I searched and read all the instrument panel issue posts, I guarantee you it's not fuse number nine, because I keep blowing it!
89 Wrangler, 2.5 L.
I fried the fusible link for the alternator to the starter relay, replaced both (i tried to bypass the link to test the alternator and fried the starter relay). Jeep starts and runs fine but only the speedo works (fried the power ribbon for the clock too when i pulled out the cluster and shorted it). If both relays that are connected to the battery tray are disconnected the jeep obviously won't run but the fuse doesn't blow when I turn on the key. If either of them are plugged in the fuse will pop as soon as the key is turned on. I have not been able to find any shorts with a mulitmeter so far but I haven't ripped into the wire harnesses under the hood... if you want the rest of the frustrating story let me know, it's long and drawn out but this is the biggest part.
89 Wrangler, 2.5 L.
