Does anyone know the pressure in inches of HG that a MAP sensor for a 98 5.2 should read at idle and then WOT? you can read these real-time with a computer, but i need to compare my reading to what is expected. I suspect my MAP is failing.
The term "vacuum pressure" does not mean anything in this context. Real time data would be the absolute manifold pressure and 10" Hg at idle is about what it should be. That pressure would correspond to a manifold vacuum of 20" Hg which is also about what it should be.vacuum pressure at idle was only 10" hg and i assumed it should be much higher. I know it becomes almost zero at WOT.
What kind of problem would I be looking for then if that were the case?You said, The term "vacuum pressure" does not mean anything in this context. Real time data would be the absolute manifold pressure and 10" Hg at idle is about what it should be. That pressure would correspond to a manifold vacuum of 20" Hg which is also about what it should be.
If the manifold vacuum was actually 10" Hg at idle, then you have a much bigger problem than a MAP sensor going bad.
