#1 | |
Enjoying the Ride
AX5 Vent Discovered
The 5 threads that you get searching "AX5 Vent" were inconclusive. Some guys even claimed the AX5 had no vent.
The FSM does not address this. After my last submarine adventures on the trail I changed all my fluids and got a nice milkshake out of the transmission. Time to deal. I pulled the shift boot and cover plate and sure enough, there it is on the front of the shift tower. Some Jeeps evidently have a hose installed but my rig just has a little metal breather cap.![]() Sorry paint job, I know... ![]() Anyway, the job now is to get that cap off and install a hose leading up into the engine bay. The cap spins freely but doesn't seem to want to come off. Has anyone here done this fix? What's holding the cap on? Is the fitting underneath usable as a hose mount? Your input is encouraged, I'll post the eventual results. ![]()
Fight Crime...Shoot Back Friends don't let friends roll over without a negative-G strap AX5 Output Shaft Seal Replacement Thread Last edited by Feetwet; 01-29-2009 at 03:59 PM.. |
#2 |
I'd pop the 4 bolts and yank the shift tower off and look at it.
You'll have to loosen the tcase shifter assy an move it out of the way to get the 4th bolt out. Your vent may be a press fit or screwed in. Just find a way to pry/pop/unscrew it and then put a brass barbed fitting in the hole (you may have to tap it) and then run your vent line up the firewall. I did this to my AX-15. It had no vent to start with. I just drilled and tapped a hole for the brass barb fitting. |
#3 | |
Enjoying the Ride
Fight Crime...Shoot Back Friends don't let friends roll over without a negative-G strap AX5 Output Shaft Seal Replacement Thread |
#4 | |
It's not a tight seal so air if needed could make it's way in and out of the top of the tranny. When I installed my vent hose I sealed up around the shifter boot with RTV to keep water out. |
#5 | |
King of the hill
my AX5 had no cap either, anywhere, it also did not have the dust boot around the shift stub shaft, and that was just a gaping hole letting water in left and right until the bearings inside went south. I remember someone posted a thread where they extended their vent and also sealed the shift tower using a universal rack and pinion boot purchased at Autozone ziptied in to stop water from entering under the dust boot (I got this same boot at Autozone, I just haven't been able to install it yet) my new AX15 has a vent cap this time, so I will be performing this same mod soon, along with the boot for the shift tower.
Jeep garage: 2011 Jeep Wrangler JK - 33" BFG KM2s, 2.5" RC BB, ARB bumper, IPF 900XS, Superwinch EPI 9.0 1995 Jeep Wrangler - 4 cyl, 2.5" lift, BFG AT 30s, Ford 8.8, SYE+CV, AX15 swap, ARB snorkel, Aussie locker + loads more - sold 1978 Jeep CJ-7 - 304 V8, TH400 auto and quadratrac 2007 Jeep Liberty - Mother's Jeep, BFG ATs and....mud? |
#6 |
Enjoying the Ride
Gotcha. So you had to seal up the shift tower openings then run your own vent in order to extend it.
That's good for the AX15...Anyone modified the breather cap on the AX5?
#7 |
Enjoying the Ride
Well, I'm gonna bite the bullet go for it. I hope I don't break anything.....
I'll post up the fix If I in fact fix it.
Fight Crime...Shoot Back Friends don't let friends roll over without a negative-G strap AX5 Output Shaft Seal Replacement Thread Last edited by Feetwet; 01-29-2009 at 04:47 PM.. |
#8 |
Enjoying the Ride
Extending the AX5 Vent
Went to Advance Auto and bought a 3/16" vacuum elbow, 6' of 3/16" vacuum hose and a 1" hose clamp. Total cost about $8.00. I had some zip ties and RTV laying around.
![]() Remove the fasteners from the shift boot and tunnel cover plate. No need to completely remove them, just rotate them around a bit and up out of the way. I tied them off to the steering wheel. Locate the breather cap at the front top of the shift tower. ![]() Use a pair of pliers on the top of the metal cap. Gently rock it back and forth while pulling upward. The cap will pop off and leave the vent exposed. There's a spring and rubber washer inside the cap. Discard these three parts. ![]() ![]() The barb on the new fitting is just a bit too big. A little sandpaper on one leg makes a perfect fit. This leg will go in the vent hole. ![]() Apply a thin bead of RTV to the sanded leg and press it firmly into the vent hole. Point the fitting toward the left front tire so the hose will clear everything. ![]() Attach hose and clamp securely. Route the hose over to the frame rail, forward and up the firewall, using zip ties as you go. I followed the fuel return line up into the engine bay. Make sure the hose clears any hot or moving parts, of course. ![]() Make a couple loops and fasten up high. I used a handy wire loom clamp to tie to. You can add a check valve to the hose end if you choose. ![]() That's it. Button up the shift console and you're on your way.
#9 |
Excellent!
I should really do this to my AX5. As soon as I get my paycheck I'm going to get the hose, attachment, silicon, and start
/l , [____], l---L--[]lllllll[]-_ ()_) ()_)==@=)_) |
#10 |
Stop Kali-Ma'ing the dog!
This is a great tutorial! I suspect it's one of the reasons why AX5 started to go downhill fast once it hit New England. This is definitely on my agenda for the summer! Thanks so much!
95 YJ, 2" BDS w/ 1" shackle lift, 235/85/16 BFG ATs 2010 JK Unlimited, Islander Edition ("Her Jeep") (See my build blogish thing for excessive details, ha ha) - North Shore Jeep Club - "What the trash is the point of an automatic jeep with four doors? Isn’t that against your jeepers creepers religion?" - Coworker on my newfound hypocrisy. |
#11 |
Enjoying the Ride
I'm glad you guys found this useful. I've been in a lot of water in the last 18 months hunting and fishing and have had no water in my AX5. Floorboards have been soaked but not my tranny fluid......
#12 |
Paid $20 for BOLD letters
Thanks for putting this thread in the FAQ.
Planing on doing this weekend along with Trans oil. My AX5 has no breather vent, Just some info.
I’m not here to express my opinion but to pass judgment. I prefer to drink my Blue Mountains SUPER COLD "All your base are belong to us" |
#13 | |
from here it gets rough
Below is a photo of this type device I used in another application. ![]()
....I'm not smart, but I can lift heavy things....... Fill out your PROFILE, and don't forget to look in the FAQ for writeups I'm stuck on da Rock http://www2.hawaii.edu/~cbird/Opihi/descrip.htm My Boy Scout Troop site: http://t-304.blogspot.com/ Something bad happened to my photobucket account (..it was my fault...)and all my pictures went blank. I am committed to editing all my writeups and posts to put the photos back in. Let me know if you find a post that needs revision and I will do that one ASAP Currently I believe I have all the critical ones done. |
#14 | |
ight, I probly dont need one but... I was just going to drill a small hole on that top plate where the shifter goes stick in the elbow and then RTV it. but guess i should figure out how to
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
