Will straight piping my jeep lead to better mileage or will it just make it loud as crap? When I say straight piping it I mean leaving the cat converter but cutting off the muffler.
Well mine being an 88..only 1 02 sensor in the manifold. I must disagree.Earlier 4.0s only have an o2 sensor on the exhaust pipe off the manifold and do better without a cat than they do with it.
You just said the same thing I did...Well mine being an 88..only 1 02 sensor in the manifold. I must disagree.
No I meant mine does better with a cat vs without one lol..Emission wise I have more carbon monoxide than with my cat:2thumbsup:You just said the same thing I did...
How did you run it without a cat? An open header or straight pipe without anything to help with backflow will run worse, but that's a bad exhaust setup and not indicative of a problem from not having a cat.No I meant mine does better with a cat vs without one lol..Emission wise I have more carbon monoxide than with my cat:2thumbsup:
02 sensor and everything is new. But yes only 1 02 sensor. Idk personally I think running straight pipe was too raspy..some like that sound so its all preference. But emission wise it will always be better running a cat! Now performance wise I think a good high flow cat & straight through muffler like a magnaflow or borla would be no better than a straight pipe..a chambered muffler like a flowcrapper or alike then the straight pipe will probably preform better.
Me I liked a deep sounding exhaust...mine sounds similar to this, except louder because its dumped before the axle...I run a magnaflow muffler p#12646. 2.5in/out, round body high clearence so it tucks up nicely..no worries of killing it offroading..cost was around 40 bucks on ebay! Also its full welded vs rolled edges like the dynomax mufflers..no worries of it leaking.
Similar sound here..mines a wee bit louder
Will on my 89 XJ we have had it like this for a long time and works fine I have yet to have a problem with it and on o2 sensors easy fix just buy a dummy for it it will tell computer every thing is finejhumphrey said:The 4.0 has an upstream (before cat) o2 sensor and a downstream (after cat) o2 sensor. If these are out of range of what the cpu has to say is "correct", the engine will constantly be trying to adjust fuel/air mixture to bring it back in spec. If you take your cat off and straight pipe it, your MPG will suffer and youll throw an engine code (check engine light will come on). Not to mention you can cause carbon depositing on the pistons from the computer trying to adjust fuel/air ratio to bring things back into spec.
Sure, cats are for emissions, but the PO of my xj did just this. The cat went out, he had it cut out, and straight piped it from there. The gas mileage was atrocious when I got it. I put a cat back on (and new downstream sensor) and my gas mileage shot up tremendously. The short term worked fine, but the long term wouldve done more damage to the engine than having the cat on.
Basically what Im saying is that the 4.0 was designed to run with a cat. I dont see how they can "mess up a car in the long run" when the fuel/air mixture is predetermined to be tuned to a certain spec, which is partially determined by input from the o2 sensors. So, it seems to me, that running one without a cat (thus keeping the computer out of spec) would be more harmful in the long run than running it with a cat (as intended).
On the 87-90 rigs..they are Renix. No check engine light..less restrictive maitenance ect.Will on my 89 XJ we have had it like this for a long time and works fine I have yet to have a problem with it and on o2 sensors easy fix just buy a dummy for it it will tell computer every thing is fine
Ummm ok..I'm not trying to be a *** or anything but yes they do..stock cats are 3 way conerters...filtering out carbon monoxide (CO), hydrocarbons, and nitrogen oxides (NOx). 3 way cats are on anything 81 & newer. Older cars assuming anything earlier than 1981 run a 2 way cat & only filter CO & hydrocarbons.How did you have less c02 emmisions with a cat? They don't filter carbon.
ITs not the point of that..its more of less do what YOU can. You can't **** down factories or anything, but why help contribute?I think it's great that people say "dont hollow out the cat and wreck the environment!" It is possible for a well tuned car to pass emissions without one. And if people are so concerned about the environment then dont yous ever again waste gas by offroading and terin up trees and crap. Oh and dont buy a lift kit, winch, pushbar, bigger tires ect ect either then because those factories that make that stuff put out way more pollution in one day then a hollowed cat would in a lifetime. So stay on the road from now on everyone:laugh:
