Guys that Durango Steering Boxes in their TJ Get In Here!!!
91K views 52 replies 36 participants last post by  J03_TJ
Guys that Have Durango Steering Boxes in their TJ Get In Here!!!
I have to replace the steering box in my tj and Im wondering if it worth the extra money to upgrade to the durango box? My jeep is at stock height with 31"s
which year and engine size is the box from (durango) that works in a 99 tj?
If I recall correctly its a 98 without snowplow option. If you got to a parts store and ask about a rebuilt box they usually ask about the snoplow option. the snowplow option has a slower ratio.
#30 ·
YES,,,
98 - 99 WITHOUT the plow option.
V8
Direct bolt in,,,
But I would plate it where it mounts,,, for some extra stiffness.
:thumbsup:
Do elaborate. My box has been leaking quite a bit lately and I was planning on doing this swap.
Ah, I guess I should actually pay attention to OP's post.
I upgrade my stock box to the non-plow Durango unit.
The only thing is that it did make turning easier. At speed it is basically the same as my Jeep box, parking lots is where it shines but not like a night and day difference.
I have 35" tires for the record so it made sense to me at the time.
my box blew a seal, so I figured id just upgrade to the durango box.(i have 35s") its not a huge difference but you can tell the difference.
#19 ·
It's an 808 series Saginaw which has a larger bore than the 800 series Saginaw that is stock in your rig.
There are variable ratio units out there. I don't know the specifics of what and where to get them, but I had one built for my wife's rig and I'm particularly fond of it. I would not however recommend that most go the same route, it takes a bit of getting used to due to the much faster ratio not mixing well with SWB. I also don't think most folks would pay the 450 I spent and that did not include acquiring the appropriate large bore core.
It is nice on the highway when the assist drops back to old style manual steering which is very pleasant at those speeds.
#21 ·
When I got mine the cost of a replacement Durango was exactly the same as a TJ. At that point I had heard horror stories of replacement TJ boxes having the same problems after being replaced and decided to go with the Durango. Also I was planning on going up to 33's from 31's. However if the cost had been different I would have stuck with a TJ box
#22 ·
---------UPDATE---------
This might help someone.
My steering box did not have leak, the problem was that the steering wheel had a bit of play in it. So I checked all the small ujoints in the steering shafts and found that the joint in the lower shaft (next to the box)had a lot of slop in it. So I changed out the shaft and it solved about 90% of the play in the wheel. Its good enough where there is no need to get a new box
If anyone needs a nice steering shaft bearing (that bolts to thre frame) I got one.
#23 ·
I upgraded to the Durango after 100,000 plus miles with 31s -either the extra weight or poor maintenance took my oem out (I'm 2nd owner).
I would be very wary of who you do business with on this - it took me 3 tries (2 returns) until I got a box with no slop! Choose carefully who you want to arm wrestle with if you need a return.
#25 ·
I wouldn't do the Durango on yours. You will need new lines and need to relocate the lower front bolt sleeve in the frame about 1/2" down.
I would call PSC and get their Saginaw that's has a new housing with the correct bolt pattern for the 03 up.
#26 ·
my tj is a 99 and from what talked about above i need the durango steering box off of a 98 without snow plow option, but off of what motor on the durango, im on 33s now but im putting full sized 3/4 ton axles and running 37s and thats to much rubber for the stock steering box so i figured i would try the durango box out
durangos are great for parts im running the durango alternator too 160 amps and no problems yet
are there any other durango upgrades that i dont know about
#27 ·
Just to clarify, the non-snowplow has a slightly faster ratio than the stock TJ box. The snow plow box has the same ratio as stock, plus fittings / plugs for the plow attachment (possible ram assist?). All they had at the parts store when I went to swap mine was the snow plow version and it works just great with my 33's.
#28 ·
I used the nwjeepn.com info to find the right box for my friends Tj with 37's- it is very helpful and will help answer some common questions... The box literally bolted right in.
Any one run hydro assist with a Durango box? He want to do that eventually...
After hearing about a previous post on slop in steering which turned out to be the steering shaft u joints, I am checking mine today!
As there seems to be a lot of Jeep owners out there considering this swap and because we have done the swap ourselves we decided to provide our readers with an article on the subject.
In this article we are not going to provide you with step by step instructions on how to swap your TJ steering gear with a Durango steering gear. There are far to many sites out there (and manuals for that matter) that provide this information.
What we do hope to do is to clear up the confusion behind this conversion and to answer the questions that we see all over the net on forum groups pertaining to this swap.
From what we have seen on the forums here are some of the most common questions and misconceptions surrounding the Durango Steering Gear.
