My East TX Jeep Project - JeepForum.com
 10Likes
post #1 of 460 Old 07-01-2013, 05:34 PM Thread Starter
Jeepn-n-tx
I went by Mike Honcho...
Jeepn-n-tx's Avatar
1981 CJ7
So, after buying myself another Jeep & trolling here, looking & finding answers, & meeting lots of friendly people who've given their free time to help me get my new ride up and running ... I've decided to post a build thread as I'm sure there will be many more questions & lots more work done on my Jeep. Better than posting a bunch of separate postings I guess. Plus, maybe my questions & crusades will help some other schmo out.
I found my Jeep back in the beginning of May while returning home from a run (I own a lawn biz here with a wide territory & travel a lot of back roads). Its an '77 CJ5 with a Chevy, small-block 350 dropped in. I have no idea as to the trans since it was converted to an automatic. I'm guessing probably from the same vehicle the engine came from. The Jeep was running, abet roughly, when I got it, but have since gotten it running very smoothly. I've also rewired/ fixed all the lights, replaced the brake switch, the TS switch, most of the light fixtures.
While I really want this beast to look as great as it sounds, I'm forcing myself to focus on "function" before "fun".
Below is a pic from when I bought it & got it home.
Anyway .... I guess this is more for my pleasure than anything. Maybe it'll help some one else out in the future. Too many to name already, but thanks to everyone that has already answered my previous questions and concerns.
**EDIT** I have since sold the black '77 CJ-5, but have continued this thread with the white '81 CJ-7 I bought a few weeks after I bought the 5. Below is a running list of links to work I've done in the thread. Hope it helps someone. (I'll try to keep them in order but no promises ...)
First pics of '81 CJ-7
Dedicated grounds for Front Turn Signals
Heater Box Tear Down/ Blazer Heater Motor Upgrade
Interior (Switch Mount, Tuffy Glove box, Stereo) - '77 CJ-5
Coolant Bottle Upgrade - '77 CJ-5
Headlight Relay Upgrade - '77 CJ-5
Destroyed Advanced Adaptor - '77 CJ-5
Untouched Engine Bay - '81 CJ-7
MC 2100 Carb Swap - '81 CJ-7
MC 2100 Swap/ Vacuum Line Diagram
Headlight Relay Wiring #2
Classic Hardtop & Doors
Blown OEM Radiator
Replacement radiator didn't fit & how I fixed it ... See post #208 for a quick run down
MC2100 High Idle Issues
Front Locking Hub Rebuild - Removal
New Tie Rod Ends & Steering Stabilizer/ Dampener
OEM Wheel Clean up/ Clear Coat Removal
Front Hub Bearings, Brake Check & General Clean Up
SpiderTrax Spacer Install
New Muffler & Tailpipe
Dropping a Leaky Power Steering Gear Box
Proportioning Valve & Master Cylinder Replacement
Power Steering Gear Box Install/ Repainting Cooling Fan
Flipping the Drag Link
AMC 20 Fluid Change & Repainting the Cover
Lengthening/ Rebuilding the Sway Bar End Links
Full Door Rebuild, Pt 1
AMC 258 Valve Cover Replacement
Full Door Rebuild, Pt 2
Public Safety Announcement ... Don't be a DUMB A S S like me ... the Hood Flop.
The Hood "oops" Fix
Under Seat Amp Install
Broken Shifter Knob & Fix
Simple Grounds for Front Turn Signals
AMC 20 Inner Axle Seal, Pt 1
AMC 20 Inner Axle Seal, Pt 2
AMC 20 Inner Axle Seal, Pt 3
Painting Hard Doors
6-Bolt Hub Conversion, Pt 1
6-Bolt Hub Conversion, Pt 2
LED Light Upgrade (Inside & Out)
Engine Swap, Pt 1 (the tear down)
New engine paint & clean up
Fixing an OEM dipstick tube to use with a HEI
Engine Swap, Pt 2 (the "pull")
Another shifter knob fix & fly wheel install
Engine Swap, Pt 3 (the drop in)
New bell crank w/ heim joint upgrades
New intake & exhaust manifolds installed
T-176 rebuild
LED headlight upgrade
Fixing broken side mirror mount
New rear bumper/ tire carrier install
I'll do my best to keep up w/ these links as they provide a nice reference to have.
markjenksjr likes this.
