Can you over ground your cj7
That's a great idea. Going to probably do this when I replace the hood hinges next month.No, but I have seen CJ projects that have more grounds than needed.
Basically you only need to ground between isolated portions of the Jeep that have rubber, paint, polyurethane, grease, oil or any other insulating media that prevents or slows down the path of electrons. Electrons need to move through conductive material.
Factory grounding was from (-) battery-to-engine block, engine block motor mount-to-motor mount frame and battery to firewall. That was it. Worked OK with fresh new steel, paint that was applied after body parts were fitted and minimum accessories and options that didn't need much current (low voltage that flows to high voltage = DC current flowing from negative to positive).
But over time, these simple connection points become corroded and inadequate for high current add-ons, separated painted panels, and so forth. Providing new points for electrons to move through conductive material is all that is needed and that will depend on the electrical device's function on how it needs to be grounded in order to function.
An example is my underhood light that use to work with factory wiring but no longer worked after painting hood and hinges separately. I simply lost the path of conductivity. With hinges being painted and hinge pins greased, I had to add a ground strap from ground Bus Bar-to-hood hinge bolt to complete the conductive path. I now we have a working light.
Use your own judgement as to where, why and when a good ground is needed.
