Sounds like you know what you're talking about.
Very strong rain all day yesterday. No leak. Then, i get in the jeep around 5PM and go on a short drive. This morning there is water on the drivers side floor, having dripped down the fuse box. My gut feeling is that it's from the door gasket. I say this because the antenna is on the passenger side. I'm actually keeping a tupperware container on the floorboard to collect the rainwater. Believe me, there are much bigger problems in life than a small leak coming into my jeep. But, it's a major pain in the butt.
I do not think it's the rubber grommet that comes through the door on the drivers side. but i'll definitely check it out one more time. when you say the door, are we talking about the drivers side door, or the passenger side front door? regardless, i'll pull back the grommet and silicone that area. Both grommets appeared to be in great shape. on top of this, i'll have to see if i can find the antenna wire going through the passenger side door, too. maybe silicone that up.
Thanks again. i've checked this forum (and others), and google, and youtube and this seems to be an unanswered question. Everyone seems to talk about the AC drain, but the drivers side floormat is where the problem is. Not the passenger side.
Just so you know it is definitely NOT the AC drain. I had that problem about 12 years ago and haven't had a problem since i blew out the line.
