41 - 49 of 49 Posts
I have a question. Looks like same fuse box for 2015 JK unlimited sport. I installed halo lights and halo fog lights tapped into M9 and M14. They were shutting off when I turned off the jeep and then one day got to work and the lights stayed on after the jeep was turned off. Do M9 and M14 go to a relay that could be bad now? Also notice my climate control knobs inside the jeep If i push them on and get the little orange light they do not turn off when the jeep is turned off. The orange lights stay on. What could be going on now?
Any help appreciated Tom
Anyone know how to get J13 out??? Does just the fuse come out or the whole yellow piece that surrounds that particular fuse?
I'm guessing this fuse is out since my car isn't starting all of the sudden even when I try to jump off my auxiliary batt.
I just reset my J13 and I do not think it is really meant to be fully removed unless it really is bad. One thing, on 2014 rubicon, other than the radio it also controls the fob system so you have to unlock the car with the key then the alarm will go off when you open the door and the fob will not work, but start the car and the alarm will go off....
Hi all,
I'm having an issue with my 2011 JK domelight. Hoping someone on hear can help. The only way for the light to work is by manually hitting the buttons on it. The cluster knows when all 3 doors are open. The light itself has been tested and works. The light is also getting power from the yellow wire. I've tried changing the turn signal stalk. Nothing seems to be working. At this point I feel like it has to be the cluster, but I really don't want to go there as it's quite expensive. Thanks in advance to anyone that can offer some advise! This problem is REALLY bothering me.
Joe
The TIPM controls all the lights in a JK so a flasher relay won't work here.
Starter Relay Replacement
Hi, I just registered to add this information which I hope it will be useful to someone. This forum has been very useful to me. Anyways, this is about the relays. Recently had to change my starter relay. Jeep/Chrysler OEM part number for relays K3, K4, K5, K6, K10, K11 is 4692141-AA and the original is branded Omron. I went to the dealership and they charged me $25 for a replacement. On close inspection, the replacement is not exactly like the original. The new replacement relay is a Song Chuan 898H-1AH-C-R1 U04, 12 Volt rating for the coil, 50 Amperes. Nicely wrapped in Mopar genuine packaging. This same relay can be found online at waytekwire dot com /item/75740/Song-Chuan-ISO-280-Mini-Relay/ for less than $5 a piece. $4.10/ea at the time of this post. You can get all those old relays replaced for the same cost to buy just one from Jeep/Chrysler. I found it outrageous from the dealership but it is what it is.
41 - 49 of 49 Posts