Jeepn-n-tx is offline
post #2 of 460 Old 07-01-2013, 05:39 PM
OldTexas
VERY nice! A great ongoing project Jeep. Sounds like she's found a home. All she needs now is a good name.
Paved roads, another example of government waste!
OldTexas is offline
post #3 of 460 Old 07-02-2013, 05:44 AM Thread Starter
Jeepn-n-tx
Jeepn-n-tx's Avatar
1981 CJ7
Haha! I've bounced a few around...
Thanks for the comments. I was in Pearland for awhile, but I had my WJ back then... Miss that thing.
post #4 of 460 Old 07-03-2013, 10:34 AM Thread Starter
Jeepn-n-tx
Jeepn-n-tx's Avatar
1981 CJ7
Alrighty, first things first.... I've decided to run a coolant/ overflow tank but am collecting/ learning info as I read it. I get the general idea from previous posts here, but am confused as to if I need a new radiator cap and why? I understand the coolant will boil over and go into the tank, hence the overflow tank, but when it cools an pressures change, wouldn't it just get sucked back up the tube into the radiator? Is that what a cap is for? To "seal" the top? And do I need to run two hoses or just connect the drain hose from my existing radiator? I'm thinking about going with a basic plastic tank from quadratec for about $19.
If anyone has a quick write up or a link I haven't seen yet, I'd appreciate t. Thanks!!
post #5 of 460 Old 10-01-2013, 12:15 AM Thread Starter
Jeepn-n-tx
Jeepn-n-tx's Avatar
1981 CJ7
Been awhile since I was on here posting .... been doing a lot of trolling and research.
The coolant tank add on went VERY smoothly. I was initially over thinking everything. Total, I think it cost me $25 and about a hour under the hood.... made a world of difference.
Right now, I'm working to get some things cleaned up as I seem to have both a trans fluid leak and a small oil leak. The trans leak looks like it's coming from around the seal. Just going to change the fluid and filter while I'm under there ... problem is, I don't know how to tell what type of transmission I have? Keep in mind this jeep has a Chevy 350 dropped in, mated to an automatic trans. The guy at pepboys, who actually knows his stuff, gave me the filter he thought it would be, but it's not right. How do I find the right filter? I do I know what transmission I have???
Thank in advance.
Edit: Just found this online and thought I'd share ... maybe it would help someone else in the future.
"You need the block casting number and the block's suffix code. Casting # is on driver's side rear of engine, on flanged that transmission bolts too. Suffix code is on pass side front of block.. Look in front of pass side head, there's a little machined pad there, up towards the intake some. Clean both of those places off with a rag, old tooth brush, and wd-40.. Then write the #'s down. Once you have the numbers you can go to www.mortec.com or www.nastyz28.com to look up what they mean. Those numbers will tell you year, size, HP, TQ, carb/injection used, tranny used, and car it was installed in."
-Scott
'81 CJ7
'85 CJ7 "The Black Whale"
post #6 of 460 Old 10-01-2013, 12:43 AM Thread Starter
Jeepn-n-tx
Jeepn-n-tx's Avatar
1981 CJ7
Speaking of leaks ... here's another quick question. The oil leak mentioned above seems to be coming from the top of the dipstick tube as there's oil covering my plug wires, the starter, and the area around it. It's a little hard to tell from underneath as it's just gotten slung around and sprayed everywhere by the wind. I'm confused by the apparent leak at the top of the dip stick though .... and the stick itself doesn't seem to want to sit all the way down inside the tube either.
Any thoughts as what I need to be checking here .... sorry for the dumb questions, I just don't know this 350 engine well enough yet...
Thanks again.
-Scott
'81 CJ7
post #7 of 460 Old 10-01-2013, 10:31 AM
LSUtiger
1980 CJ5
Probably has a Chevy th350 trans. Pretty much the shortest trans available. Hard to fit an auto in a cj5.
