. If something breaks you can be seriously injured or killed. If doing this have something hanging over the strap on both sides. I will not dig into this as we are focused on the lifting aspect and mounting.
Here we can see someone lifting their Jeep with a HLJ. As you can see the jack is almost maxed and the tire is still on the ground. In the situation a stock jack would be ideal. To counter this I will use a piece of chain hooked to the frame then under the axle and back to the frame to keep the axle from dropping down. Do this before you lift the Jeep and be sure to avoid any brake lines, ABS or other wires.
Now for the mounting. This is a personal preference thing for the most part. I will do my best to explain the issues with each.
Mounting the jack to the cage behind the back seat is arguably one of the best places. Reasons are the jack is out of the weather (they don't like dirt much. You do clean yours right?), it is easy to access, secure both in an accident and from theft and requires no mods to the Jeep. All you need are a few U bolts from the hardware store or from your buddies old springs when he swapped his leaf springs. The only down side is this takes up valuable space in the TJ. I have seen people mount them higher on the cage but now you add something for back seat passengers to hit their head on.
Next up is the ever so controversial hood mount. The cons do out weigh the pros on this one. The pro is you can show it off to everyone around, even thieves, and it doesn't take up any space. The cons include vision obstruction (I personally do not have this issue and am going by word of mouth so take that how you please), harder to get to (have to walk around the Jeep or have a friend unbolt the other side), easy to damage the Jeep (I have seen more than one person damage their rig load thing thing, from lack of upper body strength to properly lower it, it slipped from their hands or not paying attention and hitting the fender or windshield frame while lifting it. Not a fault of the mount but more user error), in the weather so rust (even with cover), harder to secure from theft and last is if you get in a wreck it could go flying (although not proven).
Mounting it to the spare is a great idea. It has all the benefits of easy access, easy to secure, no space lost, no risk of injury to you or the Jeep. The cons include weather and possible damage if you back into a tree, rock, wall or car.
Mounting it to the body in the rear has same pros and cons of tire except if you hit something it will mess up the body and not just the jack. I have actually seen this once.
Mounting it to the front fender has same effect as rear body expect blocks some vision. I only recommend this for expeditionary vehicles.
This is one I have never seen until I started looking for pictures for this. This won't work for everyone and will get very hot. If it comes loose you are having a very bad day. The only advantage I can see to this is it is out of the way. Way to much can go wrong and I don't suggest this at all.
Mounting to the face of either bumper is a good idea for mall crawlers only. If you hit a tree, rock, dirt hill or car your jack is now garbage. They bend very easy (the forces are not designed this way).
Last one I will cover is the tire carrier. While not all of them have mounts it isn't hard to add them. This has all the pros of the tire mount but it is out of harms way in a bump. It is somewhat hidden and that help with crooks. Just keep it locked and lubed and you will be fine. If you don't want to loose space this is the best place for it.
One other place is a roof rack. Only con is weather, theft and hard to get if you are short.
So in regards to the issues of theft. Nothing is going to stop a determined criminal. I like to use the "out of sight and out of mind" approach on most things. If they see nothing of interest maybe they will move on to the flashy car next to me. I'll leave it to Blaine to explain. A bicycle lock works great as well.
Small locks take care of that and it is no more expose to theft than the whole rig is. Not any more of a con than it being mounted in any other of the locations except inside with a hard top or under the hood. At least if they decide to steal, they won't cut your soft top windows to get it from inside the rig.
All of the mounting options that are out there all require the same basic things. They need to mounted securely to keep the jack positioned in the event of a crash. Even a 12 oz can of your favorite drink can cause serious issue at 40 mph to the back of your skull (remember crash test you see on TV are done at 30-35 mph) so imagine what the HLJ will do. Any mounts that expose the Jeep to the weather can cause the jack to rust and you should follow the instructions provided with the jack to keep it working right.
As for me, I leave mine in the garage. I carry a 12 ton bottle jack that works just fine with my 37"s. In fact most of the time I have it out and Jeep is being lifted before others get their HLJ even ready. If you are worried about sand or mud then carry a small base plate (that you should have even with your HLJ), the base to my bottle jack is the same if not slightly larger than my HLJ. I mount mine in the back behind the back seat although you can get a smaller one that will lift your rig that will fit under the passenger seat just like the stock one. I have used a Hi lift before back when I thought it was the only option and have the dents on my Jeep from my mistake. Ultimately the HLJ can be a great tool, a PITA or a trip to the ER. Like anything else you must be safe, cautious and know what you are doing. Watch some youtube videos on proper usage, make sure you keep it lubed up and make sure to inspect it before you leave and before you use it.
I will update this as more info comes in.
Sounds pretty accurate to me. Mine is horizontal on the spare tire mount bolted on with 1/2" nuts so you need a way to get them off to steal it. Not a lot of crime around here anyway. I agree a bottle jack is generally better but they are harder to carry/mount. I would not look forward to needing my HLJ and they are dangerous.
Save
The one where he is usin it as a winch, the jeep is about to crest the rock, roll and run him over! The under the hood one is to close to the computer and battery for my tastes, the front bumper one also blocks the license plate. And the one on the spare tire mount, Holy Wheel Weights Batman!!!
Many Evils about the Hi Lift, but it is a tool, use it correctly in the right situations its a good thing. Mine is mounted to the roll cage, it may never leave but its nice to have the option.
I had my hilift mounted on my rear tire carrier
but I read Jerry's comment somewhere about just using the bottle jack, so I went and dug mine up and sure enough it works on my 35s. Now the hi lift sits in the corner of the garage, waiting for a hapless victim. LOL.
I even bought one of these just before reading that thread, so now, it sits besides the hilift. Waiting.
http://www.amazon.com/Hi-Lift-LM100-Jack-LM-100-Lift-Mate/dp/B00042KGWG
Reno, I think with a couple pieces of scrap and a nutsert or two you could make up a mount to wedge your bottle jack under the passenger seat which is where the TJs have it. I'll get pics tomorrow if I'm here...
It's a lot of weight but with a good tire carrier there is more than enough strength there. Mine has been that way for a long time and the carrier swings out flawlessly and doesn't make a sound. Jack is easy to get to and it's out of the way. A lot of those carriers are made for these things. If it was a tailgate that's different. Or maybe a cheap carrier.
I carry my HLJ as in the 5th picture, mainly because I spend a lot of time on the National Seashore where a jack capable of lifting the vehicle clear of the sand is required. The only time I needed a jack my bottle jack was all I had. I made out fine but if a Ranger had come by there might have been difference of opinion on meeting the requirement. I have experimented with the HLJ while working around my Jeeps and I agree it is a last resort and shouldn't be your go-to jack. Great write up and great pics.
Save
I use the little ball & loop bungees to strap one in behind my B pillar.
A farm jack is dangerous, but almost every type of recovery or rigging has it's dangers.
I agree with you RnEmOvr screw/post/bottle jack is my go to for actual lifting.
Tough to see how much of a hill this is, but I broke a U joint on this trail and had to get out the old high lift to keep the body level, even though it wasn't lifting the Jeep it was easing my mind taking some of the load, note that an OEM jack is doing the actual work, and the tire is tucked under the axle just in case.
#18 ·
and it doesn't take up any space. The cons include vision obstruction (more pronounced the shorter you are),
Methinks you've never set in a rig with one on there. It is well below the line draw from the top of the dash to the end of the hood and obstructs little to nothing. Distract maybe, obstruct no.
harder to get to (have to walk around the Jeep or have a friend unbolt the other side), easy to damage the Jeep (have you held this thing?), in the weather so rust (even with cover), harder to secure from theft and last is if you get in a wreck it could go flying (although not proven).
It is the same in the weather as all the rest that are outside, but still a con.
In fairness, I've seen more damage to rigs from improperly mounted rock rails, hydraulic jacks jumping out of shop presses, and palm fronds that I have from a hood mounted hi lift.
I've yet to see of any of the quality hood mounts lose a jack in a wreck. The problem with all of the speculation is any jack will be subjected to the same G forces so no matter where you put it, it needs to be secure.
[/QUOTE]
Save
#21 ·
I guess I could have added to it (and probably will) about how easy it is to secure with a small lock. I know here in El Paso someone post on the local Jeep pages about once of twice a month theirs was stolen. I get Jeeps are the least secure vehicles out there and I also go with the factor that "out of sight is out of mind". Why invite them over.
I am 6'4" so it doesn't bother me at all and don't know from personal experience, only going from the word of others that said it did effect them. I will edit this as well.
Didn't mean to make it seem like it was any worse than any other.
I have as well but I have seen people first hand hit their Jeep while trying to load the jack on the hood. Most of it is from people with little upper body strength. I am not saying you will damage your rig, just saying you could.
