Jeep JK Fuse Box Map Layout Diagram
2 reading
631K views 48 replies 37 participants last post by  rafaelburgos
#1 · (Edited)
Since the fuse layout map on the inside cover of the fuse box is tough to read for those of us with older eyes, and since there have been several threads requesting such a diagram, I thought I'd go ahead and post this for whoever finds it useful.
If anyone sees any mistakes, let me know immediately and I'll fix it. Note that this is from my 2-door JK 2009... I don't know if there are any differences between the 2-door and the 4-door, nor if there were any changes between 2007 or 2008.
Cavity
Cartridge Fuse
Mini Fuse
Description
J1
40 Amp Green
Power Folding Seat
J2
30 Amp Pink
Transfer Case/Pwr Liftgate Module
J3
40 Amp Green
Rear Door Module (RR DOOR NODE)
J4
25 Amp Natural
Driver Door Node
J5
25 Amp Natural
Passenger Door Node
J6
40 Amp Green
Anti-Lock Brake System (ABS) Pump/ESP
J7
30 Amp Pink
Anti-Lock Brake System (ABS) Valve/ESP
J8
40 Amp Green
Power Memory Seat (If Equipped)
J9
40 Amp Green
PZEV Motor/Flex Fuel
J10
30 Amp Pink
Headlamp Wash Relay/Manual Tuning Valve
J11
30 Amp Pink
Sway Bar/THATCHAM Lock-Unlock/Power Sliding Door Module
J13
60 Amp Yellow
Ignition Off Draw (IOD) - Main
J14
40 Amp Green
EBL (Rear Window Defogger)
J15
30 Amp Pink
Rear Blower
J17
40 Amp Green
Starter Solenoid
J18
20 Amp Yellow
Powertrain Control Module (PCM) Trans Range
J19
60 Amp Yellow
Radiator Fan
J20
30 Amp Pink
Front Wiper LO/HI
J21
20 Amp Yellow
Front/Rear Washer
J22
25 Amp Natural
Sunroof Module
M1
15 Amp Blue
Center High Mounted Stop Light (CHMSL)/Brake Switch
M2
20 Amp Yellow
Trailer Lighting
M3
20 Amp Yellow
Frt/Rear Axle Lockers
M4
10 Amp Red
Trailer Tow
M5
25 Amp Natural
Inverter
M6
20 Amp Yellow
Power Outlet #1/Rain Sensor
M7
20 Amp Yellow
Power Outlet #2 (BATT/ACC SELECT)
M8
20 Amp Yellow
Front Heated Seat
M9
20 Amp Yellow
Rear Heated Seat (If Equipped)
M10
20 Amp Yellow
Ignition Off Draw - Vehicle Entertainment System (IOD-VES), Satellite Digital Audio Receiver (SDARS), DVD, Hands Free Module (HFM), RADIO, Antenna (ANT), Universal Garage Door Opener (UGDO), Vanity Lamp (VANITY LP)
M11
10 Amp Red
(Ignition Off Draw) IOD-HVAC/ATC, MW SENSR, Underhood Lamp (UH LMP)
M12
30 Amp Green
Amplifier (AMP)
M13
20 Amp Yellow
Ignition Off Draw- Cabin Compartment Node (IOD-CCN), Wireless Control Module (WCM), SIREN, Clock Module (CLK MOD), Multi-Function Control Switch (MULTIFCTN SW)
M14
20 Amp Yellow
Trailer Tow (Export Only)
M15
20 Amp Yellow
COL MOD, IR SNS, Heater Ventilation, Air Conditioning/Automatic Temperature Control (HVAC/ATC), Rear View Mirror (RR VW MIR), Cabin Compartment Node (CCN), Transfer Case Switch (T-CASE SW), RUN/ST, Multi-Function Control Switch (MULTIFTCN SW), Tire Pressure Monitor (TPM), Glow Plug Module (GLW PLG MOD) - Export Diesel Only
M16
10 Amp Red
Occupant Restraint Controller/Occupant Classification Module (ORC/OCM)
M17
15 Amp Blue
Left Tail/License/Park Lamp (LT-TAIL/LIC/PRK LMP)
M18
15 Amp Blue
Right Tail/Park/Run Lamp (RT-TAIL/PRK/RUN LMP)
M19
25 Amp Natural
Auto Shut Down (ASD #1 and #2)
M20
15 Amp Blue
Cabin Compartment Node Interior Light (CCN INT LIGHT), Switch Bank (SW BANK), Steering Control Module (SCM)
M21
20 Amp Yellow
Auto Shut Down (ASD #3)
M22
10 Amp Red
Right Horn (RT HORN (HI/LOW)
M23
10 Amp Red
Left Horn (LT HORN (HI/LOW)
M24
25 Amp Natural
Rear Wiper (REAR WIPER)
M25
20 Amp Yellow
Fuel Pump (FUEL PUMP), Diesel Lift Pump (DSL LIFT PUMP) - Export Only
M26
10 Amp Red
Power Mirror Switch (PWR MIRR SW), Driver Window Switch (DRVR WIND SW)
M27
10 Amp Red
Ignition Switch (IGN SW), Window Module (WIN MOD)
M28
10 Amp Red
Next Generation Controller (NGC), Transmission Feed (TRANS FEED), J1962
M29
10 Amp Red
Occupant Classification Module (OCM)
M30
15 Amp Blue
Rear Wiper Module (RR WIPER MOD), Power Folding Mirror (PWR FOLD MIR)
M31
20 Amp Yellow
Back-Up Lamps (B/U LAMPS)
M32
10 Amp Red
Occupant Restraint Controller (ORC), TT EUROPE
M33
10 Amp Red
Next Generation Controller (NGC), Global Powertrain Engine Controller (GPEC)
M34
10 Amp Red
Park Assist (PRK ASST), Heater Ventilation, Air Conditioning Module (HVAC MOD), Headlamp Wash (HDLP WASH), Compass (COMPAS)
M35
10 Amp Red
Heated Mirrors
M36
20 Amp Yellow
Power Outlet #3 (BATT)
M37
