Running without oil in front diff.
2.7K views 9 replies 7 participants last post by  Splinter
My Dana 30 is pooched but I want to drive it until I can afford repairs. Can I run it in rear wheel drive with front hubs unlocked and no oil in the diff. I am unclear whether axle oil lubricates inboard wheel bearings.
IM not sure what you mean by wheel bearings. I consider the wheel bearings the two cup bearings inside the wheel hub assembly. These are not lubricated by diff oil, just grease.
Diff oil lubricates the pinion gears, pinion bearings, and pinion yoke. You can very easily burn up the pinion bearings if you run without oil and throw your yoke out causing damage to your transfer case. It is possible I suppose that you could melt your ourput seals and heat up your inner axle to a point where it could cause damage to your wheel hub, but it would have to get very hot.
The diff oil lubricates the pinion and carrier bearings as well as the contact surfaces of the ring and pinion gears. If you saw the picture of the damage in Don's other thread you would see he's not too worried about anything inside the center section being damaged further.... :D
Don, nothing to worry about but make sure the hubs are actually disengaged. The carrier was busted in half, correct? If so, and the hubs somehow were engaged, you could damage the axle shafts with nothing inside the diff supporting the ends.
jack up one side at a time and rotate the tire while watching the U-joint. If it doesn't rotate, they're unlocked.
I would drive mine in the manner you describe, I would be wary of the slightest noise from the front though.
If I were going to be DDing it, I'd probably pull the front axle shafts, and the drive shaft.
Bill
Your wheel bearings are all out in the hub. They are greased, not oiled. You just need to be sure the hubs are unlocked and it is in 2 wheel drive and you should have no issues.
