So we've all heard of the speedo bounce / inaccuracy and many have experienced it. There are many threads related to it however I have yet to see a definitive solution.
As I understand it the speedo is based on a "drag cup" design, which consists of a metal hockey-puck like thing with a metal cup around closely it. The spinning of one causes the other to turn, although they don't touch. If the cup or the puck get out of whack, they rub together slightly on each revolutuion which causes the needle to jump.
So my theory(guess) is that the issue with so many failed replacement cable endeavors, it may have to do with cable tip pressure put on the "puck". So it's a matter of finding the sweet spot of just how tight to screw on the cable housing nut to the speedo input.
However that may be a left field wrong assumption since the cable had a little ball crimped on near the end that may just set the proper distance to the "puck".
My old cable, the factory original had started to develop a slight bounce at a certain speed in it's last couple of years so that's why I replaced it. I did have to cut about 3/16" off the t-case end (iirc) to make the cable fit at all. There is no tech tip or secret side note in the fsm for specific installation either.
So the burning question is, has anyone had any luck eliminating the bounce after installing a new cable? Hopefully it doesn't require taking the dash loose since thats such a pain when theres a dash pad installed!