1980 cj5 401, t-176, p/s., YJ p/b, tfi/hei hybrid, 3.73 30/44
LSUtiger is offline
post #8 of 460 Old 10-01-2013, 10:31 AM
superj
pcv valve or do a compression check and see if the rings or valve seals are bad.
pcv will cause pressure to build up in the block and bleed out the dip stick tube and so will rings/valve seals
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #9 of 460 Old 10-01-2013, 03:53 PM
aggiejon
1979 CJ7
Or a clogged crankcase breather- the other side of the Pcv. My jeep was an east tx gem. Bought in Etoile tx, across lake Sam Rayburn. I told people when I got her she was like an east tx girl-rough, ornery, and needed some love.
aggiejon is offline
post #10 of 460 Old 10-01-2013, 07:27 PM Thread Starter
Jeepn-n-tx
Jeepn-n-tx's Avatar
1981 CJ7
Tiger - you're exactly right! Confirmed it today that it's a 350trans...
Superj - I've been reading about those checks. Will try to look those over tomorrow or Thursday. Like I said above ... with the 350 swap, it's not like there's a book to reference .... but I'm finding this site invaluable.
Jon - East TX has been good to me jeep wise as well. Found my 5 up north of canton and my 7 over near van. I found another 7, a red one, just a few miles from the house but I value my testicles too much. ... and I won't ask how you know that about east tx girls ... hahaha!!! Gig'em!
-Scott
'81 CJ7
post #11 of 460 Old 10-01-2013, 07:52 PM Thread Starter
Jeepn-n-tx
Jeepn-n-tx's Avatar
1981 CJ7
I had another question I was going to get an answer for so I could get it fixed this weekend ...
I've got a vacuum in my fuel lines that makes the jeep hard to start. When I drive the jeep around and then shut'r down, you can hear the fuel being sucked back toward the tank. If you restart the jeep right after you shut it down, it'll start right up, but any longer and it's hard to start until fuel gets back up the line.
Had a hard time searching for a solution on the forum, but might be just the wording I'm using .... any/ all help is greatly appreciated!
-Scott
'81 CJ7
post #12 of 460 Old 10-01-2013, 08:23 PM
aggiejon
1979 CJ7
Check and make sure you have the right gas cap on the jeep, should be a vented one. And if that doesn't help, make sure your gas tank vent isn't plugged.
And we won't talk about how I know about the east tx girls. let me know if you need anything for those jeeps.
aggiejon is offline
post #13 of 460 Old 10-01-2013, 09:15 PM Thread Starter
Jeepn-n-tx
Jeepn-n-tx's Avatar
1981 CJ7
If I need anything!!!! ... hell yeah I need stuff!
The 5 is pretty good to go already. Just need to fix a few things to get it running a little smoother. The only things I'm missing/ needing to replace I can think of are the seats and seat frames. I also need to replace the main gauge, new dash lights, etc, to get the dash up to speed. I'm going to be replacing the glove box with a tuffy coming in the mail.
The 7 is a different story. Off the top of my head...
- need to rewire the headlights, and all lights up front, from the fire wall forward. Going to do a headlight relay harness from scratch on this one.
- needs new shackles, shocks, springs
- new tail light housings & lens
- hard doors & hard top (I'm an optimist, I know...)
- tires
- spare tire mount
- washer fluid reservoir pump
And I haven't even been through the engine bay yet, but the in-line six runs great as does the transmission and transfer case...
My job is very busy during the spring and summer, so I'm just now getting around to getting lists together. Any time you're in this neck of the woods you're more than welcome out at the house ... just stay away from my daughter! .... hahahaha!!!!!
-Scott
'81 CJ7
post #14 of 460 Old 10-01-2013, 09:33 PM
aggiejon
1979 CJ7
- tires
- spare tire mount
The headlight relay is an awesome upgrade. Anything to put more light on the road is a plus. Did it to mine and its been a great addition. I did an all on headlight upgrade to my daily driver (07 chevy silverado 2500) so when my hi beams are on, both the hi, lo are on, as well as the fog lights. I drive a bunch of farm and county backroads on a regular basis. Makes it easy to see deer, hogs, and cattle hanging out in the ditch waiting to dart out in front of me heading home or to work.
aggiejon is offline
post #15 of 460 Old 10-01-2013, 09:40 PM Thread Starter
Jeepn-n-tx
Jeepn-n-tx's Avatar
1981 CJ7
That sounds like a good idea for me too .... I've got a '10 F-150 and I'm out a lot early in the mornings. Going to do the headlight relay on the 7 first, but I'll built 2 harnesses at the same time. That way I've got one for the 5 when I'm ready for it. Can't have both jeeps down at the same time ... withdrawals.
-Scott
'81 CJ7
