Air flow, over or through metal or plastic will create, Static Electricity, in some cases, more so in cooler temperatures. wood factories, using pipe to move dust particles and small scrap, away from the machines, to compost use long lengths, of ground wire on pipes to bleed S.E. Aircraft, in flight develop S. E. and need to be grounded, before refuel or loading munitions as a precaution. Getting in and out of your vehicle in cold weather while refueling, or filling a gas can, while still in the truck bed. can cause S. E. and be a major fire hazard. on and on, you either have a good ground, or you can become the ground
