JK Grill Removal
66K views 23 replies 17 participants last post by  rirrgang
JK Grill Removal​
If you own a JK, at some point you'll need to remove the grill.
First, locate the six plastic pins/sleeves across the top of grill
These are the only tools you'll need. Small flat tip to get under lip of plastic pin, needle nose if you can't get it to pop out with flat tip.
Put flat tip under lip of plastic pin and pry up(I usually put a finger under screwdriver for leverage)
Same procedure for the inner sleeve.
You should wind up with six pins and six inner sleeves.
Next, locate your turn signal lamps, behind the grill.
Leave the plug together, simply grab and turn counterclockwise and pull rearward.
The top of your grill is now loose.
Now grip firmly, about halfway down the grill and pull toward you, wiggling it as you do. There are clips across the lower section of the grill to work loose.
As you can see, I took a different route to protect my radiator.
That's all there is to it...........
EXCEPT for the most important part...............
:cheers2::cheers2::cheers2::cheers::cheers:
Thanks Joel :thumbsup:
With all of these great how-to's in our new F.A.Q. we will be able to use the threads for all the good stuff like wheeling pic's and discussions on how easy it is to build a JK with all of the info at your fingertips! :highfive:
You are welcome....
I only wish That I'd taken pics of more stuff through the years....:confused:
I feel the same way.
When I'm on my back and covered in grease, just bashed my knuckles on the shock mount and hit my head on the sway-bar, the last thing I want to do is get the camera for some "Glamor Shots":laugh:
I made this its own thread and moved it out here so people can add to and comment on the subject.
You have a link in the F.A.Q. :thumbsup:
:tea:
Great write-up Joel !
I guess the 07' hold downs were a bit different . Mine were like little Philips screws except tended to not un-screw . Same basic deal though .
I like the last pic the best ! .........:cheers:
Might be worth noting that if you are going to pull the bulb out instead of unplugging it that you should be VERY careful no to touch it or let anything get on it. Oils can cause hot spots which cause them to blow out early. Probably safer to leave them in and disconnect.
I agree with JWA. Seen this many times when I was an auto tech.
Great write up!
Oh, and mine has the stupid screw ones, good to know I can replace them with the pull types.
Has anyone using a screen cover noticed heating issues? In the photos I would guess the open area of the screen as less than 50%. At Iowa State we did high speed airflow testing of screens, and you reach a point where the screen effectively stops flowing air because of turbulance. Our project determined that this turbulance really became an issue when the screen open area reaches about 65% or lower.
Just a lab test, but something to keep in mind when placing a screen flat over the coolers.
IowaAndy
IowaAndy
No overheating issues....
As a matter of fact, I recently talked to a guy than ran a bug screen similar to mine through the desert w/no problem.
The electric fan works great.
Good point! I've talked to many JK'ers that have had to modify the grill(usually the lower clips?rubber tabs) to remove the grill.
I benefited from them and their experience, hopefully others will read this and check measurements etc. before slapping a winch on the front.
I lowered my winch mount between the frame rails to compensate.
Thanks for adding to this discussion:2thumbsup:
I did this screen this way for 2 reasons;
First reason, cheap and easy. This is stamped aluminum, picked it up at Home Depot(10/12 bucks).
Super easy to cut, tin snips or something.
Second reason, it's not attached to the grill! I take my grill off and carefully spray paint it. Can you do that with the ones attached between the grill slats?
That's my reasoning, you have your own Jeep, do it your way! This Forum is about ideas and sharing, get to it!
Here's some additional info for those with questions
This is the sheet material that I used, by the tire to show size.(I already made one grill screen outa this)
I tucked the screen behind my driving light brackets in the second pic. If you don't have brackets, a self tapper about 1/2'" long would work.(use your imagination)
There's plenty of plastic up front and finding a place to land a screw is easy. Third pic shows two places that I put screws.
Keep in mind when you are making a grill/radiator screen, there is a contour to the grill and you want to keep that contour all the way to the top.
At the top,(fourth pic) I used felt pads. These are simply 4x4 self adhesive felt pads. I cut them into smaller shims. You can use anything you want. Screen needs about 3/4" of shimming to keep contour.(you'll see)
Fifth pic is to show how much crap stays off the radiator!
As I've said, it's your Jeep, do it your way. :cheers2:
#22 ·
In case you're not near JeepForum.com, the procedure for removing the front grill is also in your Owner's Manual, in the back where it tells you how to replace the turn signal and headlight bulbs. If you don't have a printed copy of the Owner's Manual (just the CD one), you can buy one from Chiseler's web site.