10 Amp Red
Anti-Lock Brake System (ABS) , Electronic Stability Program (ESP), Stop Lamp Switch (STP LP SW), Fuel Pump Rly Hi Control
M38
25 Amp Natural
Lock/Unlock Motors (LOCK/UNLOCK MTRS)
question
perhaps you can help me. I foudn an electronic version of the 2008 JK Bill of materials:
http://d.scribd.com/docs/2k4ee67ul95m7ob8twn7.pdf
On page 121 it has a similar diagram. Find number 13 says fog lamp relay. I cant quite figure out where that is on your diagram. It doesnt seem like you have any description for the K items on your picture. Well really my question is this: Since there is apparently already a relay in the stock fuse box, can I just wire my aftermarket lights into that and run the other wire directly to my aftermarket switch?
The illustration in the link is not the TIPM we have in our JKs.
Here is a picture of the "K" items in our TIPM.
The fog lights are electronically controlled on one of the TIPM circuit boards, shown in the second picture.
Maybe you can help me out. I have a European JK with EU tailights and they have a seperate indicator light. I want to change these taillights with led's, but the led's are US versions and share a brake/indicator light.
I asked a few wiring diagrams from the dealer and found out that (without the extra wire) the changes are withing the TIPM/front module. The only thing I don't know is; if it's a seperate relay/module, or if its a software change in the computer itself that states if it's a EU or US vehicle and uses the extra indicator wire.
Can you tell me something about this? If it's a software thing I can ask the dealer to change my JK to a US version.
Thanks,
Dennis
Does any one know how to tap directly into the fuse box to add a circuit that the jeep is made to have without using add a fuse or an Spod? It looks like i might need to take the fuse box totally out to be able to do anything like this but i was hoping that someone might have a different take on this then the add a fuse and Spod. I am not worried about time just if it is possible for a mechanic to do?
Thank you,
that was really help fully i have been searching for that for a while now. You don't by chance have a guide for removing the TIMP itself by chance do you? It looks like it is just held in by a couple off clips and I could use a flat head to release them but I would like to make sure before i frustrate my self with something that is incorrect.
#26 ·
Factory foglights
Is there a way to get the factory fogs to stay on while the highs are on?
Also can you make the low and high and fogs be on all at once.
I did this on my avalanche years ago.
I do plan to add extra LED lights at some point but for now would like to keep the fogs on with the highs/brights.
Great topic by the way. Thank you for all the great info.
#30 ·
Only ways I know of are direct wiring to a separate switch independent of the TIPM, or with a programmer you can choose for them to come on with the high beams.
#32 ·
can anyone give information about fuse panel in 2008 jeep liberty . question does it have two fuse panels ? is one under the other , and how does it come apart . I have stock fog lights and they are not working both bulbs are new But fuse box does not show fuse for fog lights . HELP
Please post your questions in the Jeep Liberty Forums, this forum is for JKs only. Thanks.
Here is a direct link for you. KK Liberty Forum
:cheers2:
#34 ·
Electrical Issues....
Driving home in POURING rain, With no grill, my lights started to flicker. Then I had NOTHING. No steering wheel controls, no lights, no directionals, no runners, no wipers. All I had were my LED spots... Needless to say, I got home safely, but WTF? Any advise will be appreciated.
#37 ·
Fuse M38 protects the door lock relay coils on the pc board inside the TIPM.
Fuse M38 protects the circuits that leave the TIPM to actuate the lock actuators.
The door lock switches are MUX, and are not protected by a fuse.
It's most likely the short that is blowing the fuse is between the TIPM and the door locks.
Try disconnecting each door to see if one of them is causing the short. Don't forget the tail gate.
If, after all the doors are disconnected, it continues to blow the fuse, you will have to check each lock/unlock wire for continuity to ground.