1. "The Durango steering gear is more heavy duty than the TJ" This is a hard statement to quantify. It depends on what you consider to be "heavy duty". The fact is that the Durango gear has the same casting thickness to the housing as the TJ, however the actual size of the piston and bore are a bigger diameter than the TJ. Therefore the Durango gear is better suited for turning larger tires and is the entire reason for changing over to it if you are running larger tires on your Jeep.
2. "The Durango gear has a tighter turning radius" Absolutely not! It's funny to read the forums and see what some people write. Turning radius is determined by where your steering stops are set at the axle not the steering gear.
3. "The Durango gear with the 3 3/8 "stop to stop" is faster than the one with 2 15/16 turns because it is a higher ratio" This is a very common misconception as a lot of guys think of this number as a "Ratio" IT IS NOT A RATIO, it is an actual measurement of number of turns from stop to stop and refers to how many full turns of the steering wheel it takes to go from one steering stop (full left for example) to the other (full right). The lesser the turns of the wheel the "faster" the steering is said to be. Therefore if you have a gear that takes 4 turns from stop to stop it would take 4 full revolutions of the wheel to go from full turn in one direction to the other. The stock TJs gear is 3 3/8 turns lock to lock. The Non-Snow package gear on the Durango is 2 15/16" which is a bit faster but isn't really that big a difference as to be noticeable in everyday driving.
4. "The Durango gear with the snow plow option is heavier duty" The difference between the two options as it was explained to us by our local steering gear re builder is that the gear with the snow plow option had extra ports for the plow lines and also have the larger stop to stop number (see specs below). Therefore the "NON-plow" gear is the one that you want for the TJ swap. There is no difference in the housing thickness or piston/bore diameter.
The questions we see asked most often are these:
1. "Which year Durango gear do I use?" The answer here is '98 or '99 Durangos, non-plow option. I have not seen a difference in part numbers due to the engine installed but if you are asked, specify the 318 engine. We prefer the non-snow option gear due to the above listed quicker steering response.
2. "What year of TJs does this swap work on?" 1997-2002 model year TJs. The hose size, bolt patterns and steering shaft input are identical for these years TJ boxes to the '98 and '99 Durangos. 2003 and later model year TJs had a Mercedes gearbox with different bolt patterns and hose sizes so the swap won't work for them.
3. "Will replacing the steering gear fix the loose steering on my lifted TJ?" The answer here really is no. Several things can contribute to loose steering which can include but are not limited to: Loose tie rod ends, worn steering column shaft or joints, loose or broken pitman arm, ball joints and caster angle. Also, DO NOT think that replacing the steering stabilizer will fix loose steering problems. Replacing the gear will rarely fix loose steering either. Usually the gear is replaced when an over abundance of oil is seen leaking from it's seals. Most owners will report that changing from the stock TJ gear to the Durango gear did nothing to fix a loose steering condition.
4. "Can the gear be adjusted to solve loose steering?" Yes and No, there is an adjustment for the gear lash on top of the saginaw gear boxes however they are usually adjusted correctly from the factory or rebuild shop. Improper adjustment of the nut on top of the gear can lead to binding of the gears and destruction of the gear, therefore it is advised that if you don't know what you are doing you leave it to a good mechanic that does. Also from what we have seen, adjusting the gear rarely completely solves loose steering problems.
A few things to consider about doing the Durango gear swap:
If you have a stock TJ there is no real reason to do this swap.
The major reason for the Durango swap is due to the increased turning power provided by the larger internal piston which is better suited for Jeeps with larger than stock tires (34" or larger)
A word on core returns:
The pimple faced kid at the local Shucks/Checker or Autozone parts store probably knows much less about actual auto parts than he does about loud chrome mufflers for Hondas so you may slide your TJ gear past them as a core return for the Durango gear. However, most knowledgeable mechanics and re builders will check part numbers and can tell the difference. Ask if you can return a stock TJ gear in exchange for the Durango gear BEFORE you buy just in case, otherwise you could be out a lot of money. One reputable re builder here in the Seattle area was willing to take our old TJ gear in exchange but stated that it wasn't something he would do on a regular basis. We sweetened the pot a bit with an additional TJ gear which was worn out and on it's way to the dump anyway.
The Specifics:
Swap only good on '97 - '02 model TJs
Durango gear needed: '98 or '99, V8 engine. We prefer the NON-Snow gear for it's slightly faster turning.
Stock TJ gear:
Number of Mounting Holes: 3
Number of Turns Lock to Lock: 3 3/8
Input Shaft Diameter: 3/4"
Line Thread Size: M18x1.5; M16x1.5
Output Shaft Diameter: 1.25"
NAPA Part#: NSP277582
Durango NON-Snow Package:
Number of Turns Lock to Lock: 2 15/16
Type of Hose Ports: O Ring
Napa Part#: NSP277588
Durango Snow Package:
NAPA Part#: NSP277580
