1 - 20 of 26 Posts
jkrosky
Discussion starter · #1 ·
So I posted this message a while back (2005 WK Hemi) ...
http://www.jeepforum.com/forum/f67/help-front-end-noise-over-sharp-bumps-1155475/
I got some great feedback and ended up replacing the swaybar bushings. However the noise never really went away.
I took the jeep to a small local mechanic and asked to them to diagnose the problem. They told me that everything on the front end suspension wise looked good. They said the noise was coming from my calipers and they were loose and rattling over small/sharp bumps, which actually makes sence. However, I don't want to pay for them to fix it.
Has anyone ran into this issues (loose/clunking front calipers)? What was your solution? What all did you replace? Did it fix it?
Thanks for the help!
Never heard of that being the cause of anybody's clunking. The caliper is secured by two bolts. They are pretty easy to tighten and you might even be able to do it without removing the tire if you can get a good look at them. If it was that, I wouldn't pay to have it done.
Never heard of that either. If you're caliper was loose enough to cause noise, I would think you would have noticed some braking problems by now.
As lifted up said its pretty easy to check. Just two bolts hold it on. Do you have any mods done?
Discussion starter · #5 · (Edited)
The brakes work fine (just put on new pads and rotors) no problems whatsoever. The caliper bolts are tight. I pulled the tires off and checked. I'm wondering how the calipers are mounted the wheel, with the 2 bolts... if they need to be loaded or somthing. I'm out of ideas and it's driving me crazy!
No mods everything is stock... only 36K on the jeep.
The only other thing that I have noticed (don't know if it's related or not), but could be...
When I'm turning at a fast speed and going over some bumps the jeep seems to get wobbly (tires not keeping good contract on the ground), then the tires seem to catch and the jeep pulls/jumps a bit back into control.
Shocks?
I have actually experienced a clunking sound that turned out to be a loose caliper bolt. It appeared to be tight but I was able to get another 1/4 - 1/2 turn on it and that solved the problem. I was pretty surprised because it was a pretty loud clunk. I didn't even want to drive it without checking it. The hole the mounting bolt goes through is a little larger then the bolt and there was just enough play to allow the caliper to move up and down slightly.
I have the same issue - while my caliper bolts were tight, I found that the brake pads can move up/down a bit in the carrier. I get a clunk/rattle when hitting bumps and potholes, UNLESS I'm on the brakes at the same time...
I bought a brake kit and replaced the slide bushings and the little metal clips which helped for a bit, but the clips loosened up after a few days and the rattle is back. I suspect it's just the particular brand of pads (NAPA mid-grade) not fitting well, but haven't done any further testing. Will post back whenever I change the pads.
Also - I've noticed that the left side of my jeep generated a LOT more brake dust than the right. I guess those pads are dragging a little. I'm pretty sure I didn't mix the sets up. It's driving me nuts - have to clean the left side wheels almost every day.
Lenny
Mine does the same thing. I pulled the brakes apart and found the caliper pins are just a bit sloppy, especially now that the brakes are worn a bit (45k) causing the caliper to sit further out on the pins. I plan on replacing all 4 pins when I do the brakes over the winter, hopefully that will help. I greased the pins and the holes the pins ride in and the rattle went away for a few days bit now it's back.
You can try greasing your slide pins and i would check the caliper bracket(mount) bolts as well. Another thing is when you're on the brakes you put a load on a lot of things in the front end that can mask where the sound is really coming from. Another possibility is your steering. Have you checked the tie rods, inner and outer ends? I had a clunk when accelerating, hitting bumps, and a noticeable clunk when turning the wheel left to right. Changed out my diff bushings, and all the ball joints, and it was still there. Tracked it down to the steering rack. I get to joyfully change that out this weekend.
Just to follow up - I changed my pads and the new ones (Autozone Gold ceramic) fit better. No more clunk/rattle when hitting cracks in the pavement. My slide pins didn't have much up/down movement, but were pretty difficult to move in/out. (maybe because of the new pin bushings) I loaded them up with grease this time and all seems well.
Does anyone know where to get new pins? None of my local shops have them. A "brake kit" comes with new anti-rattle brackets, slide pin boots, and pin bushings but no pins. Mine were ok but one of the old boots was cracked and there was a bunch of rust forming on the pin. I cleaned it up but may want to replace them next time.
You mentioned your steering rack being the cause of your clunk. How did you diagnose this as the cause? I'm in the middle of changing some parts myself and my next step is diff bushings. I know for a fact they need replaced but the clunk you describe is similar to my issue.
What should I look for underneath my XK that would indicate the steering rack being messed up?
Thank you!
Thank you!
With the jeep off turn the wheel back and forth in 6-8" movements, if you hear a clunking it could be the rack or tie rods. I pulled the bellow boot and had my gf turn the wheel back and forth. When I pressed on the rack itself the noise subsided. The tie rods and ends were fine.
Another thing it did was pulling into or out of a tight parking space at almost full lock the front would snap hard. Not a diff chatter type noise but the rack itself loading up and releasing in the housing.
The noise I'm experiencing feels/sounds like a hollow knock in the floor going over bumps/potholes. I also get a light clunk turning the steering wheel left to right when in park.
I've replaced sway bar bushings and end links. I know my diff bushings need replaced because I get the notorious thud shifting out of park into reverse, neutral, drive.
I had a similar noise about 18 months ago and went to my local Sealership. I told them to check the front swaybar as I read this was common source of this type of noise. I picked the car up in the afternoon and they said they couldn't find the noise and bring it back if it get worse. Bloody hopeless!
I drove the car home crawled under the front of the car and unbolted one of the lower sway bar link rods. As soon as it was loose i found the problem. The nut on the ball joint at the top end of the sway bar link rod was loose. It just needed a 1/4 of a turn on the nut to tighten it, the joint didn't rattle any more. That hollow clunk noise had disappeared. Simple, quick and cheap fix. That was the second last time I ever went to the Stealership
1 - 20 of 26 Posts
