Replacing side window seals in a hardtop?
22K views 14 replies 7 participants last post by  Feetwet
Replacing side window seals in a hardtop, can the outer seals be replaced without window removal?
I have old seals that look like they were cut too short and there is a gap where they were clipped.
Just got my windshield done today and they F'd up the inner seal... waiting for the inner seal then Safelite will most likely be redoing there own work again!:mad:
Anyhow I am looking at all my window seals and trying to get things trimmed up.
There's another small trim cap that goes on the ends of the seals on the bottom of the window, at least on my '89. When one fell off, it looked like the trim had about a 1"-2" gap on the bottom. You may be missing those.
On a hardtop, the EXTERIOR TRIM can be replaced without removing the glass. There is a small connector at the bottom that joins the two ends of the trim.
Dealer part #s...
55175170 Moulding-23023073 one for each side
55134656 End Cap-W23043017 one for each side.
Two year old thread still delivers....:laugh:
If you go for complete removal of the glass you will find a small pedestal-type square at the bottom center of the opening. Place a small rubber block (1/8" thick will do) on this and set the glass on top of it. You may be able to salvage the old one. Backbed the opening with the caulk, set the glass, then seal it up. This will isolate the glass from sitting hard on the fiberglass. Common glazier's technique, rubber blocks can be found at hardware stores, glass shops, etc.
Seal the glass, tape in place til sealant cures, then install weatherstrip trim.
ok....couple more ?'s how clean does the opening where the caulk goes have to be??? i've gotten a majority of it out, but it's not all out. I understand where you say backbed w/caulk...set the glass, but lost where you mean seal it up. is that meaning pressing it into the caulk? and how much to you fill in the grove? flush w/the lip or enough to squish some out. really do appreciate the help w/this. nice to know that we can do the trim afterwards too. Oh, should this be done w/the hardtop on the jeep? right now we have it off.
:laugh:
Okay, I'll try my best to answer all your questions...Bear with me..
Work can be done off the jeep, as long as the top is sitting Flat, not tweaked or torqued.
The opening should be reasonably clean. Some old sealant can remain as long as there are no gobs or chunks of old sealant that would prevent the glass from laying up flat in the opening. Clean the area with Acetone or Alcohol, clean and DRY is the goal here.
Dry-fit the glass to get the lay of the land, see where things line up and how much coverage you have. Don't forget your rubber block.
A light bead of sealant on the flange, 3/16" or so, will do on the opening flanges. Press glass in gently, there may be some "squishing out" ( Industry Term), which is okay.
Sealing up simply means that after the glass is set, go around the glass with a Popsicle stick (or Polycarbonate Dressing Tool, whichever is closest) and tool the sealant into the joint to ensure complete coverage between glass and Flange. You may need to add some more sealant here and there as you go. Tape the glass to the hardtop in a few spots to keep it from shifting.
This is important. There must be a gap all the way around the glass for the "T" leg of the weatherstrip to lock into, 1/8" or so, so don"t fill it all up with the sealant, just around the glass edge. I'd let it sit at least overnight or until there's no transfer to your fingers.
Excess sealant can be cleaned off the glass with a single edge razor blade after it cures.
Install the new trim, probably have to cut it to length, put the joint and End Caps at center, bottom.
When you look at the new trim pieces, you"ll understand about the gap.
That should do it.