This I agree with 100% and is why I said allegedly.
I know my "review" is far from perfect and I will adjust as needed. Thank you for throwing in your nickle. :cheers2:
#19 ·
i have mine on the hood, with mounts from Hilift themselfs, so im assuming good quality... and i have mine with main part on passenger side facing down so its flat across the top, obstructs nothing other then having to slightly adjust washer jets, and removed the top grip, its in with recovery bag :)
there is one picture your missing tho for secure location..... corner of the shop. :)
Nice Write up tho
And yes thats ICE all over ..lol Joys of Canada!
#20 ·
Thought everyone agreed the best place for this heavy *** jack is at the house...??
And if you just got to haul that big heavy hunk of metal around what are you doing off road that requires it? require as in there is no alternative?
#24 ·
Used it about 6 times. Two examples:
1. resetting a coil in a longbody zuk on a trail. we still had to put the jack on rocks as it was still too tall
2. lifting my jeep body away from the axle to unwedge a rock that had somehow got in between the rear wheel and the body (made me wish I had got the ww2ww option on my sliders). I couldn't move back as there was literally 2" before my rear wheels would have dropped over a ledge and then it would have been driven up further into the wheelwell. It was definitely a very rare situtation that anywhere else would not have resorted to using it but in the case it was well justified.
Needless to say I carry it more as insurance than anything and have it locked down enough that makes it quite inconvenient to use unless absolutely needed. I look at the h-lift as a nice to have with caveats but not a must have.
#38 ·
On flat level ground, not sure how you could even brake an axle there. Now what if you where high centered in deeper ruts going up a hill?
Save
#34 ·
OP - nice write up. Thanks!
I carry both the factory jack and a high-lift in my TJ. There have been times where the high-lift has been the right tool for the job on the trail. Mine's carried behind the rear seat protected inside the Jeep.
#44 ·
Hi-lifts can be dangerous but they have there uses for me. I mount mine on my roof rack. I am tall enough its not an issue. I usually use a small lock to stop the grab and go guys. If someone steals it I will hope they use it wrong and it breaks their teeth and I will buy a nice shiny new one.
#45 ·
For most trips mine is on the roof rack too.
But when I don't carry the roof rack I can mount it to the tailgate hinges.
I only carry it for off-road trips, it spends most of its time in the garage.
Save
#68 ·
I can't think of many situations where a high lift is the only tool that could get the job done so I don't own one. I am however glad a buddy had one a bit over a year ago. I had a ZJ tie rod and stock drag link running 35's, I completely taco'd the drag link at the end of a rock filter. The only way out was straighten the drag link or get a replacement. We used the high lift and my rock sliders to straighten it out. I drove it back through the filter then 2 hours home.
You can see the rock filter behind the Jeep in the video. Useful tool that day.
#69 ·
Mrblaine, I just remembered a time out your way. We were at the water fall by calico ghost town. We were heading up that and a Sammy got stuck in a notch at the bottom. We had to jack up the Sammy and put rocks under the tires to get it high enough so I could winch it out.
Save
#71 ·
I've been up that waterfall near Calico (it's in Doran Canyon, there's only 1-2 there of any consequence) MANY times and have led many groups up it that included Samurais. We've yet to ever need a Hi-Lift.
#97 ·
So ignoring the question of whether the HiLift/farm jack is the devil's own tool or not, here's a different way to mount one to get this thread back on track...
I've been experimenting with a rack that mounts over the spare tire and holds two ammo cans; it's also got a mounting grid on the back for whatever I decide to mount to it, in this case the jack. Since I never carry the jack except on off-road trips this rack is designed to be put on for the trip and removed after so it straps to the spare with ratchet straps. The ammo cans can carry recovery gear or other trail supplies that I also wouldn't carry on a daily basis.
The weight of the jack might be a lot for a stock tailgate/spare carrier - I've got an Exogate reinforcing my tailgate/holding my spare carrier and I regularly carry weight back there (like a full jerry can) so the weight of the jack isn't a problem.
Save
#98 ·
Mine is a swing out but I actually had this exact idea for gas cans, but I kind of like the idea of the jack being on there too though. It definitely would be too much for a stock tailgate but it's a cool idea. I may have to experiment with this too. The only problem I have thought of is if you have to switch the tire and the spare has no air and you have no space for stuff in the Jeep.
Status
You have insufficient privileges to reply here.
